Question about Toshiba 50H81 50" Rear Projection Television
Flickering horizontal lines
I have this horizontal lines flickering affecting both the upper and lower end of the screen, where reddish lines in the lower end and a bluish hue lines in the upper end. Both of these lines continously flickers, I thoguht it could be convergence problem, and tried to correct it using the remote, usng both the crosshatch method and screen numeral method, am able to all three hues but when you open the screen, the problem remains. anyone, could this be an IC problem, or tube problem. Any suggestion will be greatly appreciated. Danubo49
  • Toshiba Master
  • 8,617 Answers
Sounds like a problem in the horizontal deflection circuit.possibly a solder problem. try re-soldering the horizontal transistor, line coils and yoke pins.
Posted on Feb 03, 2008
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
Horizontal lines flickering at the bottom of screen...... SONYbrvia KDL-32L 5000
Hi Freddy Pagan
I like your Sony TV is defective that it cannot be fix again, better call the Customer Support to replace your Sony TV.
I hope my solution may help you.
Thanks for using Fixya...;-)
May 06, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
  1. Mybe VGA driver instalation not compatible with your monitor screen, you must check there are OR if you are use External VGA mybe theyare not compatible with your motherboard system
  2. if not work you must bring your monitor go to service hard,because your computer,because most likely your monitor easy damaged. good luck
Apr 25, 2010 | Microsoft Windows XP Home Edition
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
Benq w5000 green horizontal line flickering at bottom of screen
Hi there
This is normally only one of two things : Cable or Mainboard
The W5000 is quite a new Projector and should still be under warranty.
But try changing the cabling first and if the problem still persists , let BenQ replace the Mainboard.
Aug 30, 2008 | Televison & Video
PIcture Flickering
you may have a convergence problem. need to replace the stk 392-040 2 eq..
Jul 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Video flickering
Horizontal lines are either caused by the main logic board, a dammaged screen or by the main x and y drivers. Hard to determine which one it is, but somthing is getting hot which is causing the problem. My guess is the main logic board.
Apr 03, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Toshiba 50H81 50" Rear Projection Television Logo
972 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
