Question about Sony KV-HW21M50 TV
Sony tv kv-hw21 .when i turned it on ,initially it goes black but after 5 or 10 seconds picture appears with full darkness as well as no text appear on display when i press the menu button ,infact it
Sony KV-HW21M3
  • 3 Answers
SOURCE: Can't set up the channels on my TV
Some models require two buttons to be pressed together for menu access - usually at the bottom or side.
Posted on Feb 12, 2008
SOURCE: Correct overscan on kv-34xbr800
With TV off, enter the following on your remote:
Display > 5 > Volume + > Power now you are in service mode 2 & 5 will take you up and down categories 1 & 4 will take you up and down settings within categories 3 & 6 will change the data up or down
So press 2 until you come to the 2170D_2 category Press 1 until you get to HSIZ and change the data down to the required setting (different data registers for different width settings)
It could be more involved but this might do the trick in your case. Good luck!
Fixatorre
Posted on Mar 24, 2008
  • 1348 Answers
SOURCE: Sony Trinitron kv-27HFR blurry
the picture tube is gone.
i repaired 150 sony xbr and kv series with that problem.sony has a single gun not three and has a great pix,but burn out faster.
there is a main screen control that you can adjust ,but the tube is gone.
on the back of the crt there is 3 gun drives r g b .
turn the color all the way down so it is black and white.
if there is a green ore purple tint,one gun is out of balance.
ajdusting the r g b controls so that black and white is normal is what you want to do.
the crt board has the screen bias voltage 800volts on it so be very careful and use an insulated screwdriver to adjust the drive controls.
Posted on May 13, 2009
welcomejee
  • 10594 Answers
SOURCE: how to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Posted on Jun 09, 2009
cactus bob
  • 267 Answers
SOURCE: Sony KV-32s40 (picture flashes in and out)
YOUR CRT (PICTURE TUBE ) IS GOING BAD . this is the most common way a sony tv crt fails . the tv is to old to make it worth a crt . but if your handy and carefull there is a way to get a little more time out of it . start with the tv cold , remove the back and look on the little board connected to the neck of the crt . there is a control marked "SCREEN " plug in the tv and cable and start it , with it flashing adjust that control , one way will make it flash more and one way less , adjust this no more than you need to , just enough to stop the flashing .NO MORE ! just be carefull the voltages in a tv can KILL . dont touch anything else in there and use a little inslated screwdriver to make the adjustment good luck .... if this answer helped please leave me 4 stars rateing , this high rateing will keep me in the paid answer department , thank you
Posted on Jun 21, 2009
Blackout area on screen
Make sure the TEXT and CAPTION options are turned off.
I am not sure about the Sonny's, but on my Toshiba a black box appears when I inadvertently leave one of the close captioning (CC) on for text or captions on (such as CC1, CC2, etc.).
Feb 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Black box covering one-half of TV screen
Try turning off the text box function of the closed captioning.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony kv 32s42 32 tv
turn up your master screen control on flyback transformer. if when sceen gos black ,the timer light will be blinking. this means your picture tube is week. by turning up the screen control you may give it more time.
Aug 05, 2007 | Sony KV-32S42 32" TV
Sony KV-35S42 35" TV
Check first for bad solder on the vertical IC, Im not sure for your set as I do not have the service manual, but it may be location IC301. If after resoldering it does not fix it you may have to replace it and you should replace the electrolytic capacitors in the vertical section. Hope this helps. Don
Jul 31, 2007 | Sony KV-35S42 35" TV
Screen went dark
Sounds like the screen control which is usually mounted in your high voltage transformer (Flyback) has opened up. Stargazer
Jan 10, 2007 | Sony KV-27S20 27" TV
Picture problem
Usually that symptom is caused by cracked solder joints on the vertical output IC. As the IC starts heating up, the picture starts breaking up at the top with several "dancing" dark lines appearing, the top scrunches down and then when the vertical quits altogether, the screen goes completely black. A good slap on the side of the TV might make it happen faster or clear it up temporarily. If you have experience working on PC boards then you can resolder the pins of the vertical output IC but if you have never soldered parts on PC boards then allow a qualified tech to handle it for you.
Nov 20, 2006 | Sony KV-35S42 35" TV
Sony kv-32s26 32 inch tv
video card went out in the tv. You are saying you need a schematic. Be real careful getting into tvs. They have very large capacitating capacitators in them that can electrocute you. You need to take it to a repair specialist and have them run a check on it. Sounds like the video card to me though.
Sep 18, 2006 | Sony KV-32S26 32" TV
Picture takes hours to appear
Spounds like the b+ feed filter capacitor off the flyback that supplys voltage to the three drive transistors on the crt board is bad.
Apr 16, 2006 | Sony KV-32V16 TV
Sony KV-HW21M50 TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
