Question about Echo Garden
What is coil gap on echo hc 150 - Echo Garden
3 Suggested Answers
  • 203 Answers
SOURCE: I need coil and spark plug gap settings for echo
0.026 inch, or 6-8 mm is the plug gap.
The ignition coil air gap range is 0.012 - .016"" or .3 - .4 mm. This is the gap between the flywheel and the ignition coil.
An easy way to gap your coil is use a normal business card between the coil and flywheel, tighten the screws and remove the card.
Posted on Oct 23, 2009
philwalker78
  • 608 Answers
SOURCE: I have a echo HC-150 it won't stay on boggs down
Hi, either the carby is flooding and requires a carby kit or the spark arrestor or outlet in the muffler is blocked. Hope this helps, regards Phil.
Posted on Jul 18, 2011
Replacement of starter cord on HC-150 hedger
You may have wrapped it the wrong way. If not, your spring is either broken, the bend on the end which slides into the plastic has straightened, or the plastic spool has broken where it holds the other bent end of the spring.
Nov 07, 2013 | Echo HC-150 COMMERCIAL SERIES HEDGE...
Echo HC-150 rebuilt the carb, and now the primer bulb sticks and engine won't start
Try to pressure test the carb to see if you have an internal leak. If it won't hold pressure then it is junk and needs to be replaced. If it holds then double check that you didn't accidently put the gaskets and diaphragm in wrong. If it holds and still doesn't work right replace the carb anyway. They are relatively inexpensive
Jan 20, 2013 | Echo HC-150, Hedge Trimmer 20"
Have no spark on my Echo HC-1500 hedge trimmer. Have replaced coil with new but still no spark. Have also by passed kill switch still no spark. What else can I try
Hi, have you tried a new sparkplug? Also did you set the coil to magnet airgap at 8 thou? Also when you say you by passed the kill switch did you do this by leaving the wire off the coil? Because if you did it at the switch end the wire from the coil may be chafed somewhere and earthing the coil. Hope this helps, regards Phil.
Jul 27, 2011 | ECHO, Inc. 20 In. Double Sided Hedge...
Jul 18, 2011 | Echo Garden
Hello, what is the gap for the pick up coil and flyweel for Echo leaf blower PB251.
a bussiness card thickness, slide it between flywheel and coil, the rotate till magnets catches coil the tighten up
May 27, 2011 | ECHO, Inc. PB-251C Handheld Blower
Igntion coil on echo trimmer went bad, replaced with echo blower coil . there is a small difference in design but now have ignition. Engine still won't start.
Make sure the air-gap between your used blower coil module and the magnets on the Echo's flywheel is about the thickness of a regular business card. That is about .010"-.016". The gap HAS to be present in order for the module to produce the spark.
Oct 01, 2010 | Echo Rapid Loader, Trimmer Head
How can i test the ign. coil on a echo HC-1500 and also check the flywheel i have no spark and i have unplug the kill switch
pull the spark plug and ground it to engine. pull rope, and you should be able to see a spark across the plug. If no spark, replace the coil. There really is no effective way to check a coil without a very expensive coil checker.
Sep 23, 2010 | ECHO, Inc. 20 In. Double Sided Hedge...
I need coil and spark plug gap settings for echo hc 1500 type E2 hedge trimmer.
Oct 23, 2009 | Echo Garden
Looking for owners Manual for Echo HC 1500 Hedge Trimmer.
Go to this web site http://www.echo-usa.com/ and on the right hand side of the page click "TECHNICAL DOCUMENTS"
Then when the next page comes up type "HC-1500" and click search.
Now this is important: You have to keep track of your serial number, your model number and
your engine type.
Even when your looking for parts such as the ignition coil keep track of your serial number.
When you pull the side bar down you'll find the different manuals you can copy. I hope this helped.
Apr 02, 2009 | ECHO, Inc. 20 In. Double Sided Hedge...
Garden Logo
125 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
