Where can I find a Servis M6702 washing machine manual?
FitzOriginal
  • 842 Answers
SOURCE: Servis Washing machine clothes wet
I don't know the specific machine, but this is a fairly generic problem, so I hope the following helps: The empty pump cycle is a timed operation, the fact that there is still water in the drum after the time allowed for the pump to drain it has run out means that the water isn't clearing out fast enough.
In order of probability, the problem is usually caused by:
1. A blocked filter
2. An obstruction in the empty pipe or drain
3. A Faulty pump
1 Blocked Filter: Many machines have a small door in the bottom of the chassis. Behind this door (Usually about 5 inches square) is a filter, which will usually unscrew. In this filter you will find fluff, string, coins, the odd small sock and all sorts of nasty stuff if you haven't had the filter out before. If the filter is blocked then the pump is having to draw water through all that gunk and it will run out of time and leave water in the drum. Clean the filter in the sink, pocket the coins you find and make a note to clean it regularly in the future Most manufactures will suggest you check it every 2 months or so, depends how often you are using the machine of course.
Unfortunately, other machines do not have filters so easily accessible. If there is no door or obvious access to the filter, some manufacturers put a trap in the rubber hose that feeds the pump. The pain here is that the access to these traps is gained by dragging the bachine out of its place under the work surface and tipping it on to its back. Track the waste pipe back to locate the pump. On the other side of the pump will be a thicker (usually black rubber) pipe and built into this pipe is usually a little bucket that stuff can fall into before it gets to the pump. You can usually squeeze the pipe and feel if there is stuff in it. If there is, then depending on the machine again, some of these traps will have a plug in the bottom that is held in place by a spring clip (Pliers to compress the spring to get it off) or a screw clip (Unscrew with a screwdriver). Enev if there is no trap as such, squeeze the rubber delivery pipe and feel for obstructions (Often a sock!), if necessary, disconnect the pipe from the pump to gain access to the blockage. WARNING!: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, to the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend butting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
2. An obstruction in the empty pipe or drain: Start at the point that the pipe enters the household drain pipe, pull out the empty pipe and check that water will flow freely into the drain (Stuffing the garden hose down there and turning it on (but not TOO FAST) will usually demonstrate if there is a blockage. If this is free, check the pipe that runs from the pump to the drain (This will need the machine tipping as described above, and possibly the pipe removing from the pump to check it.
3. A Faulty Pump:If you have done everything described so far, then you have checked for obstructions in the pipe leading to the pump, the pipe leading away and you have cleaned out any filters or traps... If you still have a problem, you have a faulty pump. This is highly unlikely. These pumps have induction motors (no brushes to fail) and in my experience, they either work, or they don't. They very seldom "work a bit". If SOME water is being pumped (check by putting the empty hose in the sink and watching) then you really need to double check your work before replacing the pump. Good news is, if you do have to they are usually reasonably priced.
Posted on Feb 09, 2009
SOURCE: how to get the washing machine manual for Servis
Go to PartStore.com or sears.com parts.
Posted on Oct 02, 2009
  • 6 Answers
SOURCE: manual for Servis 1100 rpm washing machine
Hello, try eManualOnline.com or contact the old factory direct
Servis UK PO Box 14, Darlaston Road, Wednesbury, West Midlands, WS10 7TJ
Posted on Jul 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: I am looking for a user manual for a Servis wahicg
CLICK HERE
http://www.miaudioaddiction.com/fixya/manual.pdf
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Posted on Sep 16, 2010
  • 6277 Answers
SOURCE: Servis 1100 rpm manual needed Moved
You will need to type into your search engine/web browser '(make) washer manual' and you might be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
(I have just typed in 'servis 1100 manual' and there are a number of sites from which to select))
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Apr 18, 2011
Fitting door catch Servis Rainwave 900 washing machine
You might want to post this question in the washing machine section so the proper experts will see it..
Aug 19, 2012 | YouTube Videos
Servis 1100 rpm manual needed Moved in into a new house with a Servis 1100 rpm washing machine but there is no manual; As the company Servis does not exist anymore - where can I get a manual...
John C.
Apr 18, 2011 | Washing Machines
Manual for Servis 1100 rpm washing machine
Jul 17, 2010 | Washing Machines
I need a manual for Servis M6012W washing machine
I did not have a dishwasher, as my question says I wanted a Manual for a washing Machine.
Jan 15, 2010 | Servis Dishwashers
My servis easi logic 1400 doesnt switch over in cycle.
Check the control card for dry joints. This is a common problem with these machines
Jul 04, 2009 | Washing Machines
I need instruction manual for servis m6723w
if theres 4 buttons on facia they are from left to right pre wash extra rinse spin cancel and start depending on which button is flashing you may have a problem if the dial is at 12 oclock and the start button is flashing set the dial to any program and the light should stop flashing if it does not you will need a new board for it and it will need resetting with a servis hand set as servis are now no longer you may have a problem... hope this helps
Jun 26, 2009 | Washing Machines
CLICK HERE
Apr 04, 2009 | Washing Machines
Washing Machines Logo
67 people viewed this question
Top Washing Machines Experts
