Question about Elo 17' LCD MONITOR, TOUCHSCREEN, 1280 X 1024, 250 CD/M, 450:1 => Model 1725L D66140-001
Elo 17" LCD Touch screen ET1725L Powers off after 1 second
I have an Elo ET1725L touch screen that I bought used from ebay.
Because I already have another of the same model, the drivers, etc are already installed on my computer and work fine.
This monitor powers up, shows windows and then powers down about 1 sec later. If I wait about 15 seconds, I can power it up for another second before it shuts down.
Does anyone have any ideas if this is fixable and how?
Thanks,
Wake
Your problem lies ion either your back light inverter or in the backlight tubes ( bulbs) which are embedded in the LCD display. The display has 4 ccf tubes inside of it that provide the backlighting. if any of these tubes are bad the backlight inverter will shut off after about 1 second. Because there are 4 of these tubes inside the screen you may not notice ( brightness wise) if 1 of them is out.
You can buy another backlight inverter( about $70.00 US) however, from my experience that would be a waste of money. Unfortunately, I think your problem probably lies in your LCD and the backlight tubes are not replaceable.
Hope this helps all who have this problem.
Good luck
Jim
Posted on Jun 25, 2009
I have a problem with the ET1725L-7CWF-1-G touch screen rom ETOL. The problem started as it powers up for seconds and then shuts down. I sent it previously to a test center to be checked and they said that...
you need to replace your power supply! asap!!! check the voltage coming from the ac adapter to verify the correct voltage!! please vote and rate this post!!! thanks
Dec 02, 2010 | Elo 17' LCD MONITOR, TOUCHSCREEN, 1280 X...
I have the same issue with a 1515L Monitor. It comes on for a split second and goes off? or picture goes away. Picture looks fine at all resolutions and touch screen is working also.
jcleary916, You or qualified electronics technician will need to find out why "cold-cathode-fluorescent-lamps" fail to sustain output of white light that enables you to see what is on the LCD panel. CCFL inverter supply probably needs work on it. Do some reading in my and other fixya lcd monitor tech'e profiles. You will be amazed that so many other owners of ALL brands of CCFL back-lit monitors have YOUR exact same symptom as your's does. And then think about all the other owners who don't find their way to fixya for an answer!!! Keep in touch by doing another comment to this one after you do some reading. Then let me know what you are willing to do about your BLACK or BLANK n BLACK CCFL back-lit LCD monitor and how old it is!!! 12fixlouie
Mar 14, 2010 | Elotouch 17" LCD Monitor
Elo ET1725L with no video. Flash on screen on
When LCD's "turn on" momentarily before going blank again it is an indication that the backlights have worn out. Cold Cathode Floursecent Lamps (CCFL's) have a limited amount of hours which they can be in operation for before the mercury vapor in them breaks down (or leaks out). When that happens the backlights no longer look like a load the inverter (device inside the monitor which turns low voltage into high voltage) is programmed to look for, and long story short, the inverter does not keep the lamps illuminated because of this being a safety setting, if the load no longer looks like what the inverter is looking for, it could be sustaining an open arc which then leads to extremely high temperatures, and a possible fire. The flash you see is the "firing voltage" (I think that is what it is referred to in the industry) which is a very high voltage pulse used to create the arc between cathodes in the CCFL, creating the arc takes a much higher voltage than sustaining the arc, so even if the inverter successfully creates the arc and lights the cathodes, it quickly doesn't look like a proper load and then inverter quickly turns off to prevent damage.
In essence CCFL's are usually the weakest link in LCD monitors as far as what is most prone to failure, technology has been improving, but if you keep your monitor on all day long at full brightness, never shutting it down, don't expect more than 3 years out of it :( Some brilliant LCD manufacturers recognize this problem and even make the backlights replaceable!! What a novel concept!!! But due to price gouging, the replacement backlights are usually sold for a premium from resellers, better option than the majority of LCD displays which have the backlights so integrated that you end up destroying the LCD and introducing contaminates in the process of "reviving" the display...
Your best bet if the backlights are in fact shot, is, if you are handy with a soldering iron, get the LCD apart, get out the backlights (there are probably four in there, possibly 6) measure the diameter and length, and look on eBay to see if someone is selling the particular CCFL you need-- that may be the cheapest route if you are out of warranty...
Jul 14, 2009 | Elo Entuitive 1725L-MSR (Dark Gray) 17 in....
Elo Touch Screen wont stay on!!
Hoya
I spoke with ELO techsupport and they said that I have a bad backlight inverter. I am looking for replacement parts. Have you found anything? If not, would you be interested in selling your USB controller unit from your monitor? Wake
Jul 08, 2008 | Elotouch 17" LCD Monitor
Broken Elo Monitor Screen
Touch screens are even more expensive that straight LCD panels. This repair may cost more than the original monitor. Why do you need another panel? Is the panel cracked or is the touch screen portion not working correctly?
Dan
Mar 28, 2008 | Computers & Internet
Blank screen
elo touch screen ET1925L -7SWA1 i get no picture on the screen but i hear sounds coming ou the back of theespeakers.. could it be the inverter?? help
Oct 24, 2007 | Elotouch 17" LCD Monitor
How to adjust sensitivity on ELO Touch Screen monitors
you probably have a capacitive screen, it only responds to finger press. You need a resistive screen to be able to respond to finger, nail, or pen press.
Aug 28, 2007 | Elo 15" Touch Monitor
Computers & Internet Logo
1,924 people viewed this question
Top Elo Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Sam DeGonia
Level 1 Expert
afiza begum
afiza begum
Are you an Elo Computer and Internet Expert? Answer questions, earn points and help others
