Question about SanDisk Sansa m230 MP3 Player
M230 well my m230 won't turn on,and when it does it turns off quickly then turns on and again off.Whats wrong with it?
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 27, 2008
Turns over but won't start
change the crankshaft position sensor thats whats wrong with it.
Jan 27, 2013 | 1997 Isuzu Hombre
I have a Magnavox 15' HDTV monitor and it won't turn on, when I push the on switch on it turns green and a split second later it turns yellow. whats wrong?
This is typical when there is no communication with video card. Test on another PC. Re-seat video card on PC. Use VGA cable instead of HDMI or DVI. Make sure monitor is correct mode. Again VGA, DVI, or HDMI, depending on cable used.
Aug 27, 2012 | Philips Magnavox Computers & Internet
Sony blinking codes
If i remember correctly ten blinks means a high voltage error.
The only thing you could try is unplugging the power cord then plug it back in and try turning on the tv. If it still won't turn on try unplugging the power cord for five hours or longer and try again. If it still won't turn on it would be best to find a local repair shop that works on sony tv's and have them repair it for you.
Mar 01, 2012 | Sony Grand WEGA KDP-51WS550 51" Rear...
Rumbly groan with turns at low speeds esp just beginning to move car Dealer just repalced entire rack and pinion and sway bar. no noise first day- today heard noise again
My esp light, all wheel drive light, traction light and abs lights have come on & won't go off. Tried everything I could think of. Tires are new, brakes are a little over 2 years old. Recently tires rotated. Maintenance done regularly . Whats wrong?
Mar 26, 2010 | 2007 Chrysler Pacifica FWD New Cars
Sansa MP3 player. songs won't show up
How can I delete songs from my model m230 so I can replace with other songs?
Mar 13, 2008 | SanDisk Sansa m230 MP3 Player
Turn
Feb 18, 2008 | SanDisk Sansa m230 MP3 Player
My mp3 player doesn't work
My Mp3 dosn't work when i turn it on it says updating and when i put it on the charger it tells me instalzing i don't know what to do please help me.
Nov 27, 2006 | SanDisk Sansa m230 MP3 Player
San Disk Sansa m 230 512 MB
Your problem is probably beacause you accidently deleted "AudibleActivation.sys" from your "Audible"-folder. Format the sansa and then use "reset to factory settings" to make the file appear again. It might be a good idea to make a backup on your hard drive, just in case, and make the file hidden.
Oct 31, 2006 | SanDisk Sansa m230 MP3 Player
M230 big problem
Remove the battery from the player. Enable the hold switch and connect the player to the computer. Right-click on My Computer and choose Manage. Click on disk management if the player is listed there right click it and choose format. This will erase all the songs on the player. If the player is not listed there try another usb port. If all else fails try calling sandisk to see if there are other steps they could provide.
Sep 25, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
150 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
