Question about Iomega ULTRAMAX 1TB TRIPLE INTERFACE FireWire 400 (1394a) Hard Drive
Change hard drive iomega ultramax
Which kind of internal hard drives (ata/sata/???) can be put inside the iomega ultramax 1TB enclosure to replace the existing hard drives?
5 Suggested Answers
  • 97 Answers
SOURCE: Can't mount my external Iomega harddisk anymore
Try running disk utility. If it can see the hard disk but it isn't mounting it, try clicking "repair" or if that is greyed out, "verify" then "repair". Be warned that this could take a very long time, so leave it over night. It may even look like it has crashed. This may either fix the problem, or tell you that the drive can't be repaired (in the data sense) and it will hopefully mount it read-only so you can retrieve the data. You will need another drive with enough space to copy everything off. If copying data fails, try copying folder by folder or even file by file to get off all files that are ok, as otherwise it will just give up when it finds corrupt data.
If disk utility cannot see the hard disk at all, try the other interfaces (usb/firewire/sata). If it can't see it in any of them, try it on another computer. If none of them can read it then the unit is dead. You may be able to retrieve your data by taking the unit apart, removing the hard disk, and placing it in another enclosure. This will probably void your guarantee though, so it's a choice you may have to make :(
Posted on Oct 27, 2009
  • 825 Answers
SOURCE: my iomega 1tb is "read
Any Hard drives before getting to used with MAC OsX has to be formatted according to the MAC file system...
I think that is the problem you are facing...
Make sure your hard disk is not formatted for any windows OS and try to reformat for MAC OsX...
It should work...
Posted on Dec 09, 2010
  • 80 Answers
SOURCE: HI... Can I clone my
http://www.runtime.org/driveimage-xml.htm this program will allow you to clone your hard drive directly to your external, you can then expand the partition using 'disk management' which can be found typing it into the 'run' window from the start menu. this will erase the external drive however and i wouldnt recommend booting from it externally.
Posted on Feb 25, 2011
nicklemarr
  • 296 Answers
SOURCE: I have an Iomega UltraMax 1TB Triple Interface
It depends on the physical size of the drive.
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=92&name=External-Enclosures
On the left there is a size filter. Pick one of those that suits your use.
Posted on Mar 21, 2011
Testimonial: "This is very helpful - thanks!"
I have an iomega 31868500 external hard drive I haven't used in years. I now want to use it to store files from my wife's Toshiba laptop running Windows 7.
Hi Jack
It would be pointless having a hard drive fixed to Read Only.
I don't think there is a switch setting to set as Read Only.
The original Iomega (early days) removable cartridge drives had a plastic tab on the cartridge to allow it to be write protected (RO).
So perhaps the Iomega Enclosure (Interface electronics inside) is getting out of date.
The oldest part of your drive will be the Enclosure & USB port.
I would suggest you open the enclosure and take out the actual hard drive. Should still be good to use.
Drives are either 2.5" or 3.5" Size Standard.
Eg Pocket drives are 2.5" size, Slower operation as they use 5 volt only. One bump during use can kill them!
3.5" use 5v & 12v & spin much faster (3500 to 7200rpm) for high speed transfer. Eg Movie Streaming / Fast Backups and are more robust.
The internal connector will either be the older IDE / ATA type connector Or
The new universal SATA connector (serial ATA much smaller)
You will need to determine this.....
The Fix:
The most convenient enclosure these days would be a DOCK type that allows you to plug in both 2.5 & 3.5 SATA drives. AND use USB 3 as a faster Future Proof Hard Drive
Then you can plug one in for Movies and another for Music and a third for Backups. Each drive purchased separately.
Eg 3x 1TB should be cheaper than 3 separate enclosed drives.
I'm sure there is a dual DOCK also for the older ATA connector.
But all future Drives will be SATA.
Once you determine what connector your drive uses then you can plug it in to the more modern housing and format the drive for Windows NTFS or FAT32 (Windows & Mac & TV's)
Cheers
Good Luck
EG: SATA
Amazon com ezDISK EZ0330 USB3 0 hard drive docking station support SATA II...
https://en.wikipedia.org/wiki/Serial_ATA
IDE Connector / Adapter
Vantec CB ISATAU2 SATA IDE to USB 2 0 Adapter Supports 2 5 Inch 3 5 Inch 5...
Amazon com SATA PATA IDE Drive to USB 2 0 Adapter Converter Cable for 2 5... Serial ATA Wikipedia the free encyclopedia
Connector
Parallel ATA Wikipedia the free encyclopedia
Bare Hard Drives: SATA & IDE
They all work on Windows or Mac (After Formatting)
Search Results for Western Digital hard drives at MacSales com
Feb 23, 2016 | Toshiba Computers & Internet
Where can one buy a replacement pcb control board for a iomega 'ultramax plus' unit? My existing one has a damaged IC component at 'U4'....and possibly more elsewhere on the board.
No one sells what you're looking for. I'm assuming the drives were in a raid configuration which means you can't put them in an enclosure to get the data off. Your best bet is to purchase another unit and replace the drives. This thing is hella expensive. If you don't need the data you can get a different one bigger and cheaper. http://www.sears.com/iomega-33991-esata-firewire-800-firewire-400-usb-2.0-500gb/p-00389575000P
Oct 16, 2012 | Iomega 500GB Ultramax HD USB 2.0/FW 500 GB...
My Iomega Ultramax external hard drive continues has only one problem. This problem occurs every time I plug it into my computers. The hard drive at random times, disconnects itself without being told to....
It sounds like it is losing contact in the USB cable connecting it. If you have another USB cable, I would advise you to try it instead, it could be a problem with the cable. If the cable is not the issue, clean off the contacts in both the USB ports of the computer and the external hard drive itself to make sure there is nothing disrupting contact. Should this fail, it may be a faulty USB driver board in the enclosure, in which case you can contact Iomega and find out if this is a known issue. A cheap fix should the driver board be the issue would be to buy another enclosure and transfer the drive into the new enclosure. Enclosures can be purchased for under 20$. Should even a new enclosure not work, the logic board on the drive itself is malfunctioning and Iomega should be notified and will hopefully offer you a replacement.
May 05, 2011 | Iomega UltraMax 500 GB USB Hard Drive
I have an Iomega UltraMax 1TB Triple Interface External Hard Drive and have been told that the case/enclosure is dead, but that the hard discs inside are fine. Would it be easy to put them in a new case?...
Mar 21, 2011 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
Iomega UltraMax 1TB Triple Interface won't start
I would go on the web interface of the device. Find the IP address of the device and enter it into your browser. Maybe it has a setting for 'sleep' mode. Also, on rare occasions, the power adapter can go bad on them unexpectedly, not your fault, just a bad batch of hardware.
Feb 24, 2018 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
Iomega ULTRAMAX 1TB TRIPLE INTERFACE FireWire 400 (1394a) Hard Drive Logo
359 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
