Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
Gaggia Synchrony Compact heat exchanger thermostat
How can I test the thermostat. I tested resistance and it is zero at room temperature. If I heat is with a gas burner resistance remains zero until it clicks open and resistance is infinite. When removed from the burner the thermostat switch closes at ~276F (135 C) as measured with a infrared thermometer.
The problem is that the power supply wire to the heat exchanger is overheating and I am trying to isolate the source of the problem for possible repair.
5 Suggested Answers
mirran
  • 515 Answers
SOURCE: Gaggia Synchrony Compact Digital Problem
I think you have get air in the system, try to find a bellows pump or similary. Fill it with water, open the steam knob and take of the water tank, put the pump in the water inlet and press. When the water begins to flow, close the steam knob and put the water tank back.
Best regards
/Mirran
Posted on Nov 08, 2008
SOURCE: Gaggia Synchrony - we need a new boiler.
http://www.cafeparts.com/dynamicIndex.asp This site has parts.
Posted on Mar 27, 2009
EsWorld
  • 1618 Answers
SOURCE: I have a Gaggia Synchrony compact. I recently
If it leaks from the steam wand then you need to get a new steam valve assembly. For the heat you will have to open the machine it is possible that the steam boiler is damaged or that the thermostat on there is bad, use an ohmsmeter to check thermostats and element. There are 2 screws in the grinder, 2 behind the water tank and about 2 or 3 in the front behind the door.
Posted on Jun 13, 2009
  • 109 Answers
SOURCE: Gaggia Syncrony not dispensing properly
It sounds like you need to program the coffee level.
Have a look on this page for the instruction manual.
http://www.coffeeitalia.co.uk/downl-manual.php
Posted on Feb 25, 2010
  • 1089 Answers
SOURCE: I have a Gaggia Digital Syncrony. The machine
Hi
You could have a micro switch in the doser that is going bad and needs to be replaced. They are a special micro switch that is very sensitive and can get stuck with a little coffee dust inside the switch.
Posted on Mar 10, 2010
Miele t224 is not heating and suspect it's the thermostat. I have tested one with the multi meter and no reading.i understand there are others !can you direct me to it or them please ? So I can test
Make sure the wires are not connected during tests. At room temperature, you should get a reading of zero on the thermostat. When heated, it should read infinity.
You can also test your heating element. Once you have gained access to your dryer's heating element, set your multimeter to the R x 1 resistance scale. Touch each meter probe and to one end of the element. If you receive a reading of infinite resistance, then your heating element is no longer functioning properly and you will have to replace it.
Jun 13, 2016 | Dryers
My gas Dryer will ignite but it goes out after a couple of minutes? I changed the coils and the problem is still there, what's going on?
one of the thermostats in the rear of the machine ( located on the heat vent tube and or burner tube, has stuck, or is bad, you can check those by removing the wires attached to them, do them one at a time and mark the wires, ) set your meter for resistance, at the Rx1 setting,, Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero.
Sep 08, 2011 | Dryers
How do i test thermostat for maytag dryer
The wires leading to the thermostat are connected using metal slip on connectors. Remove the wires by pulling on the connectors, and not the wires themselves. It may be a good idea to use a pair of needle nosed pliers to help you.
Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. I strongly recommend that you test your thermostat at room temperature.
Jul 15, 2011 | Maytag MGD5600T Dryer
The dryer lights, heats up for a few minutes then the heat shuts off
your limit thermostat is going out heres how to check them
Jul 13, 2011 | Maytag MDG16MN Gas Dryer
I have a Whirlpool electric dryer MOD WED5540S!) SER MU2124790 TYPE DWJR-ELE-2406026-FM54 the dryer runs good, but will not heat. I have checked the air flow and its clear. I've checked all...
Limit thermostat , heres how you check thermostats Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. I strongly recommend that you test your thermostat at room temperature.
Jul 13, 2011 | Whirlpool WED5500S Electric Dryer
The motor turns but the heat is lower than before. Model no NE 5313-4562
check the thermostats ,, you have a high limit thermostat thats probably on its way out , heres how to check them
Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. strongly recommend that you test your thermostat at room temperature.
Jul 13, 2011 | Speed Queen Dryers
Dryer works god for a while then overheats and shuts off...when i push the start button it makes a clicking noise and while it is running it makes a hummin?
thats probably a thermostat going out, over heating , and shutting down if you have a meter you can check them, Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. I strongly recommend that you test your thermostat at room temperature.
Jul 11, 2011 | Whirlpool LER4634J Electric Dryer
Electric dryer. We replaced the heating element. Now a soon as you turn it on, the back inside of the drum glows red hot. Could it be the themostat?
HI. The thermostats in this particular case will be the focal point for your troubleshooting. I would recommend to test all that are included in the unit, especially, the high limit thermostat. I believe this will be the culprit. Be sure that the unit is well ventilated, also. clean out the entire ventilating assembly, if needed.
Thermostat testing procedure:
To test the thermostats or fuse, set your multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
NOTE_ If all temperature monitoring devices test out ok; Replace the main control device.
Dec 06, 2010 | Dryers
Drum turns, poweris present, does not heat
HI. To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
Sep 29, 2009 | Dryers
I have a Gaggia Synchrony compact. I recently decalsified it and it stopped working. The low water light is on and nothing works except, for the water pump. It will flow only cold water through the steam...
Jun 09, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
43 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Henry  Thomas
Henry Thomas
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
