Question about DeLonghi DNC 60 Dehumidifier
I bought a dnc65 dehumidifier and when I turn it in it gives me an alarm light
Our dehumidifier seems to be working fine but the orange light is flashing above the star mark
When an error occurs, the Alarm lamp flashes orange. Check the status of the lamps, then take the appropriate action in Alarm Lamp Flashes or ON Lamp and Alarm Lamp Flash Alternately.
Jan 10, 2017 | Dehumidifiers
I have a DeLonghi DNC65 dessicant dehumidifier about 4years ol. It runs for about 2-3minutes then the alarm light comes on and then it switches off. It is operating in a room which is 15 deg. C. Is this...
Ignore the first comment, Desiccant dehumidifiers do not have Freon, or a compressor...
The warning light coming on after a few minutes could be one of a few things (but probably most likely due to overheating or the detection of something not right in the unit operation. Most likely faults include:
1) failure of main fan motor (this would cause eventual overheat)
2) failure of heater blower motor (this would cause an overheat)
3) clogged desiccant wheel (restricting air flow and causing overheat)
Generally the warning lights only come on if an overheat occurs, If the heater has failed these units usually continue to run, albeit cold, and with no water being extracted.
Another culprit could be the water level cut of switch being faulty.
Feb 05, 2014 | Dehumidifiers
I bought a model 365 remington dehumidifier. I plugged it in and nothing lights up. I have it plugged in for the past 8 to 10m hous and still nothing. Should i be seeing the blue light up ?
Two things that you need to check: Make sure that the outlet the dehumidifier is plugged int, is in fact working. The circuit breaker for that outlet may be tripped or there may be a loose or damaged wire connection to the one of the outlet's terminals. I assume you are turning the Master ON/OFF Switch to ON of the dehumidifier, after you plugged the unit in and set the humidity extraction level below 40%?
Jun 27, 2011 | Remington Model 365 Dehumidifier
Will not run or turn on light will not turn on
Had a similar problem with Goldstar model DH305. A solution was already posted about cutting the two white wire going to humidity control, and it works until tray fills up (no control). However, if you want a complete fix which allows you to control by selecting humidity level go to the following site:
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=282871&modelsID=&typeName=dehumidifier
Part number is 6877A30013L
May 27, 2009 | Goldstar DH304 Dehumidifier
Dehumidifier not collecting moisture
Normal 0 When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
Jan 31, 2009 | Kenmore 54501 Dehumidifier
Control panel lights up-nothing else happens
first check that the bucket is in properly. then remove bucket and push red button with finger with the unit on. if you are still getting a red alarm light it might be time to change the control panel. also unit does not work the same in cold weather. it will cycle too often. unit better used in summer-------good luck
Dec 16, 2007 | Kenmore 5365 Dehumidifier
DeLonghi DNC 60 Dehumidifier Logo
65 people viewed this question
Top DeLonghi Dehumidifiers Experts
Mike Kolbay
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
