Question about Sony DPP-FP35 Thermal Photo Printer
Print ribbon for sony FP35
I need ribbon for sony photo FP35 printer in Mumbai.
2 Suggested Answers
SOURCE: Printing only bottom half of picture.
I had the exact same issue with mine! I didn't manage to fix it, but I know exactly what the issue is. If you open the printer, you'll find a black rectangular box above where the film fits inside the printer. This black box is connected to the board above it, and is supposed to press down against the film, and then against the paper for it to print properly. There is a little bar above the rectangular box, and there should be two plastic pieces on both ends of this bar. The bar is also connected to the gears, and when the gears move the bar, the two plastic pieces coming off of the bar push the black box down. When I looked at mine, only one of the plastic pieces was doing its job; the other one was broken, and was sliding on the bar. Tried some super glue, wouldn't work. I suggest tossing it out like I did, unless it's still under warranty or you want to try fixing the plastic piece so the printer head gets pressed down all the way.
Posted on Jun 22, 2009
My 510s is having issues with printing. The print ribbon is sticking to the paper, thus tearing the ribbon and causing a paper jam.
Remove any slack in the ribbon by turning the ribbon-tightening knob, or reinstall the ribbon cartridge...
First Turn the printer off, open the printer cover and remove the jammed paper if paper is jammed..
***If you need any technical help on printer then you can reach at here
Jan 02, 2013 | Unknown Hiti P510s 6 Dye Sub Roll-type...
Jun 22, 2009 | Sony DPP-FP30 Thermal Photo Printer
Photo ribbon doesnt print black
You need to install the K-tool and even then the registration won't be super
May 05, 2009 | Teac P-55 Thermal Printer
Sony UP-DR150 4x6 "ribbon error"
The black spool of the ribbon has a built in chip, If that chip is damaged it renders the ribbon unuseable. Be very careful if you take out party used ribbons and re insert them later.
Dec 15, 2008 | Sony UPDR150 Thermal Photo Printer
Pebble 4 miss ribon setup from time to time
Sounds like a failed/failing ribbon sensor. Each color ribbon has an embedded RFID tag. The PC/driver requests the ribbon tag info from the printer, and sets the driver according to the reply (R3011-YMCKO, for example). The mono-chrome/black R2011 and R2211 ribbons don't have RFID tags. If the PC/driver requests the ribbon tag info, and gets a response of "none found", then the driver will be set for "K" ribbon.
This can also be a fault due to spotty communications with the PC - bad USB cord; USB port; printer logic board issues; etc. Try a different USB cord, port & a different PC to see if the problem will resolve. If not, then it seems the problem is with the printer itself.
May 02, 2017 | Evolis Dualys Thermal Card Printer
Scratch on print
Sounds like dust within the front compartment. Remove the ribbon AND the paper roll. Give the unit a blow out with compressed air. Also wipe the print head with an alchol wipe.
Jun 02, 2008 | Sony UPDR150 Thermal Photo Printer
Ribbon not moving out side
the ribbon have tension?
Feb 09, 2008 | Zebra Z4M Printer
Ribbon problem
is the ribbon new?, sometimes they have problems, if that one is alright, u need to send it to a repair centre, it must need to repalve the mainboard
Jan 04, 2007 | Olympus Camedia P-10 Thermal Photo Printer
Sony DPP-FP35 Thermal Photo Printer Logo
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
