Where can I get a replacement lamp for a OPMI Pentero in the UK?
I have inherited a OPMI Pentero and am trying to establish the manufacturers code for the replacement lamps. Any ideas?
  • 4234 Answers
SOURCE: Projection lamp nearing end of life replace lamp still coming on
Along with the instructions for the lamp installation, you should have revceived instructions on how to reset the lamp counter. If not, this operation is listed in the owner's manual. If you can not locate that manual, please confirm your model number and I will post the instructions. Since the counter has not been reset, the TV will continue to show the "error" message.
Dan
Posted on Mar 09, 2009
  • 4 Answers
SOURCE: Samsung SP50L6HX, I replaced the Lamp but still nothing.
Hi, Samsung haves a known issue with the ballast, once you make a replacement of the lamp, sometimes its harder to ignite a new lamp that has 100% of gas inside than igniting a old lamp that has maybe 60% or 50% of gas inside. Just in order to ignite the lamp, the ballast needs to send some High Pulses of Voltage, as high as 15 kV (that is the constant clicking sound that you are hearing). In order to resolve this you need to change the Ballast Board. I tried to look for your ballast with your TV Model # at samsungparts.com , but nothing showed up. You will need to find out which ballast part # you have in order to find it online. To locate the ballast part # please check the end of this video, you only need to take the lower back cover of TV off. http://www.youtube.com/watch?v=0jr_9A5Xd2Q
Here is a link of a ballast I found http://www.discount-merchant.com/SAMSUNG-9137-008-08905-Lamp-Ballast-Driver-p/1138231.htm?Click=49915
Posted on Dec 24, 2009
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi 52525 TV Red Lamp LED
340v should be on power pwb plug PL on the 1 and
5 (GND) pins for the ballast. and the ballast plug CN should also have the 340V with pin 1 of that plug being GND nd pin 3 should have the 340V If the PL plug on the power board is low the power pwb has a problem most likely the doubler circuit. If CN plug voltage is high say 360V the ballast is suspect.
Posted on Jan 10, 2010
  • 50 Answers
SOURCE: LAMP REPLACE FOR PANASONIC PT-50DL54 INSTRUCTION
Pull off the panel below the screen.
Remove the two screws hold the 2nd cover from the left.
Remove one screw from the lamp module and pull it out.
Buy the lamp module. It is not worth it to try replacing the lamp. You can damage the bulb easily.
Posted on Mar 08, 2010
asnowman
  • 788 Answers
SOURCE: I have a panasonic DLP TV model PT56LC70 lamp is
Just to be sure, I looked at your Model Number and found a PT-56LCX70.
I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
The part number that I was able to find was LFS4000PA1EB.
But I would contact Panasonic about this problem, they have an 18 month warranty on the lamp product.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Posted on Mar 16, 2010
Mitsubishi Wd-73638 code 6 red 1 yellow not sure what that is please help
No error code 61 listed, only a 66 error code which indicates lamp issues:
66
A) Lamp did not turn on at P-ON sequence... Check CJ4 circuitry
B) No Lamp Inserted............... No Lamp inserted
C) Disconnected cable between ballast and lamp.... HV connection or lead wire to lamp.
D) Lamp-Enable goes to PWB-MAIN but not to Ballast....Lamp Cartridge Failure
for lamp see the following web site: http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73638
recommend using the manufacture part# as many replacements for Mitsubishi will not work.
May 08, 2015 | Mitsubishi Televison & Video
What kind of bulb do I need to replace the lamp? And where do I get it from?
If you consult your manual it will give you the detail required to order.
Try googling the description, www.espares.co.uk or indeed the manufacturers web site to find an authorised dealer.
Hope this helps.
Mar 15, 2011 | JVC Televison & Video
I bought a replacement lamp for my 3400mp dell projector and I cannot get the pin to seat in the receptical. My old lamp goes in and out like butter, no problems. When I try to put in the new lamp the...
Hi Patrick,
It sounds like you have a damaged or incorrectly supplied lamp. You have established that the old lamp can be fitted and removed easily. You should not need to do anything when fitting the replacement lamp that you did not need to do to remove the origional. Compare the two lamps side by side and see if you can spot any differences. Perhaps some careful measurements may help.
Lamps should have a part number which will be common on both lamps. Non OEM lamps are supplied in re-manufactured housings, the better ones (eg Diamond & Pro-Gen) use the original lamps which are either Phillips or Osram. Cheap copies use 3rd party lamps which are less effective at best.
I would advise being wary of the source of this lamp if it is not Dell.
Feb 14, 2011 | Dell 3400MP Multimedia Projector
Lamp Not Coming On
From what it sounds is you got a bad lamp and visioneer being a very old scanner would probably be hard to find a replacement lamp for this scanner.
Jun 29, 2009 | Visioneer 4400 Flatbed Scanner
I've got green spots on my Tv screen
Their is no more you can do.
You probaly waited too long. Your light engine may be damaged. If so, you need a new TV.
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Panasonic PT-52LCX66 Projection Television
Very loud buzz
(414) 762-8600
Established 1974
Mar 24, 2009 | Toshiba 52HM95 52" HDTV Projection...
Boiler Thermostat
In desperation, I trawled the internet and am pretty sure that these are manufactured by Drayton, either a Drayton Digistat +2 or Digistat +3
Try this page http://www.gasapplianceguide.co.uk/drayton_central_heating_controls.htm
Good Luck!
Iain
Oct 02, 2008 | Hardware & Accessories
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
Electro Med Services...
