Question about D-Link DI 514 Wireless Router (DI-514)
D-Link DI-514 2.4 GHZ Wireless Router
I have Comcast internet the cable from the internet is connected to the router and from there I have two computers connected to the router. The first computer is working fine but on the second one I am getting this error W32Time NtpClient. Time Provider NtpClient event ID 17 and 21. I check the time on the computer and it shows the correct time. the Local Area Connection show that the speed(100.0 Mbps and the status: Connected). I have switched the Cat5 cables, reset the router, reset the comcast internet. When I do a ipconfig /all I get an ip address from the router. I have manually tried different TIME providers and still no luck.
De Guyver
  • 123 Answers
SOURCE: WEP Encryption
It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption. Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead. Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen. Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key. Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption. 64-bit encryption 10 characters 128-bit encryption 26 characters 256-bit encryption 58 characters (available on DI-614+ only) The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key). Step 5 Click on the Apply button then click on the Continue button to save your settings. Note: If using non-D-Link adapters, please refer to the manufacturer´s documentation on enabling encryption.
Posted on Feb 16, 2006
De Guyver
  • 123 Answers
sandrew
  • 2961 Answers
SOURCE: Unable to detect my router
This is because your router is setting your pc at a different IP address than your original modem. Make sure router is set to enable DHCP which gives out an automatic ip address and check your wireless card and network cards are set to obtain ip address automatically. It may take a few re-starts to get on the internet as your systems will need to clear their previous DNS settings. Also i assume you have set up the home network wizard (XP) as you are now using a router and not a direct modem. Also try Start>Run, then type ipconfig /flushdns then press enter.
Posted on Dec 30, 2006
sandrew
  • 2961 Answers
SOURCE: Help connecting Cable Internet through D-Link DI-514 Router
what may be happening is the wireless pc as it was; needs the dns and ip address flushing, also the pc you connected the router to as you must have conflicting ip addreses Click start run then type ipconfig /flushdns. You should ensure that the router is set to enable DHCP to assign ip addreses and make sure your'e network cards on all pc's are set to obtain ip address automaticaly in the TCP/IP properties. Restart the pcs and type 192.168.0.1 in your web browser and get into your router setings and check in the DHCP section that all pc's have been given an ip address. If all fails you may need to reset the router
Posted on Sep 03, 2007
AlmostBob
  • 550 Answers
SOURCE: D-link problem
connect to the routers configuration web page at http://192.168.0.1 from the working pc
at the wireless settings
ensure wireless is turned on, is probably off if not previously used
read the security WEP WPA settings and copy them to the settings page on the ipod
Posted on Jul 16, 2008
I have a d link d1 514 router. I'm unable to open 192.168.0.1. if i put the internet connection wire in LAN then I'm able to get internet access using cable but if i put the wire in wan, I'm not getting...
carry out the resetting of the dlink router
then use lan cable to gain access to dlink router,
set up the internet conenction (i.e. your internet provider modem plugged into the dlink router also)
if it has a built in wizard then just follow the on screen instructions
you will need to define SSID (wireless network name) and passkey (password for the wireless connection)
and the your done. disconnect the laptop from wired connection and connect via wireless
Oct 16, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Can not connect to the internet using my DLink 514 wireles router
May be the wifi modem drivier is not installed properly. check it using device management
Apr 19, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Wont connect to internet
I might advise you to reconfigure the DI-514 Wireless Router, Access the IP address 192.168.0.1 using the Internet browser and configure as Dynamic IP address. You got a red light because the router is not configure yet or no Internet connection from your provider.
Mar 21, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
MY INTERNET WAS DONE AND CALLED COMCAST TO RESTART AND THEY TOLD ME IT WAS MY ROUTER THAT NEEDED TO BE RESET, THEY TRIED TO RESET, AND THERE IS A CONNECTION THERE BUT NOT WITH THE ROUTER HOW CAN I FIX THIS
Hi
Connect the modem and the router. Make sure the cable from the modem goes to the internet port in the router.
Reset the modem.Resetting the modem can be done by using a paper clip and insert it to the reset hole found on the back of the modem. Restart your router and systems.
Check if this resolves your issue. Post your results.
Thank you
rakesh
Dell Laptop Expert
Jan 07, 2009 | D-Link DI 514 Wireless Router (DI-514)
Other computer won't connect wirelessly
Comcast is apparently weeding out multiple connections through routers. They want you to pay extra for their wireless router and pay an extra $5 a month too.
Jul 30, 2008 | D-Link DI 514 Wireless Router (DI-514)
D-link problem
Jul 16, 2008 | D-Link DI 514 Wireless Router (DI-514)
Current dlink basic want to use dling DI 514
If you want to use your former router, you just have to connect the previous router in between your modem and computer. Try turning off all the devices (modem, router and computer) for 2 minutes. Then turn on the modem first, wait for the lights to be stable then turn on the router. When the router lights are okay that is the time that you can turn on the computer and check the internet connection.
If the Internet connection still has not come back, you will have to reconfigure it for Comcast connection. You can try using the setup CD or access the setup wizard using 192.168.0.1. User name is admin and leave the password empty then run the wizard.
May 05, 2008 | D-Link DI 514 Wireless Router (DI-514)
D-Link 614 Plus
You need to do some reconfiguration on your router by using the setup cd or by manually configuring it using the user interface of the router.
Apr 05, 2008 | D-Link DI 514 Wireless Router (DI-514)
Connection Issue ~ D-Link DI 514
Connect to your router, then on the computer click start/run, type CMD at the >, type ipconfig /release, then ipconfig /renew this will reset all ip address from your computer through your router to your modem. this should fix the problem. BPCS
Dec 30, 2007 | D-Link DI 514 Wireless Router (DI-514)
Belkin wireless g router 2,4 ghz 802,11 g
Whats the model number of this Belkin router?
Oct 16, 2007 | D-Link DI 514 Wireless Router (DI-514)
D-Link DI 514 Wireless Router (DI-514) Logo
66 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
