Question about Hitachi 53UDX10B 53" Rear Projection Television
Hitachi tv magic focus does not work
Colors do not line up on the screen. After running magic focus I notice it shows a number 5 in the lower right corner of the screen.
  • Anonymous Oct 29, 2008
    ewcept my color is Blue
  • clouse03 Nov 04, 2008
    I have the same thing, with the green appearing to dip in the upper left corner, when I run the magic focus, I get the number 3, any ideas on if this is fixable. We went ahead and bought a plasma, but would like to keep this tv for our basement play area for the kids......
    Novelist:
    Champion:
  • 203 Answers
Your problem is the convergence circuit. This is very common in CRT projection sets like yours. There are a couple of IC's that need to be changed and possibly some resistors. A good repair shop will run you $400-$500 to do the repair.
Posted on Oct 28, 2008
I have a 65 inch Hitachi projection TV and all of a sudden lines apperaed on the screen that runs across the upper part of screen. I tried using the"Magic Focus" setting to get rid of these lines...
The tv Magic Focus button don't solved these R,G,B colors lines mis alignments problems.Mean ur tv have a convergence pictures problems,it is dead.Ur tv now have any colors lines like R,G,B mis alignments,have a colors shadows picture or a 3D pictures look alike?Yes,mean ur tv convergence board it is dead to causes all of these pictures problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 24, 2011 | Hitachi 65S500 65" HDTV-Ready Rear...
My TV is the Hitachi model 51UWX20B and tried using magic focus to line up red color. Picture looks like 3D with red off center. When using magic focus it gets to the red phase and it shows the number 5...
You need to replace the STK ICs which are Convergence ICs STK392-110 use 120s or 150s
also check the small ohm resistors around ICs . They are Big Black ICs and will have part number on them ,should be located on the Right hand side of Chassis .
Mats Eletronics has Parts 1-800-628-1118 Convergence IC Kit.
Jul 04, 2011 | Hitachi 51UWX20B 51" Rear Projection...
I HAVE A HITACHI 53WX10B TV AND THE SCREEN IS BLURRED. I HAVE TRIED THE MAGIC FOCUS BUTTON AND THE SHARPNESS BUTTON. ANY OTHER IDEAS?
Magic focus button don't work or datas never reaches 100%.Tv have a problems,known as a convergence problems,it dead.Tv have colors lines R,G,B mis alingments,have colors shadows pictures or a 3D pictures look alike?The tv have a dead convergence board.The tv convergence board have 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence pictures problems.The shop,will cost like $300-350 for parts and labors.
Dec 04, 2010 | Hitachi 53SWX10B 53" Rear Projection...
Goes through magic focus than in the middle stops and displays #5
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 19, 2010 | Hitachi 46F500 46" Rear Projection...
Magic focus error Hitachi 52
The model number you have selected here does not have magic focus--if you really want a answer post the correct model number.
SD TECH
Dec 12, 2009 | Hitachi 52LDX99B 52" Rear Projection...
43fdx15b Hitachi 42in red vertical lines magic focus inop for red
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors.Shops usually charge from $200-$300
Sep 26, 2009 | Hitachi Televison & Video
Hitachi 51G500 big screen rear projection tv
Is this a new television? Under warranty? You need a service call.
Aug 07, 2008 | Hitachi 51G500 51" Rear Projection...
Hitachi 46f500 convergence?
a common problem wich i also have with convergence with blue and red convergence.
the image converge amplifiers are burnet out wich in turn blow out resisters that control individual color convergence.
Jun 19, 2008 | Hitachi 46F500 46" Rear Projection...
Hitachi 46f500 screen messed up after welding on same circuit
If you did manual conv. You have to redo it when you replace the bad parts. Them being conv. ic's replace them and check 1/4 watt resistors that are low value right beneath amps. Careful not to solder any foil pads together or you will have major problems. Very common for do-it-yourselfers. Good luck, Russmann.
Jun 15, 2008 | Hitachi 46F500 46" Rear Projection...
Hitachi 43VWX10B Rear Projection Television - color adjustment problem
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Dec 25, 2007 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
827 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
