Question about Refrigerators
Samsung rf217 water and ice under crisper drawers
  • 112 Answers
SOURCE: ice acculation under crisper drawers
No. There is, however, a drain hole in the back center that tends to get plugged. Remove the lower two drawers and see if it is plugged. It drains to a pan under the unitand behind the kickpanel
Posted on Oct 18, 2008
SOURCE: water standing under crisper drawers
small drain hole/tube inside (behind crisper pans) is stopped up. Clean out with flexible wire, etc.
Posted on Jun 24, 2009
  • 3600 Answers
SOURCE: Water collects under crisper drawers
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
Posted on Aug 28, 2009
Testimonial: "found a drain hose but can't see where either end is located"
  • 30 Answers
SOURCE: water under crisper drawers. model frt18b4a
Unplug the power to the Fridge, take the items out of the freezer. There is a bottom tray that's inside the freezer that has 2 or 4 screws, remove the screws that holds the floor to the freezer and lift it out. You will probably see a sheet of ice on the bottom of the freezer. You may have to take off the back cover which is inside the freezer, it covers the evaporator. Then you will want to defrost the ice, do not use a heat gun it will melt the inside of the freezer. Best way to thaw it is leave the power off and melt it with hot water (not boiling). Either wet vac out the water as it melts or use a hand towel to mop it up. Sometimes a turkey baster will work to squeegee it out. There is a drain hole in the back that you will see as the ice begins to melt. That needs to be clear and the only way to clear it is to cover it with hot water. You will know that it clears and working when you see the water drain out thru the drain hole in the back of the inside of the freezer. By the way the drain drains thru a pipe thru a tray that's on top of your compressor. That's what heats it and makes it evaporate. Be advised that as you see that it is clearing, you can stop dumping water down there as some may get on the floor as the pan may overflow and dump water on the floor. If that happens, just mop up the water from the floor. Now put it back together again and plug it back in and you should have no further problems.
Posted on Aug 31, 2009
  • 122 Answers
SOURCE: frigidare 1812 frig-water under crisper drawers
clogged drain line somewhere in fridge plumbing
Posted on Feb 22, 2010
Water falls into ice tray and freezers.
If you have a Samsung French Door (as I did) you'll find the solution here: Samsung Refrigerator Leaking Into Crisper Drawer Floor
Mar 23, 2016 | Refrigerators
Water under produce section
In addition to water under the crisper drawers, you might be getting water in the drawers too, look for any ice/frost in any of the air vent holes just above the drawers on the rear fan cover. This unit was made by Samsung for GE, these are notorious for this issue as the defrost drain tube wick heater is not long enough to work. You will need to turn the unit off for 24 hours, unplugged, doors open to ensure it's completely thawed both behind the cover and drain tube. Part# WR13X10573 (cover assembly complete) gets replaced, and part# 819043 will need to take the place of the existing Samsung one. Pleazer Appliance...
Apr 08, 2014 | GE Profile Pfsf6pkw 25.8 Cu. Ft....
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
Ken more refrigerator has no ice maker but water is pooling under the crisper drawers. Model c21tfa95
Check the drain channel at the rear of the fridge just above the crisper drawers and blow through the drain hole with a drinking straw to clear it.
Jul 02, 2012 | Refrigerators
Fridge is collecting water under the crisper drawer of my Samsung RF217 fridge, has french doors and bottom freezer. How do I get to the drain hose to thaw/flush it?
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 16, 2011 | Samsung Refrigerators
Aug 28, 2009 | Refrigerators
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Frozen Veggies in Crisper Drawers and Water under Drawers
water under the crisper doors is pretty common, all you have to do is raise the front legs of the refrigerator, Refrigerators have a heater in them that keep everything from freezing, if it wasnt for the heater then it would just be a freezer, now alot of these samsungs have 2 evaps, so if you get a warm fridge, its prob. because a sensor is out or the heater is out and there is ice buildup inside the unit preventing either the fan from turning, or just blocking air flow, but for the water, just raise the front legs and there is a drain in the back that it will go into from now on
Jul 29, 2008 | Refrigerators
Refrigerators Logo
1,264 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
