Question about Craftsman Tools & Hardware - Others
How do I adjust depth on craftsman finish nailer?
4 Suggested Answers
mrhappyface
  • 205 Answers
SOURCE: craftsman 16 guage finish nailer. shoots 2 nails at a time. what
wrong gauge nails or wrong head type nails check that the magazine is not loose
Posted on May 29, 2009
  • 1388 Answers
SOURCE: I have a craftsman 16
Assuming that the nails are correct for gun (16g nails measure .055) and feeder is actually applying pressure to nails (feel spring pressure as you close clip), most likely problem is driver is not returning to top of cylinder. This is caused by low pressure to gun, bent driver, lower bumper missing pieces/cracked, worn oring on piston or lack of lubrication. Remove cylinder and examine condition of lower bumper, replace if broken/cracked; check outer cylinder for check valve in place (usually small band or oring covering series of ventholes) ; replace piston oring as needed, make sure driver not bent. Parts available at sears web site. Good luck
Posted on Sep 08, 2010
wentlanv
  • 710 Answers
SOURCE: Describe your NT50AE2 2" Brad
Hi Randy,
Welcome to fixya!
Copy and paste this web address into your browser and a webpage will open with your nailer on it: http://www.hitachipowertools.ca/en/Products?cat=29&pid=254
Scroll down the page to the bottom of the description and you will see the owner's manual listed. Click on that and you can download and print a copy.
Please place a vote when you accept this solution. Thanks,
Handie Andie
Posted on Aug 21, 2011
My Bosch 18v nailer does not fire
Check the depth sensor is adjusted properly if it is set to deep or low it will not fire
Feb 20, 2015 | Bosch Fnh180-16b 18-volt Cordless Lithium...
Fire blade pasload pin gun doesn't punch the nail in
I'm assuming you've adjusted the depth gauge and this has had no affect? If so you need to do a full service before anything else. That's replacing both upper and lower o rings and give it a good clean. It sounds like your losing compression.
Aug 02, 2014 | RTO Paslode 902000 IM250 Ii Cordless 16...
I have a craftsman 18 gauge nailer/stapler the only # I see is 351.184540 when connected yo air supply it only hisses no firing. Took off depth setter on rear of gun inside it appeared to b a diaphragm and...
Model 351184540 CRAFTSMAN COMBINATION NAILER STAPLER Parts
You can price parts and decide if it is worth it, is the gun old, used much etc. If you don't use it much HF sells inexpensive ones. If you use it more often buy a better name brand at HD, Amazon E bay.
I have a combo nailer/stapler and i only use it for staples. The combo will put a bite mark on your wood. I use a nailer that doesn't leave marks so cleanup before finishing is much easier.
Oct 29, 2017 | Air Tools & Compressors
The gun dose not fire the pin all the way in ?
Dewalt list the obvious causes below.
Remember that the gun may not facilitate the use on specific materials that are just too much for the gun to handle. The most common cause for this issue is depth adjustment is not set properly. Also make sure that the nails being used are the correct nails for the gun. Its possible to buy the wrong type and they look very similar to the ones needed.
Here is The website addy for Dewalts pdf user manual and tech tips.
http://servicenet.dewalt.com/Products/Detail?productNumber=DC616KA#
Low battery charge or damaged battery Charge or replace battery
Depth adjustment set too shallow Rotate depth adjustment wheel to a deeper setting
Tool not firmly applied to workpiece See instruction manual
Material and fastener length Choose appropriate material or fastener length
too rigorous an application
Damaged or worn driver blade tip Replace driver/return assembly; see authorized service center
Damaged or worn driver/return assembly
Mar 08, 2011 | Dewalt DC616KA 18 - Volt 16 - gauge...
I have dewalt dc618, nail doesn't goes all the way in, please help?
Below find information on how to adjust for depth, however if you have already made adjustment then check for broken tip on driver blade. The blade is not expensive and available from dewalt service center.
Please note the following from manual:
Adjusting Depth
The depth that the fastener is driven can be adjusted using
the depth adjustment wheel (C) on the side of the tool.
WARNING: To reduce risk of serious injury from
accidental actuation when attempting to adjust depth,
ALWAYS:
• Remove battery pack.
• Engage contact trip lock-off.
• Avoid contact with trigger during adjustments.
1. To drive the nail shallower, rotate the depth adjustment
wheel (C). There are twelve depth settings, 1 being the
shallowest and 6 being the deepest.
2. To sink a nail deeper, rotate the depth adjustment
wheel (C) to a higher setting.
Sep 08, 2010 | Dewalt DC618KA Angled Nailer Kit
I need a piston stop part#4357.00 craftsman 16 gauge finish nailer model # 351.183210, im told by sears part is not available, any other finish nailer with the same part?
same thing here, I believe it was made by porta cable looked at their nailer, looks the same trying to get that part should be around $14 plus shipping
Jul 29, 2010 | Craftsman Garden
I have a craftsmans framing nailer when pushed against surface it will not fire and release the nails or even try.
Check the compressor to make sure you have it set at the proper air pressure for this nailer. Typically a framing nailer requires about 90 psi.
Aug 28, 2009 | Air Tools & Compressors
Mastercraft Brad nailer piston always fires damaging finish but nail gets randomly shot. Thought it was a indent before nail shot to indent nail since it mostley shoots nails after second shot but lately...
The dial on the top of the gun is most likely the depth adjustment for the nails, this should solve the driver damaging the work piece. Make sure the nails are the correct guage for the nailer you have.
Apr 13, 2009 | Tools & Hardware - Others
Nail Gun cost
A good-quality starter set, including both a compressor and a small nail gun, can be bought for around 200 US dollars (USD). More sophisticated models can reach 1000 USD or more. Optional features such as a hard-shell case, safety trigger, and depth adjustment can drive the price even higher. For one-time jobs, a nail gun can also be rented at hardware stores and home repair centers.
Sep 01, 2008 | Makita Brad Nailer Finish Nailer...
Tools & Hardware - Others Logo
211 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Mike
John Trevino
Jim London
Jim London
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
