Nashuatec 1805, error SC 322 - Office Equipment & Supplies
Bubbabear64
  • 2794 Answers
SOURCE: sc 322, sc 326 codes
Never heard of this happening to five machines before.  Check the connections in the laser unit.
Posted on Oct 27, 2008
SOURCE: error
problem ricoh photocopier model no. 2015 error sc 552
Posted on Jan 06, 2009
  • 990 Answers
SOURCE: sc 322
Hello sir; Try to reset if not work you need to replace laser unit, the reset procedure as follow; press "clear mode " then 107 then press " clear/ stop " until screen change ,then touch "copier sp " ,then turn power off and back on .
Posted on Aug 26, 2009
SOURCE: ricoh 1035 laser problem
sometimes the plastic of the laser is turned by the heat proves to relax and to fit the screw that holds the laser unit that is of the side of the drum while it raises a millimeter with a screwdriver, this sometimes works.
Verifies that the glasses and mirrors well be positioned correctly.
Other
Poor connection between the laser
synchronization detector board and
the LD unit.
Laser synchronization detector board
out of position
defective
LD unit defective
Posted on Nov 15, 2009
  • 192 Answers
SOURCE: i HAVE AN ERROR SC 322 WHEN i GO TO PRINT RICOH 1035
Error Code SC322:
1st laser synchronization error
The 1st laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Possible Causes:
+ Poor I/F harness connection between the laser synchronization detector board and the LD unit.
+ Laser synchronization detector board out of position and angle of reflection not correct
+ Laser synchronization detector board defective LD unit defective
Not sure what your expertise is on this, but unless you know how to service the machine yourself, this one is going to require a service call...
There have been instances where toner drops onto the LD Unit and creates problems like this. About a month ago I replaced the Laser Synch. Detector Board in a 1045 for this exact problem and error code.
I'd start by cleaning up any toner on the LD unit, and re-seating all the electrical connectors on the laser unit. If that doesn't clear things up, it's probably one of two things, the LD Unit or the Synch. Board. I'd lean more towards the Synch. Board myself, but you never know...
Posted on Nov 19, 2009
Meaning ofSC 400 Nashuatec C2030 aficio
Nashuatec is made by Ricoh.. SC400 means that there is a problem with the fixing unit.
Jun 08, 2012 | Office Equipment & Supplies
SC 322
sc 322 how to solve this error
Jun 16, 2010 | Ricoh Aficio 450 Copier
How to clear error code,sc542 nashuatec photocopier-mp6500
01. Press Clear/Stop Key (Yellow key) 2 tram
02. type 107
03. press Hold down Clear key 5 secend ( Red key)
04. type 5 and press # or Ok
05. type 810 and Press # of Ok
then machine Of and On
Jan 14, 2010 | Ricoh 6513 Copier
Sc 322, sc 326 codes
Oct 25, 2008 | Ricoh Aficio 1035 Copier
Afficio 450 sc 322
1st laser synchronization error.  This should be looked at by a Ricoh technician to see what needs to be replaced.
Sep 11, 2008 | Office Equipment & Supplies
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Aficio 450
SC 322 is a laser diode problem. It will require service.
Mar 27, 2008 | Ricoh Aficio 450 Copier
Open Questions:
49 people viewed this question
k24674
