SOURCE: Epson LQ-2180 continuous printing problem
An Emulation driver will fix everyones problem... Do this:
1. Click on "Start", then "Control Panel" and then "Printers and Faxes".
2. In the left hand column choose the option "Add Printer". The "Add Printer Wizard" comes up, click on "Next".
3. At the "Local or Network Printer" screen choose "Local" and remove the check from "Automatically Detect".
4. Click on "Next".
5. At the "Select Port" screen choose the appropriate port (usually LPT1: recommended printer port).
6. At the install printer software screen choose "Epson" under "Manufacturer" and LQ-1050 for the printer, then click "Next". If you wanted to install the Windows universal driver, choose "generic" under "Manufacturer" and choose "Text Only", then click "Next".
7. At the printer name screen choose "Next".
8. When asked if you would like the printer to be default make the appropriate selections and then click "Next".
9. Finally click on "Finish". You may need your Windows XP installation disk.
SOURCE: lq-2180 continous blinking
lq 2180 printer front pannel led's all are blinking after turning on the printer
SOURCE: EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
SOURCE: my printer EPSON LQ-2180 send me an error code "paper out"
Hi Soulen , This link is very interest and useful for your type of printer : http://files.support.epson.com/pdf/lq2180/lq2180pg.pdf
and also for driver open this link : http://www.driverstock.com/Epson-LQ-2180-driver-download/23-26-3157-53410/index.html
SOURCE: epson lq-2180 printer pause light continously on
if u use up tractor use down tractor or inverse the operation
coz your problem is in paper sensor in up or down printing
