Question about HP CP3525DN Color LaserJet Printer
Xp hp cd3525dn drivers
On Windows Xp (32-bit) files only extract, and do not start the installer.
SOURCE: Hp 1018 Driver for windows98
need to windows xp driver for hp laserjet 1018
Posted on May 23, 2008
  • 93 Answers
SOURCE: HP Deskjet 3745 installation on XP x64 bit
We do not have full feature software for xp 64 bit. However install alternate drivers and then try to print.
Posted on Jun 11, 2008
guide2u
  • 461 Answers
SOURCE: can not locate and download 64 bit version of HP 2840 laserjet printer driver
Try below link, it may be able to help resolve you problem...
http://etech.maiila.com/hp-color-laserjet-2800-all-in-one-printer-series-driver-manual-and-software-download-including-for-vista
Good Luck
Posted on Nov 05, 2008
Teis
  • 340 Answers
SOURCE: no driver for the scanner hp officejet 9130 all-in-one priter
You obtain the driver the for HP office 9100 series, here.
- it is on purpose that I want you to download the older PCL5 driver, asthe new PCL6 can course problems.
If any problems, against all ods, should arise, do write back and I will be here to help you. 69d4c1a.png Regards
/Teis
Posted on Dec 21, 2008
pagebor
  • 2785 Answers
SOURCE: does hp officejet 5610 has driver for 64 bit
sorry the website dont have the drivers
Posted on Jun 23, 2009
I used twinkle cam successfully in windows xp. I have upgraded to windows 7. How do I get the driver or will anything work?
According to http://www.chicony.com.tw/download/di/driver.asp , the available drivers were written in 2004. Chicony has stopped supporting their cameras for newer Windows OS versions. I suspect they never made a 64-bit version of the driver for XP 64-bit.
If you had the 32-bit version of Windows 7, you might be able to use the compatibility mode to install the driver. To check your version, click on Start > Control Panel > System and Security > System. Look for your Windows version and check if it says x64. If you see that in the description, you have the x64 bit version. Otherwise, right-click on the driver file from the above site (after extracting the files from the zip file). Choose Properties and the Compatibility tab. Check the box for always Run this program in the compatibility mode and set it to Windows XP in the drop-down menu. You may need to repeat this on the camera software as well.
If you have a 64-bit version Windows Home Premium, you may be better off upgrading to Windows 7 Pro or Ultimate. Then you can download and install Virtual PC and the XP mode, if your hardware can handle that software. This gives a virtual version of the 32-bit version XP that will run your camera. (The CPU needs to have virtualization support and it has to be enabled in the BIOS. Then you need enough memory to give the virtual XP at least 512MB -1GB of memory.) If you already have Windows 7 Pro or Ultimate, just use XP mode. Other virtual PC software exists but they require a licensed version of XP. (If you can find a valid license.) The only issue I've found is that files saved to the C: drive in one OS can't be accessed by the other OS. You have to transfer the files with an external drive, flash drive or burn the file to optical disc.
Dual boot systems with XP and Windows 7 can be set up if you have the XP license. Then pick the OS you need when you boot up the computer. This requires you to repartition the hard drive or have two bootable hard drives. Make sure to back up before partitioning the drive.
I wish that I had better news for you.
Aug 22, 2013 | Chicony TwinkleCam DC2110 Webcam
Is there an updated Acer ScanPrisa 124Out driver compatible with Windows 7 anywhere?
Unfortunately, there are no Win7 drivers for this scanner. THe drivers are for Windows 98SE through XP. The support for the ScanPrisa 1240UT is available here: http://benq.co.uk/support/downloads/downloads.cfm/dtype/M/page/downloads/product/87 . Click on the Drivers tab.
The XP driver may work under Windows 7 32-bit in the Compatibility Mode. (To check your version of Windows 7, click Start > Control Panel > System and Security > System. If the Windows version title ends with x64, you do not have the 32-bit version. Otherwise, you do.) To use this driver in Windows 7 32-bit, download the .zip file and extract it. (Right click and choose Extract All.) Then find the installer (Setup.exe) and right click again and select Properties. Click on the Compatibility Tab and check "Always run this program as compatible with" and fill in XP in the drop down menu. Right click again and choose Run As Administrator.
If you have Windows 7 64-bit, you will need to use a computer with the older version of Windows. This can be a virtual computer (if your hardware supports it), a dual boot machine, or a physical second computer. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP computer for free (again if your hardware is capable of doing it). In that case, download Virtual PC and XP mode from Microsoft. Install the programs in order. Then install the scanner using the drivers from the above link as if the XP mode is your regular computer. Other virtual computer programs include VMWare and Parallels. However for those and the other options, you will need a licensed copy of the older versions of Windows. (If you know a Windows User's Group member, you may have a source for older versions of Windows.)
I hope this helps.
Oct 14, 2011 | Acer ScanPrisa 640P Flatbed Scanner
I need a sound driver for dc5000 for windows 7
There are no sound drivers for this device for windows 7, however you can use an older driver in a compatibility mode. Here is the page for the drivers (these are XP pro x86[32 bit] drivers). To install the driver in a compatiblity mode: right click on the driver file and select properties, select the 'compatibility' tab. Select Windows XP pro. Click apply. Right click the installation file and select 'Run As Administrator'. This should fix your issue
Aug 22, 2011 | HP Compaq dc5000 Small Form Factor PC...
Hp scanjet 4570c + windows 7
Download Windows Vista version (32 bit or 64 bit) depending on your Windows 7/8.0/8.1 (32 bit or 64 bit) from: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=77368&lc=en&cc=us&dlc=en&lang=en&cc=us
Then, extract the file that you download "setup_basic_4500_500.exe" using WinRAR to Desktop.
Next, go to Control Panel then Device Manager. You will see the scanner "hp" under Other devices with error. Right click on it then select update driver software. Select Browse my computer for driver software. Click Browse and point it to the folder on your desktop that contains extracted files. You can make sure to check on include subfolders.
That will install the driver perfectly fine under windows 8.1 in my case 64 bit.
Aug 11, 2011 | HP Scanjet 4400c Flatbed Scanner
I want hp psc 1315 all-in-one printer scanner copier Software & Driver
Here are thedrivers . When you click on the links, give it a minute and they will'pop-up' on your screen. When you click 'Save' the driver package willbegin to download. OS Type Version Date Added File Size File Type Download Link (About) Windows XP Driver 4.2.0 - Basic 2008-05-17 48.54 MB exe HP PSC 1315 Windows XP Printer Driver Download Windows 2000 Driver 4.2.0 - Basic 2008-05-17 48.54 MB exe HP PSC 1315 Windows 2000 Printer Driver Download Windows XP 64-bit Driver 1.0 - Beta 2008-05-10 58.43 MB exe HP PSC 1315 Windows XP 64-bit Printer Driver Download Windows Vista 64-bit Driver 080.001.237.000 2008-05-13 163.07 MB exe HP PSC 1315 Windows Vista 64-bit Printer Driver Download Windows Vista Driver 080.001.237.000 2008-05-13 163.07 MB exe HP PSC 1315 Windows Vista Printer Driver Download Windows 7 Driver 13.1.0 2009-12-04 362.68 MB exe HP PSC 1315 Windows 7 Printer Driver Download Windows 7 64-bit Driver 13.1.0 2009-12-04 362.68 MB exe HP PSC 1315 Windows 7 64-bit Printer Driver Download ALTERNATIVEDOWNLOAD LOCATION.
Note: These are LARGE files and may take some time to download.
Save the driver file somewhere on your computer where you will be easily ableto find it, such as your desktop.
After downloading, go to the location where you saved the file and double clickon the file. Then simply follow the on-screen instructions for installing thedriver.
HPPSC 1315 Windows 7 Printer Driver Download
HPPSC 1315 Windows 7 64-bit Printer Driver Download
THE HP SOFTWARE IS AVAILABLE THROUGH YOUR OPERATING SYSTEM. ON WINDOWS CLICKSTART AND THEN SELECT THE WINDOWS FAX AND SCAN ICON.
Software: Download optionsand information Description: clip_image002.png This software installs a copy of the help files onto your computer. Install this software if you did not install from the CD or if you did not install the full featured version of the software. Do not install this software if the help files for the HP PSC 1315 are already installed on your computer.
To see if the help files are already installed on your computer, check the following destination:
Windows XP: On the Windows taskbar, click Start, click All Programs, point to HP, click PSC All-In-One 1310 series, and then click Help.
Windows Vista: On the Windows taskbar, click the Windows icon, click All Programs, point to HP, click PSC All-In-One 1310 series, and then click Help. Details andspecifications File name: clip_image002.png MaggiMinus_Installer_24Nov08.exe [1/1, 24.91M] System requirements: clip_image002.png No additional prerequisites Released: clip_image002.png 2008-12-04 Version: clip_image002.png 1.1 Compatibility: clip_image002.png Microsoft Windows Vista, Microsoft Windows Vista (64-bit), Microsoft Windows XP 64-Bit Edition, Microsoft Windows XP Fix/Enhancement: clip_image002.png Updated the file to make the help files available from the Windows Start menu after installation is complete.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-66177-3&lc=en&dlc=en&cc=us&os=228&product=374568&sw_lang=&key=null&site=null
Apr 13, 2011 | Computers & Internet
My windows xp can't find my epson stylus nx125 printer driver
You can get them from EPSON website and install them:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=150186&prodoid=63088088&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=20&y=10
Just choose what youi want, a complete (40MB), or Driver only (8MB)
Drivers and Utilities Combo Package
Windows 7 32-bit Edition, Windows Vista 32-bit Edition, Windows XP
epson13804.exe - 40.9MB - posted on 09/15/10
This file contains everything you need to use your Epson Stylus NX125 and NX127 with Windows XP, Vista 32-bit and 7 32-bit.
This combo package consists of the following items:
  • Printer Driver v6.72
  • Scanner Driver v3.770
  • Epson Status Monitor 3
  • Event Manager 2.40
Driver only:
epson13802.exe - 7.9MB - posted on 09/15/10
This file contains the Epson Stylus NX125 and NX127 Printer Driver v6.72. The Epson Status Monitor 3 is incorporated into this driver.
Please leave rating if it helps.
Jan 20, 2011 | Office Equipment & Supplies
I need the software disc for my HP F 300 any sugestions
HP Deskjet F300 has F340 and F380 series printer which uses the same software.
Click on the link below and select the operating system to download the software.
Choose 32-Bit Operating system drivers from the list ( ex. Windows XP 32 bit )
Run the file once you have downloaded to start the installation.
Download Drivers
To know more about installation procedure,
For Vista Installation Instructions - Click here
For XP Installation Instructions - Click here
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 16, 2010 | Office Equipment & Supplies
I lost my installation cd
Download Drivers
Dec 16, 2010 | HP Deskjet F340 All-In-One Printer
Windows 7 drivers for minolta magicolor 2300dl?
Two Minolta 2300DL windows 7 64-bit solutions(choose oneoption): 1) Download the XP 64-bit driver and extract to a folder: ftp://ftp.minolta-qms.com/pub/crc/out_going/windows/2300d_64b.exe then Control Panel>Devices and Printers>Add aprinter> Add a local printer>choose USB printer port>select the "HaveDisk" button(do not select a printer) and browse navigate to where you savedthe XP 64-bit driver "MLUU_DRV.inf" driver file which installs and worksfine. Only issue is now have a 3 minutewait delay for each print job using the universal driver compared to no delaywhen printing with XP. OR 2) Follow the Vista USB port(not network) install guide butstill use the XP 64-bit driver. ftp://ftp.minolta-qms.com/pub/crc/out_going/manuals/misc/km_vista_instruct.pdf 3) 32-bit option use the Vista 32-bit driver first as thatshould work.
Nov 06, 2009 | Konica Minolta magicolor 2300DL Laser...
HP CP3525DN Color LaserJet Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
