Error code E1 carrier i-power inverter model 42CIV012308
5 Suggested Answers
  • 3 Answers
SOURCE: Have a ge model ASW12ALS1 Air conditioner with error code E1
I have a G.E. window air conditioner that kept giving me the E1 error code and would not allow the unit to turn on. After much frustration (and no results from following various tips on internet forums) I decided that I had nothing to lose by taking the thing apart. After all, it was way past the warranty period.
Make sure the unit is unplugged before doing any of the following.
When I took off the cover (not the front grill, but the metal cover over all the internal parts) I found a small black envelope stuck to the top of the styrofoam inside the unit. What an inconvenient place to find what the error codes mean! It obviously means they don't want the average customer to know any of this. "E1" means a short or open circuit, unit inoperable.
With that in mind I noticed that the black two conductor sensor wire was broken. This is the wire that leads from the sensor on the front fins to the control circuit board. After soldering it back together and wrapping it well with electrical tape the unit works perfectly.
If you don't wish to try soldering the wire, it can be unplugged from the circuit board. I would not be surprised if you can order a new sensor (with wire and plug attached) from a G.E. parts supplier.
By the way, this particular G.E. 6100 BTU air conditioner was manufactured by Samsung electronics.
Posted on Jul 03, 2009
richroth
  • 9472 Answers
SOURCE: I have a 4 zone
What is your model number of your unit?
Posted on Aug 17, 2011
  • 334 Answers
SOURCE: carrier Comfort zone 2 is flashing e1 after a storm/power outage
HEY THERE, DID YOU TRY POER CYCLING THE UNIT? TURN IT OFF AT THE BREAKER THEN BACK ON
SETH
Posted on Jun 27, 2009
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Fix error code E1-F1 on kenmore oven...model-95802000
That us usually a fatal error of the control board unfortunately. the control may need replacing.
Sep 17, 2014 | Kenmore Kitchen Ranges
How to fix Carrier E3 split type Model: 42CIV012308
Your question is to vague. What are the problems, list here and then some one will get a better idea of a solution
Apr 30, 2014 | Carrier Heating & Cooling
E1 message on my LG Inverter Direct Drive Dishwasher
An F1 usually means a communication error between the control board/touchpad and the motor/pump assy. Could you please supply the full model # for your unit?
Mar 12, 2014 | LG Dishwashers
Carrier Air Conditioning error code 5
Carrier A/C split Model # 38KCL112313GP has error code E1 What is that?
Aug 09, 2009 | Carrier Heating & Cooling
Carrier Comfort zone 2 is flashing e1 after a storm/power outage
SETH
Jun 27, 2009 | Carrier 38CKC060 Air Conditioner
Error code on air conditioner e1
Search for this problem on web or contact Sharp Technical Support for the following procedure:
1. Unplug unit.
2. Hold down power button while plugging in unit. It will do a short self-test and then beep. leaving unit off.
3. Release power button and unplug.
4. Plug in again and turn on normally. This should last for about 720 hours, at which point the E1 error will come back and you need to follow the procedure again. (You might as well clean the air filter at this point just in case it really needed it...)
Jun 09, 2008 | Heating & Cooling
Heating & Cooling Logo
1,118 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
