Question about Blaupunkt America SR04 SIRIUS Radio Receiver
Display no longer works
The display on my receiver is no longer working. One day it was there, the next day it wasn't. It is all black. Blaupunkt will not fix it. They told us to throw it out but I purchased a lifetime subscription to Sirius and the receiver is no longer under warrenty.
0 characters
1 Points
How do you open the Delphi SA10034 CD/MP3/FM boom box.
The boom box doesn't work or the XM receiver doesn't work?
Jun 03, 2014 | Delphi Home Satellite Radios
No Display
Sounds to me like the display went bad on you. I'm not too sure your those though.
Jul 10, 2007 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
Backlite display on JVC sirius radio stopped working?
Typical Sirius junk - overheats and display goes out. Buy a new XM Onyx Plus radio instead.
Dec 28, 2012 | JVC KT-SR2000 SIRIUS Radio Receiver
Tuner will not work to scroll stations
Press the up/down button, then DISPLAY to show what item you want to see (Song Title / Artist / Channel Name). Also, there are settings under MENU for your display options as well. Go to the MENU Settings to set how you want to see your display. Okay? Let me know if you need more help. John
Sep 27, 2010 | Delphi SKYFi3 XM Radio Receiver
XM radio overheats
The radio if it does not work in the car too. You can turn off the back light it may help it cool down press "menu" go to Display light hit select set it to 10 sec. press select again and try it
Feb 24, 2009 | Delphi Roady XT XM Radio Receiver
White screen
I had the same problem with my Pioneer Inno Gex-Inno2BK XM radio receiver. One evening while leaving work, I gently took it out of the cradle & the screen suddenly went completely blank & all white. I could still hear music but there was no screen visible. Solution is this: (1) Gently remove the back cover which covers the battery. (2) Gently remove the dark blue square battery which is only about 1 inch (width) by 3/4 inch (height) by 1/4 of an inch in thickness. I removed mine by holding the receiver upside down & gently shaking it with one hand until the battery came out into my other hand. After about 4 or 5 gentle shakes, it came out. (3) Wait about 10 seconds. (4) Place battery back into XM radio receiver being careful to line the copper power receptable on the battery with a corresponding surface inside the receiver. Each copper area is only about 1/10 of an inch by 1/10 of an inch. Use this as a guide when putting the battery back in to make sure it's lined up properly. (5) Gently slide the cover back in place & let it snap into place. (6) Turn receiver back on by pushing power button like normal. (7) XM receiver should boot up with a full display just like new. All recorded songs are still in place. Nothing has been lost. Problem solved. Root cause of problem is probably some type of boot-up issue with the receiver in which the battery (i.e., the power supply) just happened to be slightly ajar...which also persisted even when placing the receiver back in the cradle until the above steps were taken. The steps above worked beautifully for me...Hope it works for you as well! Have A Great Day...Tom Armstrong
Jan 19, 2009 | Pioneer inno2 Portable XM Satellite Radio...
Cracked display
Sure, you can do this if you have great soldering skills. The contacts are very small and requiring precision soldering, but a successful soldering job would make for a successful repair. There is nothing specific about the displays so any display from a sportster 4 would work on any other. Have a great day!
Jan 10, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Sound on SR04 fades in and out.
I have the same unit and it has a faulty antenna connection, it is too lose. Not sure what to do about it but obviously not a good purchase.
Jan 03, 2008 | Blaupunkt America SR04 SIRIUS Radio...
Intermittant display of song title and artist
I believe it's actually a firmware issue with the SIR-KEN1. I havethe same setup and have the same exact problem. I have to cycle thru my "SRC" button and get back to Sirius for it to work. Not a happy camper. I read on the Sirius Backstage forums about the firmware, although I have written Directed Electronics (SIR-KEN1 manufacturer) and never received a response.
Nov 12, 2006 | Kenwood SIR-KEN1 SIRIUS Radio Receiver
Blaupunkt America SR04 SIRIUS Radio Receiver Logo
32 people viewed this question
Top Blaupunkt Home Satellite Radios Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Home Satellite Radio Expert? Answer questions, earn points and help others
