Question about Electronics - Others
Sitronix keychain photo viewer
I have a Sitronix multimedia USB device, a small 1.8" photo viewer I'm trying to fix.
Need usb driver for sitronix keychain photo viewer
Please check the below link to download the drivers
http://www.fileheap.com/dbquery/1/sitronix+photo+keychain
THANKS....
With Regards......
Vaishu
Sep 26, 2010 | Computers & Internet
I dont have the instructions to use my Smartparts SP15PCP viewer
If it came with a USB connecter plug that in first.
then a small screen should come up saying that it is connected to mount M or whatever USB link you put it in.
if it dosn't, go to computer, click on Devices with removable storage and you pocket keychain should be one of them. then drag and drop the pictures you want into the file.
to unplug, go to the bottum right hand toolbar and click the green arrow, then select "saftey remove"
May 28, 2009 | SmartParts (DC-MM306ATG-VP) Digital Photo...
Installing coby digital keychain software
Start from scratch, uninstall everything and pretend your installing for first time:
1. have keychian unconnected from usb
2. install software
3. DONT RUN SOFTWARE YET
4. connect keychain to usb
5. on keychain select: USB update
6. Run software
7. well-ah, intelligence > poorly organized device - enjoy everyone
Dec 14, 2008 | Coby DP-5588 5.6-Inch (4:3) Clock &...
Copy DP-151 Photo Viewer software does not work.
You have to push the USB cable into the keychain until it pops. Push it in hard! I thought mine was all the way in because the keychain lit up, but it wasn't.
Jul 08, 2008 | Audio Players & Recorders
I have a coby dp-161 and cannot get the pictures to install.
We had the same problem and you won't believe how simple the actual fix was!!! When you plug the USB plug into the keychain device or whatever device you are using (in our case it was a keychain), make absolutely certain that the plug is pushed in all the way (it is tough to push in) until it actually clicks and all you see is the black part of the USB plug. Then try your software. It should work!!!
Jun 20, 2008 | RIM BlackBerry Pearl 8100
My digital photo keychain album
My instruction booklet says:
IMPORTANT: The keychain MUST be plugged in and in "update" mode in order for you to open the Photo Viewer progarm. If it is not plugged in, or is in the wrong mode, you will get the following error" No photo viewer is found, program terminated!
2. Once the keychain is plugged in and in "update" mode double click the Photo Viewer icon on your desktop to launch the application. (I wasn't able to double click the Photo Viewer icon at all, so I don't know what else to do). And for the rest of you that are able to double click it, I will give you the instructions.
3. Use Photo Viewer's file manager to browse photos on your computer.
4. Once you select a photo, it will show up in the crop marquee. Put the box over the area that you want to see on your keychain and click the POST button (arrow to the right). This will move your photos to the collection panel.
5. Delete any unwanted photos by selecting the image in the collection panel and clicking the X button from the menu bar.
6. Once you have all photos in the collection panel that you want on your keychain, click the "synchronized" button. At the bottom of your screen, you will see that the status has changed from "idle " to "download" and the black bar will show %complete.
7. Once the download is 100% complete and you get the following message, "photo viewer data synchronized complete", click OK, exit the progam and disconnect the keychain.
IMPORTANT: Do not disconnect the Digital Photo Keychain until the download is complete and you exit the photo viewer software.
Jan 14, 2008 | Digital Products Monaco Ezcolor Photo...
Photo keychain
If this is like my keychain photo viewer you need to put the keychain in USB update mode before it will work.  When you first plug it in to the USB port it will show USB Charge or USB Update. Use the arrow keys to put it in USB Update mode and then press the menu power button.
At this point you can open the software and start adding photos!
Dec 27, 2007 | Innovage LCD Touch Panel Phone
Innovage Digital Photo Album w Keychain driver
Summary of Solutions posted here and elsewhere:
I just received a Innovage Digital Photo Album Keychain as a gift and ran into some of the issues posted here. I am going to summarize the solutions I have come across in hopes they will help others.
Installing/obtaining the software:
The keychain requires you to use custom software to upload pictures. The keychain includes a mini-cd with the software. If you have a computer with a slot loading cd (i.e. laptop, imac, mac-mini, etc) do not try to put the CD into your computer, it may become stuck! Either call the service line and order a full size cd, or try downloading the software from either:
Coby DP-151 software
Digital Foci - Pocket Album software
(While these are different digital photo products, the transfer software appears to be same as the Innovate software)
The software should be installed before you plug in the keychain into your USB port.
Software Issues:
Some users have complained that they can't see the whole transfer window. You might have your screen resolution set too low (like 680x480 or 800x600) try increasing to 1024x768 or bigger.
Finding photos: The software is quite simple, it does not integrate with your photo software (e.g. iphoto) it simple reads image files. You will need to point the software to where your photos are stored on your computer. For most people this is either "My Pictures" or simply "Pictures" folder.
Transferring photos: There have been some recommendations to transfer the photos to the keychain in small batches (like 6-10) rather than queuing up 60 images to transfer all at once. Apparently the software has crashed on some peoples machines when transferring many images.
Device Issues:
Charging: The device has an internal battery, it must be charged via your computers USB port. In must be in the charge mode, it will not charge when it is in the update mode. When you first plug the device into your USB port a menu should come up on the screen. You can use the arrow buttons to change the selection, then press the power key to select your choice. For charging you should select "USB Charge". In this mode the keychain will display images and won't let you power off. The red light will supposedly turn green once the keychain is fully charged.
Transferring images:
The keychain must be in the "USB Update" mode before your software will talk with it. Try unplugging the keychain, plug it back in, wait for the menu, use the arrow keys to select "USB update", press the power button. Now try running your transfer software
Bad USB cables: Many people have reported that the supplied USB cable doesn't work. If you are having problems with charging or transferring images, first try another USB cable from a similar type device if you have one (many cameras have the same sized mini usb connectors)
Hope this helps someone!
Nov 30, 2007 | Baby Gear
Software--Innovage Digital Photo Keychain
found that on another site - after I had the same trouble - this software really works - updated the pic frame in no time :)
IT IS an easy fix...uninstall the Picture Viewer that you got from the Disc they gave...Throw it away. Go to www.mscustomercare.com at the top of the keychain section, it says "download".............. THIS version works.
Sep 30, 2007 | Cameras
Can run photoviewer program for photo keychain
Your computer will certainly have its own program for viewing photos. For example, if you are using Windows XP, you just right click on a photo file and choose "preview". It can be difficult to find the photos on your computer if you have been using one of the silly organizers that come with cameras. You can search for a photo if you know its filename or for *.jpg to find all the photos on your hard drive.
Sep 11, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Electronics - Others Logo
418 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
