Canon ir 2018 error code e808 - Office Equipment & Supplies
  • 66 Answers
SOURCE: my canon ir 1018 displays this error code e808 and does not print
has the machine been serviced recently? if not, unplug machine for 10 mins, then plug back in. if the code comes back the fuser assembly will need to be replaced.
Posted on Apr 13, 2009
iservice
  • 318 Answers
SOURCE: where is the waste cartridge for the canon ir 2018
If you open the front cover and release the leaver of the drum unit.Remove the drum unit.On the drum itself is a plastic plug,remove the plastic plug and remove the waste toner in to a bin.The waste toner is stored behind the drum and must be removed reguarly.
Posted on Dec 15, 2009
Cogz
  • 1326 Answers
SOURCE: Error code : E 604 of Canon IR 400
It means that you are having a problem with the hard drive boot up program... You will need to replace the hard drive.
Posted on Mar 02, 2010
  • 6 Answers
SOURCE: canon IR 2018 system error E007
E007 means that the fuser film inside the Fuser unit is damaged which needs to be replaced, or the white patch on the fuser film is dirty and it just needs to be cleaned. I recommend getting a canon technician to fix it,
Posted on Jun 01, 2010
hamzaskilltd
  • 316 Answers
SOURCE: error e-261
zero cross signal error
Posted on Jun 12, 2010
I have Canon iR 2016 it show E808 code error
That error is related with the fixing unit. Check the connectors or replace the fixing film assy
Mar 25, 2015 | Canon IR2016J
Give solution for canon ir 5050 error code e808-02
See here.
http://www.copytechnet.com/forums/canon/53715-ir5075-e808-002-a.html
Jun 19, 2014 | Canon ImageRUNNER 3570 Copier/Printer
How to reset e808 error code
This error due to your red wire at fixing unit out of position,put back and switch on the macine and the error automatically cleared
Mar 03, 2014 | Canon iR 2016i Black and White Copier
System error 007 for canon ir 2018
this is error for fixing film rotation. There is no reset code, you need to replace fixing film in fixing unit, Fixing unit is located under left sideway door above drum unit ( green roller ).
Call service!
Aug 26, 2011 | Canon iR 2016i Black and White Copier
I have Canon iR 2020 it show E808 code error
conon ir2020i can not innitiallise asking to switch off and on the main power switch
Jan 06, 2011 | Canon iR 2016i Black and White Copier
Error 001, error 808
the e001 code is something is going with the fixing assembly. one of the thermistors could be going bad.
E808 is a Zero Cross error. We most commonly see power supplies or bad wall voltage cause this code.
The following information is coppied from the IR2016 Service Manual.
E808-0000 DRIVE CIRCUIT FAILURE
A zero crossing signal cannot be detected.
A fixing drive motor failure has been detected.
E808 0000 Fixing drive circuit failure
  • The heater does not turn on.
  • A fixing drive motor failure was detected.
  • Check the connector of the fixing film unit.
  • Replace the fixing film unit.
  • Replace the fixing drive motor.
  • Replace the DC controller PCB.
  • Replace the power supply PCB.
M201 - Fixing Drive Motor - FK2-1067 - J202 on the DC controller PCB - E007, E808
Power Supply - FK2-1074
Jun 14, 2010 | Canon iR 2016i Black and White Copier
i have canon Ir2016 it give 808 error code can u help me please
May 29, 2010 | Canon iR 2016i Black and White Copier
My canon ir 1018 displays this error code e808 and does not print
Apr 13, 2009 | Canon imageRUNNER 1023iF Black and White...
k24674
jasbo
jasbo
