Question about Garmin GPS
How do I load maps of Crete on my garmin gpsmap 62 please
I have tried mapinstall on my apple mac & it does not work
SOURCE: Garmin is stuck at loading maps
I had a 200 W Nuvi with the same problem. Luckily it happened with the first 3 months, so i could return it to Garmin under warranty for a free replacement
Posted on Jun 20, 2008
jonniewalker
  • 1029 Answers
SOURCE: how to load maps from google to garmin
This solution works for more than the 760. i think it will work for all 6xx and 7xx series.
a simple solution to convert Google maps to Garmin routes and is found here:
http://www.elsewhere.org/journal/gmaptogpx/
In essence, you create your route in Google maps and then click the recommended url bookmark.
Save the GPX file to the Garmin device and from "My Data" (under Tools) convert the file to a route. You are done.
hope this helps pls appreciate by rating as fixyaa thanks
Posted on Nov 23, 2008
SOURCE: Garmin GPSmap 76 not acquiring satellites
You need to do an auto locate. This also corrects your time issues (wrong date and/or time will be corrected. To do an auto locate do the following.
  1. Start with the unit turned off.
  2. If you have a GPSMAP 76, GPSMAP 76C, or GPSMAP 76S, hold down the Page button. If you have a GPSMAP 76CSx or GPSMAP 76Cx, hold down the Zoom Out button.
  3. While holding down the first button (Page or Zoom Out), press and hold the Power button.
  4. Continue to hold the two buttons until the Satellite page displays. You can then then let go of the buttons.
  5. Finally, let the unit sit outside with a clear view of the sky. Allow about 20-40 minutes for the unit to acquire satellites.
Posted on Nov 24, 2008
reef runner
  • 7 Answers
I had the same problem? GPSmap76S was hung up trying to AutoLocate. It just couldn’t find itself, and it just stopped working all of a sudden one day, while I was traveling. I spoke with Garmin about the problem, and they advised me of an ongoing problem with WAAS. I was told that I should "Disable" WAAS, because the signal from the WAAS satellites had been changed by the government, and Garmin had not yet put out a software update to address the problem, on the 76 units, anyway. Also said that an update "should" come out, in the future, however, no commitment or promise on that. Evidently, once your unit hits one of the WAAS signals, it scrambles up the receiver in the GPS, because mine sure went crazy. The support guy also said, that if this did not correct the problem, I might also want to try a "Master Reset". So here’s what happened.
I disabled WAAS, but this did not correct the problem. The unit was still lost out there somewhere, trying to AutoLocate, so I ended up doing the “Master Reset”. Please read up on this procedure before trying it, and understand that you “will loose” any settings that you might have made to the GPS, along with all waypoints, routes, tracks, etc., however, my maps actually remained in tact? This procedure will actually set the unit back, just as it was when it originally came from the factory. Once completed, you will then have to allow the unit to initialize it's self again, just as you did when the unit was new. If you have forgotten about doing that, it simply means that you need to set the unit outdoors and leave it “on” for a while (15 – 20 minutes), until it actually AutoLocates it’s self, or locks in on your current position. Once this is done, re-do your setting preferences, back to the way you had them before the Master Reset. At the very least, you’ll have to re-set it to the correct time zone, and tell it about daylight savings time. Note: It’s a very good idea to go thru first, and jot down your page settings and main menu settings, before doing this procedure, or the screens may not look familiar to you, once the unit resets. You think you’ll remember them all, but you won’t. But whatever, once you have done the “Reset” and “Initialization”, you must now hook the GPS up to the computer and reload your waypoints, routes, etc, back to the GPS. You did have them saved on your computer, didn’t you? Hope so… If so, you should now be good to go…………….
My unit now works like a champ, good as new, just not as accurate, due to WAAS being turned off. I still don't know if the WAAS issue, was part of the problem or not, but I do know that the Master Reset got the unit back to working immediately, allowing it to locate itself almost instantly. What a relief…………..it’s a little work, but it takes much less time than it took you to read this post…………..
Hey, when all else fails, call Garmin 1-800-800-1020. They are good guys and willing to help, in fact, I would advise you to call them before you do anything, so you can describe to them, exactly what your unit is doing. I am only relating my situation and what happened to me. Your situation may be different…….
Posted on Dec 13, 2008
  • 4090 Answers
SOURCE: POS Garmin Streetpilot C330.... HELP REQUESTED!
I think this one is a return to seller or send to Garmin.
Posted on Jul 06, 2009
Compass will not caibrate
Garmin GPSMAP 62 - Initial Setup - Calibrate Compass ...
? 7:27
https://www.youtube.com/watch?v=OG7uVh2kQ24
Nov 9, 2010 - Uploaded by Jim Cyr
have owend 3 garmins. will be using handheld for biking. this looks like fast map ... Anyways, your review was decent, just don't know if I like garmin (possibly not). .... Compare Garmin GPSMap 62S vs Garmin GPSMap 60Csx ...
How to Reset the Garmin GPSMap 62 Series Handheld ...
? 1:23
https://www.youtube.com/watch?v=v-M7Ev6YTcA
Jul 20, 2012 - Uploaded by GPSCity
GPS City will show you how to RESET your Garmin 62 series GPS back to factory default settings. Back up all ... -My GPSMap 62s will not track satellites! -Forgot what ... -My barometric altimeter will not work or calibrate.
[PDF]GPSMAP® 62 series - Garmin
static.garmin.com/pumac/GPSMAP62_QSM_EN.pdf
Jan 04, 2016 | Garmin Gpsmap62s Hand Held Gps
How do I install maps on my GPS?
First you need to have Mapinstall app on your computer
Once MapInstall is installed, to load maps:
  1. Connect the Garmin device to the computer
  2. Open the MapInstall program
    • MapInstall appears in the Start menu or Start screen on Windows
    • MapInstall appears in the Applications folder on a Mac
  3. Select the device or SD card
    • If all compatible map products installed on the computer will fit completely on the selected device, MapInstall will give options to Send Maps (Mac)/Continue (Windows) or Customize
      • Send Maps/Continue will send all the maps that will fit on the device
      • Customize will allow the selection of individual map products
      • Advanced/Partial Install will allow sections of the map products to be sent without sending the whole map product
    • If all map products installed on the computer will not fit completely on the selected device, MapInstall will give the option to Continue
      • This will allow the selection of individual map products
      • Advanced/Partial Install will allow the selection of individual sections of the map products
    • If loading the map to a SD card or an older Garmin device, MapInstall will give the option to Continue
      • MapInstall will allow the selection of individual sections of the map products - similar to the Advanced/Partial Install option
  4. Click Send Maps (Mac) / Continue (Windows)
  5. Click Confirm (Mac) / Install (Windows)
  6. Click Done (Mac) / Finish (Windows)1
May 21, 2015 | GPS
Where do i go to down load update for my gps 295. garmin said thay dont support this unit. thanks joe
Joe,
The Garmin "GPSMap 295" is at, as far as Garmin is concerned anyway, "end of life". This means Garmin will no longer support, repair, etc. this product. C'est la vie.
Garmin's older product lines lack the hardware to decompress the new "NT" (New Technology) maps that Navtek (the map company) is producing now. The NT maps are compressed so that they would fit on smaller capacity memory cards. By doing this, the maps required Garmin to include hardware (special designed circuitry) that could quickly decompress these maps "on the fly" for display. The much of Garmin's older GPSMap & StreetPilot lines predate this hardware requirement.
Our "still-functioning" GPSMap & StreetPilot GPSr will still pinpoint our location on the Earth as always - but lack the latest & greatest maps. You should review the maps that your GPSr can use and choose the one you prefer. I switched mine to display topographical maps. These show many of the road names like the City Navigator maps do, but lack important things like the POIs and routing. If you can do without them, this could be good enough. If you can't, you'll need to decide on whether the last non-NT map version is sufficient or purchase a new GPS that can accept the maps you want to put into it.
I hope this helps and good luck!
Sep 06, 2011 | Garmin GPSMAP 295 GPS Receiver
Gps has lost its maps, screen says can't unlock maps
There several reasons you may receive the message Can't Unlock Maps on your nuvi or zumo device.
  • Can you press OK and get to the Where To/View map screen?
  • Did you load maps to the unit using the MapSource or MapInstall program?
  • Did you load maps to an SD data card?
If one of the points above applies to you, please follow the steps below to clear the Can't Unlock Maps message:
  1. Remove SD card from unit, if applicable.
  2. Plug the unit into your computer with a compatible USB cable.
  3. Open MyComputer/Computer icon. (Mac users skip this step.)
  4. Right-Click on the Garmin drive and select Open. (Mac users can locate the Garmin drive mounted on the Desktop.)
  5. Open the Garmin folder.1
  6. Locate a file named gmapsupp.img
  7. Right-Click and delete file named gmapsupp.img
  8. Safely disconnect your unit from your computer to see if the Can't Unlock Maps message is gone.
1. Nuvi 1100/1200/1300/1400/1600/3700 and Zumo 665 users will open the Map folder instead.
*If the gmapsupp.img file does not appear in the Garmin folder, please create an unlock file for device.
Nov 28, 2010 | Garmin Nuvi 265W GPS Receiver
Jul 05, 2009 | Garmin StreetPilot C330 GPS Receiver
How do upload updated maps to my garmin660
go on garmin, connect your gps via usb , get map install program and you should be fine, works on any operating system
http://www8.garmin.com/support/mappingsw.jsp
Jul 01, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 200w can't update all 49 lower states
OK, I just finally am getting through all of this myself.
First, the bad news. You cannot load all of the lower 49 states onto your Garmin 200W as-is. The map file is over 1GB and the 200W only has 991MBs of memory.
So, go out and get yourself a SD card. I got a 2GB card at OfficeDepot for $8. It was at the counter, not back with the other cards they carry (Note: The speed showed as 60x. The slightly more expensive ones, $12-$15, may be faster, like 150x.)
You'll also need to get yourself MapInstall, available from the Garmin site. BUT, don't try to use this right away, a mistake I made. If you do, you basically get a message that MapInstall can't be installed because it's not already installed. Seriously.
BUT, MapInstall GETS installed, or whatever, when you load your 2010 maps (or partial maps), so after you do your partial install, THEN you can install the MapInstall program. (May not be necessary, but remember, I did this out of order. Look for a "Garmin" folder under your Programs, or All Programs, and see if it's already there after you install your 2010 maps.)
Next, run MapInstall. The next mistake I made was that at the window where it finds your device, I clicked on the NEXT button. DON'T. Notice that your device is shown in a drop-down box. Click on that, and you can select your SD card for the destination.
THEN click NEXT. On my system, it appears as if it shows you what IS already on the 200W, and lets you select whatever you want to add. I put everything else available on the SD card.
I just this minute finished loading "the rest" and checked it out. Works flawlessly. I easily found a seafood restaraunt in Anchorage (Alaska was not loaded in the intitial install.)
Just remember that you have to keep the SD card in the Garmin at all times to use those maps. That really shouldn't be a problem though.
Hope this helps eveyone.
JDCrownover
Huntsville, AL
Apr 29, 2009 | Garmin nuvi 200W GPS Receiver
Tide station
please verify if firmware of your receiver is up to date.
the newest version of GPSMAP 76CSx is Ver. 3.60, realised on Feb 18, 2008
if not, make upgrade either by WebUpdater application or download it direct from www.garmin.com
enter: www.garmin.com
then click "On the Trail" -> Mapping Handhelds -> GPSMap 76CSx -> quick links: Updates&Downloads -> Unit Software
regards
frankie
May 19, 2008 | Garmin GPSMAP 76Cx GPS Receiver
Have problems with the loading of the map XPC415S. Australia East coast. Will this map work with this unit?
Any bluechart that has been preloaded on an SD card should work.  Did you purchase your chip with the data preloaded or did you download it yourself?  If you downloaded it yourself, try erasing the sd card, format it, then insert the blank card in the 420 and power it up. This somehow preps the chip for the data download.  Then download the bluechart onto the chip and try again.  There is some ambiguous wording in the download screen that makes it look like some kind of error, try the download anyway and most of the time it will work. After the download is complete it should list the bluechart software version on the screen along with some other software info.  If the operating system software is not v2.5 or higher, you may need to download a software update first.
Oct 25, 2007 | Garmin GPSMAP 420s GPS Receiver
GPS Logo
93 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
