Question about SanDisk Sansa c200 MP3 Player
My computer isn't detecting my Sansa mp3 player anymore.
I plug my mp3 player into the USB and before, the computer would do 2 chimes and my hardware would be detected. I could then put songs on my mp3 player. But now, I plug it in and it does 3 chimes all on the same note and nothing happens.
  • 1 more comment
  • Emily Ryan
    Emily Ryan Nov 19, 2008
    My computer wont reconze it, and it will say connected wen plugged in but it wont actually charge
  • krvram Nov 24, 2008
  • Anonymous Apr 26, 2009
    I did the above direction and it still reports that the device has malfunctioned. I suspect the Sansa bit the dust. It won't turn off at all. Can't do anything with it. Just says "Connected" whether it's plugged in or not. I won't buy another one, this didn't even last 2 years.
  • 8,596 Answers
First, make sure the lock switch isn't engaged.
Try this: disconnect the player from the computer, turn it off, hold in the volume + (or Record) button, and reconnect the player to the computer while holding the volume + (or Record) button in. Keep holding the volume + (or Record) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start --> Control Panel-->System--> Hardware--> Device Manager (you computer may vary slightly, depending on Windows Version).
-Tha Mp3 Doctor
Posted on Feb 28, 2009
My pc window can not recognize mp3 player
Hello
Connect your Sansa MP3 player to more than one USB port on your computer. Ensure that your computer USB port is not corrupt or disabled by testing at least two available ports. This is especially useful when you possess no other USB-based equipment.
Inspect your USB ports' status to ensure they are enabled on your computer. Right-click "My Computer" and launch "Properties" to verify the availability of such connections. Select "Device Manager" from the Hardware tab and click the "Universal Serial Bus Controllers" from the list shown. If a red "X" is shown, the USB ports are disabled.
Ensure your computer is updated by clicking "Start" and launching "Windows Update" from the Programs menu. Alternatively, inspect your USB port connectivity through your motherboard BIOS settings. Note that BIOS access and settings varies by mother board manufacturer.
Scan your computer for new hardware changes. From the Device manager, click the "Action" menu and select "Scan for hardware changes" while your Sansa MP3 player is connected. Allow your computer to attempt to find any physical component recently added in the event it failed to previously detect it.
Connect your Sansa player to a different computer. Test the connection on a different system's USB port to verify that the Sansa device's own connection has not been damaged. Inspect the USB ports on the computer in question as well to eliminate the possibility of both systems having problematic USB ports.
Change your Sansa MP3 player's USB plug. Sometimes the head of the plug may lose contact with the appropriate circuits. Obtain a secondary USB port at your local retail store and test it on an updated computer system.
Nov 14, 2010 | SanDisk Sansa e250 MP3 Player
My computer is not reading it
hello
Inspect your USB ports' status to ensure they are enabled on your computer. Right-click "My Computer" and launch "Properties" to verify the availability of such connections. Select "Device Manager" from the Hardware tab and click the "Universal Serial Bus Controllers" from the list shown. If a red "X" is shown, the USB ports are disabled. Ensure your computer is updated by clicking "Start" and launching "Windows Update" from the Programs menu. Alternatively, inspect your USB port connectivity through your motherboard BIOS settings. Note that BIOS access and settings varies by mother board manufacturer.
Oct 01, 2010 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e250 MP3 Player with Mac? Is there any driver to make it compatible with Mac platform? Thank you
NOTE: MAC computers do NOT support MTP modes of USB conectivity in a MP player. A Sansa player in MTP mode when plugged into a MAC computer will NOT be detected or recognized. MAC computers supports Sansa players in MSC mode Sansa players can only be recognized by a MAC if the USB mode on the Sansa player is set to Auto Detect or MSC.
Check in the System Profiler Open System Profiler from the Utilities folder, which is inside the Applications folder. From the Contents column on the left, under the Hardware header, select USB; the panel to the right will show all the USB devices that the computer recognizes. It may not identify them correctly by name, but it should have the right number of devices listed. . Navigate to USB Mode settings. Sansa View - From the Main Menu, select More > Settings/Options > System Settings > USB Mode.
Sansa Fuze and Sansa Clip+ - From the Main Menu, select Settings > System Settings > USB Mode.
Sansa Clip, e200v1 series, e200v2 series and e200R - From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC. e200R - PlayforSure is MTP and Rhapsody is MSC
See this tip posted here on this site for a better explanation on the modes - MTP and MSC. Solve your MP3 Player Connection Problem.
Feb 05, 2010 | SanDisk Sansa e250 MP3 Player
Sansa m240 files won't show up on computer
Uninstall/remove the mp3 player from the device manager of windows while its plugged into you computer and unplug afterwards from your usb port and plug it back in, windows now sees a new device and starts installing it.
Go to the configuration panel\system and click at the tab hardware and klik at the button device manager.
This should solve the problem.
Succes.
Aug 31, 2009 | SanDisk Sansa m240 MP3 Player
When i plug my sansa media convertor(mp3 player) into the computer it takes forever to load and then it says no device inserted
hello
this is a hardware problem maybe your mp3 will not oscillate thats why you cant get detect or USB recognize in to pc..
Angel
Thanks...
Jul 31, 2009 | SanDisk Sansa e260 MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
check for up dates to the software for your mp3 and also make sure you have the right software for the make and model of the computer meaning is it a xp, vista or windows 98 .
windows xp should detect new hardware auotmatically. you could delete the software and remove the hard ware for your mp-3 player and try to reinstall it.
Dec 01, 2008 | SanDisk Sansa m240 MP3 Player
WONT DELETE!!!!
first you have to turn your sansa on and go to the setting and then you have to go to usb mode and ptu it on "mtp"
then plug it back up to your computer and this time when you plug it up the computer will start detecting it and when add song use your windows media player
Mar 05, 2008 | SanDisk Sansa e250 MP3 Player
My computer wont detect my e200
Dont turn it on and plug it in. That had happened to me and that fixed it.
Aug 31, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
493 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
