Question about Coffee Makers & Espresso Machines
Gaggia espresso dose leaking water from group head
I have gaggia espresso dose for almost 5 years and i have the above problem, the leaking is from group head even without press the brew button. if i press the button to warm up the machine in order to make some steam for milk i receive a cloud of steam from group head. any suggestions or hint is welcome thanks you in advance
  • 2039 Answers
SOURCE: Coffee tastes burnt/No steam for froth
so i guess our expresso you dont have that creamy topping that lack pressure descalcify not with vinegar remove caicium in chunks have a chance of blocking everything descalcifier solution melt the calcium 1part solution 1 part water fill the water with solution open the valve if some come out close it leave the solution in it for 15 minute repeat untill empty rinse very good cheers
Posted on Feb 03, 2008
  • 40 Answers
SOURCE: Saeco Vienna Digital Expresso Maker - brew group will not line up to fit back into espresso machine
Could be a number of reasons. If you "hear" the brew group moving in one direction, stop and then move again, then the microswitches are o.k. If the sound of the movement is low and/or slow ( slower that normal), the CPU/power board may be bad and needs to be replace. If the movement is as before (same sound and movement) but not lining up, perhaps the brew drive motor is bad.
To remedy this situation, an authorized SAECO Service Center would have to open your machine and replace damaged components. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 19, 2008
z34aga
  • 137 Answers
SOURCE: Water not coming through espresso side although steam wand works fine
you both can have same problem, solution is:
  1. low pressure of pump (or too fone grinded coffee)
  2. security valve of boiler openes to early and dont let the pump to rise pressure enough for good brewing( if it is this you can see water returning back to container if you have 2nd pipe in your machines reservoir)
Posted on Apr 02, 2009
  • 80 Answers
SOURCE: Brand new Gaggia classic, no water coming through the brew head
take out screen and screen holder,and unscrew piece in head,clean with wire and try,i think its your head plugged out.
Posted on Aug 22, 2009
EsWorld
  • 1618 Answers
SOURCE: gaggia baby espresso machine - water comes out of
Remove shower and screw, then run brew button, if that works clean shower, if not remove allen wrench screws and clean diffuser and valve on spirng.
Posted on Oct 21, 2009
Hi, My Gaggia Classic is not working. No water
try to clean the group shower which it can be ansrew by one cetrer screw and if you can you can open the machine and remove to clean also the coffee group solenoid valve. Bothe the valve and shower can be full of dry coffee that can blocked the way of water coming to the grounded coffee.
If you manage to clean everything above and the machine work ok so from now on in order to avoid the problem again try to flush water from the group many times without any coffee. With this is like you wash the group shower and valve from any remai coffee.
Good luck
Jun 29, 2010 | Gaggia Classic Espresso Machine
How do I replace the group gasket?
1. empty the water tank
2. turn machine upside down
3. remove shower rose(one screw in middle)
4. remove group head (two hex screws)
5. pry out old gasket
6. fit new gasket and reassemlbe
Dec 25, 2009 | Gaggia Classic Espresso Machine
My baby gaggia dose (brand new out of the box) leaks
HI
Call who ever you bought it from and have them diagnose the problem. I think you have a disconnected hose or something worse.
Nov 18, 2009 | Gaggia Baby Espresso Machine
Baby Gaggia Dose leaks
On the gaggia clascic there are 2 hoses in the back above the drain tray, are those in the water reservoir? If yes then there is a broken hose on the in side of the machine.
Aug 12, 2009 | Gaggia Baby Espresso Machine
No water coming through group head
Remove the shower screen and clean. If shower is clean then line to head is clogged.
Jun 18, 2009 | Gaggia Baby Espresso Machine
Gaggia Classic Group Head Stuck
try this website http://www.bluebox.com.au/jcrayon/gaggia/
Mar 06, 2009 | Gaggia Classic Espresso Machine
Gaggia baby dose solenoid valve
You may get this part from EBay for around $45/£38 a small "How to" below ">
Dec 04, 2008 | Gaggia Baby Espresso Machine
Leaky Gaggia Classic Espresso
you have very steam because like you know our loosing our pressure you need a seal kit be carefull when you play in there calcium buildup is very hard to remove cheers
Feb 03, 2008 | Gaggia Classic Espresso Machine
Coffee Makers & Espresso Machines Logo
26 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
