Question about Xerox Office Equipment & Supplies
Fault 003-318 xerox
Unable to use copier due to this code
5 Suggested Answers
SOURCE: xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Posted on Oct 27, 2008
SOURCE: Fault/Error
shko thirre sidnin
Posted on Apr 02, 2009
njau
  • 15 Answers
SOURCE: we have a xerox docucolor 700 and we keep getting
check the belt hole sensor on the accumulator belt for contamination
Posted on Nov 16, 2009
  • 53 Answers
SOURCE: xerox 5225 fault code 010-320
that is a fuser overheat code suggest you have a techintion repair or replace the fuser
Posted on Jan 18, 2010
How to open micromex 103 sucraty ?
Hi, Try to follow these steps. Reset your Samsung galaxy S2 by going to: Menu Settings Reset Reset settings tick one the following Select all , sound , display, phone. You may also enter this code to hard reset your phone. Please note to do backups sa this will delete all your files saved. *2767*3855#.
Read more: I am unable to open my micromax x103 due to forget password. So, Help me to unlock my phones. Plz give me solution? - I am unable to open my micromax x103 due to forget password. So, Help me to unlock my phones. Plz give me solution :: Ask Me Fast at
Jun 22, 2015 | Office Equipment & Supplies
Brother error code dcp-j 125 unable to Init 50
hi good day! the printer is error 50 due to a paper or some sensor error.. open the printer, or dismantle, clean the sensor and wash the pump of water and change the waste pad of new absorber. locate the sensor under the pump, clean it of alcohol.
Mar 17, 2014 | Brother DCP 165C Compact Color Inkjet...
UNABLE TO PRINT 44 - BROTHER MFC-J6510DW
User guide http://download.brother.com/welcome/doc002835/cv_mfc6710dw_use_busr_lx7144001_b.pdf says either a mechanical problem or could be foreign object like paper clip or torn paper inside the machine. Open the scanner cover to check for that.
Oct 15, 2013 | Brother MFC 6490CW InkJet Printer
My brother DCP-165C clean unable 50 problem, i can not use my printer due to this problem, what am i gonna do' pls. help?
my brother DCP-165C clean unable 50 problem, i can not use my printer due to this problem, what am i gonna do' pls. help?
Feb 15, 2011 | Brother DCP 165C Compact Color Inkjet...
Canon MP830: Error Code 6A00
Sir,
I think there is a piece of torn paper lodged inside due to carriage is stuck, try to do manually moving the carriage and also blow some compressed air around hoping to clear any foreign objects. Opened top manually. Moved print heads to left. About one inch from the right wall on the floor of printer are two soft spongy rectangular pads sitting in two abutting small trays. With the end of a ballpoint pen, pulled the right tray toward the front of the printer and the whole assembly snapped into place.
Thanks Good Luck
Sep 14, 2009 | Canon PIXMA MP830 All-In-One InkJet...
PRINTING...
Have you unplugged the printer for a few minutes to clear the memory ?
Jan 21, 2009 | Brother Multi-Function Center MFC-240C...
F1-00 Code - How to clear?
Helloo, first check the connect between the sorter and the machine. You may have to push strongly for proper connection.
*** MAIN NOTE**** I have found info on the web that there is a claim you can file due to this issue.
Check connection first then search; clearing fault code F1-00. On the Sharp forum you will find info about claim.
Dec 08, 2008 | Office Equipment & Supplies
Unable to print and showing an 'unable to print 5A code
There are diffrent reasons for this error:
check, if something sticks in the machine (paper or metal clip)
The paperfeeder clutch gear is broken: check if the paper feeder works well.
The purge station has problems to do the cleaning jobs: gear broken or too much ink within the purge tubes.
Anyway, this problem is hard to handle for a novice due to so many diffrent reasons.
You should contact a service dealer and in case it is still in warranty let fix them.
Mar 06, 2008 | Brother MultiFunction Center MFC-440CN...
Unable to Change
which error? Will be helpful to know the error code. Reset the printer with hard power down, and disconnect the interface cable, after powering down.
Got Backup?
Feb 07, 2008 | Brother MFC-5440CN All-In-One InkJet...
Error code 07,010,43;19646
The printhead is stuck in the tilted position and is unable to tilt forward due to the print position.
Nov 30, 2007 | Xerox Phaser 8500/DN Printer
78 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
