Question about Motorola Talkabout FR50 (14 Channels) 2-Way Radio
Talk button sticks
Where can i get a new takk button switch? Or should i just trash it?
  • Motorola Master
  • 1,654 Answers
The FR50 is a disposable radio. You will need to replace it. (Sorry)
Posted on Oct 28, 2008
The buttons on the remote control for my talk talk view box stick and do not allow me to change channels or access my recordings.
assuming it is the buttons sticking and not low battery power .. you can use a cleanser, preferably a foaming cleanser, lightly spray then hold the control with buttons facing down while you wipe off the cleanser with a clean duster, make sure you press all the buttons in whist drying with the duster, do this several times if necessary, holding the controler upside down will prevent the cleanser going under the cover.
Sep 22, 2014 | Televison & Video
I have 1200 photos on my memory stick. Is there any way I can wipe out the whole stick instead of having to delete them one by one?
Press the Playback button(the one to view pictures) then select menu. Select the delete(trash bin) and press the right/left arrows and select all images in this folder. Then press the circle button to confirm.
Hope this works.
Apr 24, 2011 | Sony Cyber-shot Digital Camera
How to install ignition switch in 2000 jeep wrangler with auto trans do you need special tools, Do you have to takke the steering wheel off.
You need the special Torx Driver with a center divet to remove the steering wheel cover and the switch itself from the column and put the new one in place. You don't need to remove the steering wheel at all.
Feb 18, 2011 | 2000 Jeep Wrangler
Hi cant change headset profile in my micromax q5fb phone n cant cant talk without headset plzzzz solve my problem thanksss
i also had a same problem a timeback...
i threw those headphones in dustbin...
am using an intex headphone right now...
u can use any other company's headphone(which can be attached to cell) !
Aug 27, 2010 | Cell Phones
Delete memory stick
To delete one or few images on the Camera, please playback the images and press the Trash icon button on the camera.
To delete all the images at a time, please format the Memory stick. To format the memory stick, please select the Setup Menu and select the Memory Stick tool and press Format and OK.
Sep 27, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
My mates PS3 is stuck, he tried to install Linux (Ubuntu) and trashed his harddrive when he attempted to put the firmware back on from a Memory stick! I've ordered a new disk, how can I be sure that it...
did you install ubuntu from ps3 boot loader or was it an install of ubuntu then stick the hard drive in the ps3. cause the only way to install another os is from the install other os option even if the drive is partitioned ps3 has to lock the hard drive to the ps3 witch requires reformatt
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
Trash button stuck, how can I delete pics from camara & memory stick from computer
Go into your camera like you would your hard drive. Go to my computer then, look for your camera listed. Then there is usually a folder listed DCIM. Just look throught those folders. You will find the pictures. Then select them all by clicking and holding shift and delete.
May 09, 2009 | Cameras
345c stick cylinder drifting
SOUNDS LIKE YOU HAVE FLUID LEAKING THRU THE CONTROL VALVE. THE VALVE IS NOT SEATING FOR SOME REASON AND ALLOWING FLUID TO PASS BY IT WHEN IT SHOULD BE CLOSED - TRASH IN IT OR DAMAGED SEAT. TO TEST THIS THEORY, SWITCH BOTH THE HOSES TO A DIFFERENT VALVE TO TEST IT. IT SHOULD STOP CREEPING. MAKE SURE ITS TURNED OFF WHEN SWITCHING ! YOU MAY BE ABLE TO REVERSE THOSE TWO HOSES AND FLUSH THE TRASH OUT BACKWARDS AND THEN REINSTALL THEM CORRECTLY. HOPE THIS HELPS. JODY
Apr 05, 2009 | Plumbing
Turn sigal trouble
first check for grounding wires, beware of shortcircuits, lastly replace stick. If you replace stick without checking wires, u will throw money to trash
Jun 29, 2008 | 1997 Hyundai Sonata
Motorola Talkabout FR50 (14 Channels) 2-Way Radio Logo
81 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
