Siemens E10-46 I cannot open the door. The machine is empty.
I've tried using the door pull but it won't budge.
  • 561 Answers
SOURCE: The program has finished long
usually this happens if the machine still has water in it. or is damaged
to manually open the machine it has to be done manaully from inside.
you should ask a sevice person the do this.
check if there is water in the machine, to remove water
open vent at bottom of machine and remove any water.
make sure you have container ready to catch water as there
maybe a lot. if not try running the spin cycle again this should run the pump
to remove any more water and not add any water.
I hope this was helpful.
Posted on May 23, 2011
Macmarkus
  • 2605 Answers
SOURCE: I've an Asko Front loader W600 bought in 2001.
Hi, welcome to FixYa.
I'll start by addressing the later part of your post first, and that is by saying I wouldn't run out and buy a new washer...not yet anyway.
You should be able to get the garments out of the washer by way of manually unlocking the door. The door can be opened manually, see below for instructions.
**Watch for lots of water if it hasn't drained though...see below for manually drain as well**
Usually if the door won't open it's due to the unit not draining sufficiently (this may explain the "shuddering" as well if pump has debris within it) or perhaps a fuse tripping, thus no power. Just to be thorough you should check the pump to insure the filter isn't clogged, in my opinion, or do you know where it is and how to check it ?
In the event the pump, filter or hose is clogged or obstructed, will prevent the door lock from releasing...potentially causing a fuse to trip.
This is by design, but it's easy to confirm or dismiss.
Check as follows...
Let me know if any of this isn't clear and I'll attempt to help you move forward by way of possibly emailing this info to you.
Once you've cleared the pump filter or ruled out it was indeed blocked or not, you can now pull the manual door lock release located in the same area.
i.e.
Once that has been done, I'd now check the fuses in both the washer as well as the dryer...if yours plugs into the dryer as most Asko do. To do so is as follows...
CHANGING THE FUSE
1. Remove the fuse holder insert with a screwdriver (1/4 turn).
2. Replace the fuse. (The fuse must be a 250V, 15amp slow-blow fuse.)
3. Fit the fuse holder insert with the fuse into the fuse holder.
Let me know how you make out. Thank you for choosing FixYa and good luck. Please take a moment to rate the info provided for you here today at FixYa.
Regards,
Macmarkus :)
Posted on May 31, 2011
Testimonial: "Thanks so much for your help. We'd been researching new Askos ... so you saved us a lot of money, even if it's just short term. We owe you a beer! B"
bunnydawg
  • 5158 Answers
SOURCE: My door won't open on
unplug the machine for about ten minutes and then try to open the door after you plug it in. If the plug is not easily accessable, locate the fuse in the fuse panel for it. i may add after you have interupted power to the machine, you may want to try opening the door then.
Posted on Jun 12, 2011
dcramer531
  • 1654 Answers
SOURCE: Asko W6021 washer. Our
There has been issues on this washer in the past when the saop drawer gets warped slightly and stick. In that case you have to manually pull the drawer open and you will also have a problem getting it back in if this is the case. Once you get it out check for warped plastic on the bottom and clean out any debris in the tracks of the drawer. You have made sure the child safety lock is not engaged correct? The red button has to be recessed so the drawer can open.
Posted on Jun 27, 2011
  • 403 Answers
SOURCE: The detergent draw won't pull in and out easy.
theres is probably soap inside the track where the drawer slides, just clean it out and you should be fine.
Posted on Jul 09, 2011
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
Tip
My panel won't come off, I've taken out all the screws but it's...
This advice is for Kenmore Elite, Whirlpool Duet and Maytag Epic model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Jul 26, 2011 | Washing Machines
Broke handle off of siemens TOP WD1200 champion, the settings are all in chinese and my clothes are locked inside. help?
This is a common and easily fixed problem. The door should NOT be opened after the wash is completed. You have to wait for AT LEAST 2 minutes to try the door, do not use force. There is a built in mechanism for most front loaders to delay the door opening, so be patient.
If you have used force you have already damaged the door lock, so replace. You are lucky if the door can be opened after the lock sign goes off - otherwise you just have to change the door lock.
Click if helped.
Mar 30, 2013 | Siemens Washing Machines
The door on my Hotpoint Washing Machine WT741 won't open even though the programme has ended. We've tried running the programme again and pumping out but still the door won't open.
The door latch may have broken. You can sometimes open the door from the inside. You will know the door latch is broken if the door handle is floppy. If the door handle is not floppy - then the issue is probably with the door interlock. This is the electronic part that prevents the door from being opened during and after the wash has finished.
Either way - you'll need to get the door open.
To do this, unplug the washing machine from the mains and then move it out from where it is. Tip the washing machine to a 45 degree angle. Don't tip it over 45 degrees as you may break internal parts.
You need two people to do this - one person hold the machine at 45 degrees angle, whilst the other person puts their hand up into the machine - you should be able to feel the door catch mechanism and depending on the model, open the door that way. Sometimes the manufacturer has helpfully put a manual release inside - and sometimes they don't.
If you aren't able to open the door using that method. Get a length of strong string and poke the middle section of the string into the gap between the washer door and the machine body - to the right of the door handle. Use a flat headed screw drive to push the string into the gap, all the way around the door, so that you end up with the two ends of the string on the left hand side of the door. Now have someone put the ends of the string whilst the other person pulls the door handle. If the string is pushed in far enough it will release the door latch and the door will open. It takes a bit of persistence to get it right.
Once you have the door opened you can usually replace either the interlock mechanism or the door latch itself. Parts are easily available online from sites like espares and yourspares.
Mar 29, 2013 | Washing Machines
2000 Chevy S10 passeger door won't open
Remove the door panel and inspect the latch rods for damage or broken retention clips. A video is below of how to remove the panel.
Nov 06, 2012 | 2000 Chevrolet S-10
Remove washing machine filter for cleaning: How do I remove the filter on my Bosch class iXX front load washing machine for cleaning? We can turn it 1/3 anticlockwise but it won't pull out.
Something must be jamming the filter. You will need to just keep working it. If you cannot get it to open, you will need to replace the whole assembly.
Nov 03, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Sampsung wf7708n6w1 door won't open!
Your door switch/lock is broken, you need to unplug the machine and remove the top, you can then reach down (tight space) and using a small screwdriver you can pry around the switch and get the door to open, you need to get a replacement door switch for the machine.
Leaning the machine back can make it easier to access the switch.
Mar 06, 2012 | Samsung Washing Machines
Dregdrawer Full
I read somewhere that there is a counter in the machine that when a certain amount of shots are done, the counter will reach its limit and tell you to empty the drawer, even if it's not full.
When I get the message I open the door, remove the drawer and it goes away once you replace it. Don't know why the machine would stop working though?
Apr 28, 2010 | Gaggia Titanium Espresso Machine
Washing Machines Logo
115 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
