Question about E-Machines Computers & Internet
Basically my on buttong got stuck and when I was trying to get it out the front cover thing came of. Together the wires also came out.On the end of the wires it has...(POW S/W),(POW LED),(HDD LED). Please help me I don't know where to plug the wires back into. I am curentely using my laptop.
  • Anojan Oct 28, 2008
    Emachines 390 is the model
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    got a model number for that e machine you can share to make it easier to help?
    Scholar:
  • 195 Answers
Ha Ha Ha, well your front cover thing is where your power on button and LED lights reside. the POW is your power wire that connects to your power switch you pried out of your front cover thing, or your power switch. Your POW LED is the wire that connects to the light that lets you know your computer is on and running on your front cover thing. and of course the other wire connects to the other LED light on your front cover thing. Good Luck. also, you can change the wires around until you get it right.
Posted on Oct 28, 2008
What is a ****
Basically, if you take an *** and a ************ and put them together, with enough tries at least, you will eventually get a ****. Occasionally, the *** ends up with several **************'s and the whole thing turns into a ********.
Oct 18, 2012 | wikipedia.org
I have a 2006 electra glaide police bike ...how do i install a new throttle cable
First remove the air filter cover, the air filter element, and the air filter backing plate so you can get to the carb end of the cables.
Then, adjust the cables so that you have as much slack as you can get in them.
Loosen the two bolts that hold the front brake master cylinder on and slide it towards the center of the handlebars. Take the two bolts out of the right handlebar switch half. Separate the switch halves carefully as there are wires in there. Work the cable out of the throttle sleeve, take the ferrel off the end, and pull the cable out of the lower switch housing. Sometimes this can be aggravating but spray some penetrating oil in there and keep working it. Once out, disconnect the cable at the carb end.
Reassembly is basically the reverse of the dis-assembly. When putting the switch housing back together, don't pinch any wires and don't slide the throttle assembly all the way up on the bars. Once you have the throttle assembly bolted together and the master cylinder repositioned against the front face of the switch housing, adjust the throttle cables. Not to tight, a bit of slack in each cable. The throttle should "snap" back when you release the throttle. If not, work with it until it does. Failure to properly adjust and insure proper throttle operation can cause the lose of control of the vehicle which could result in serious injury or death to the rider.
Good luck
Steve
Oct 09, 2010 | Harley Davidson FLHT Electra Glide...
When the unit was running it quit the display went blank? is there a fuse somewhere, all i can find is a printed control panel. DU1055 model.
Does it function at all? If not it's prob not the fuseable link. I'd put money that you have a bad contriol (the circuit board has shorted). I have the same model. Mine shut down during a wash cycle - totally dead. It has power but doesn't function. The wiring diagram (located down on your kick plate) explains how to test various components. Two things you can do when the unit has power but is dead - Turn off the power to the unit. Open the door and unscrew the six screws that hold the top of the dishwasher together. The front top control will now be loose.On the backside there is a gray cover. push the tabs back and remove this cover - make sure the power is shut off at the breaker). Under the cover you will see your circuit board and a bunch of wires. There is a 14 pin connector that connects the circuit board to the key pad. push the tabs back and lift out the circuit board. carefully unplug the 14 pin connector and leave it unplugged. Put your circuit board back in and install the gray cover over the controls - leaving the 14 pin connector unhooked. install the six screws - basically putting the thing totally back together. Leave the dishwasher door open and turn the breaker (power) back on. Count to five and close the door. If you have a bad key pad your dishwasher drain motor will cut on and run for 2 min. If the control is bad (the circuit board) nothing will happen. The control is fairly easy to replace - costs around $122 bucks for parts. Hope this helps!
Oh yeah, if you want to check the fuseable link it's the round thing on the circuit board - has two black wires going into it. MAKE SURE the power is turned off at the breaker before you mess with this.
Feb 19, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Stuck in tow haul - how do I get it to release? GMC Yukon YR 2000.
After time, the wires at the end of shifter break because they were cut short at factory and have little or no play. You will have to take column cover off where you can splice wire back together. It’s best to solder them together for best contact.
Feb 15, 2010 | 2001 GMC Yukon XL
What's the proper way to connect my linksys WRT110 properly
exactly the same as with its predecessors. either wifi or ethernet. use ethernet for any speed realted things, wifi for moveable connectivity. i woulndt bother with the protecte connect buttong thing on the front. ust do the same as normal.
Nov 11, 2009 | Linksys Computers & Internet
Can sirius antennas be cut and spliced back together
If your antenna cable has been cut or severed, it can be repaired without the need for a replacement.
You will need the following things:
Small 600 degree soldering iron and solder.
Liquid flux for soldering the braid.
Small sizes of heat shrink tubing.
Small heat gun.
Small pliers, cutter, and Xacto knife.
1) The first step is to use the Xacto knife to cut both ends of the antenna cable so you have a clean end.
2) Using the Xacto knife roll the cable on a board and gently cut all around the cable to cut the outer insulation. Remove about 1/2 inch of the insulation from each end.
3) Push the braid back to expose the center wire and gently roll the cable and cut the center insulation to expose about 1/10 inch of the center wire. With your small long nose pliers, bend the center wire into a small hook shape.
4) Repeat all the above steps on the other end of the wire.
5) Put a 1 inch piece of heat shrink tubing on one end ( the black piece), and a 1/4 inch piece of heat shrink (the white piece) on the center conductor. Look at the picture to see this.
5) Hook the two ends together. Gently squeeze the hooks closed and solder them together. Be very careful when soldering this. Be quick so you do not apply to much heat and cause the heat shrink tubing to shrink on the side where you do not want it to be.
6) Slide the small white heat shrink to cover the cooled solder joint you just made and use the heat gun to shrink the tubing in place.
7) Now push the braids back together to cover over the connection you just made. Try make the braid smooth together by GENTLY rolling the cable between your fingers. Carefully solder the braid. A little liquid flux on the braid prior to soldering helps the solder flow and makes it look better.
8) Slide the final piece of heat shrink tubing over the braid and shrink it with the heat gun.
Jun 12, 2009 | Sirius Satellite Radio Receiver
2000 ford focus speedometer stuck at max speed
it may have a static charge in the instrument cluster,try un-hooking the battery then turn the key on and even hit the brakes to try to drain the spark out of the system,hooking the 2 cables together with the battery disconnected may work as well to drain it.hook up the battery and see what happens,but make sure the key is off and nothing is on-lights,radio,wipers etc,it could send a spark to the computer.
May 31, 2009 | 2003 Ford Focus
2003 buick lesabre heated seats wont work
I had this problem, but only on the driver's side (with leather seats). Sometimes the switch would come on, but I could not get it to go back off (and the seat would not heat).
I ended up removing the drivers front seat cover (only the bottom part), folding it back from the driver's door to the middle of the car. You also have to unplug the wiring harness underneath the seat. I found a black spot burned in the foam. This is where a wire had broken. I carefully pulled the wire together, then soldered it. I put everything back together, and it has been working ever since (about 6 months - and getting lots of use in the middle of the winter).
I think the only way to replace the heated seat wires is to replace the whole seat cover. I was glad I could fix mine by soldering it.
Jan 28, 2009 | 2003 Buick LeSabre
Hobart Dishwasher electrical connection
Hi chefmail,
I'm Harvey the Master Plumber.
You want to know: Somebody disconnected our AM-14 to redo the floor, and left it disconnected. You know basically where the wires went, but could use some help or a diagram.
I generally don't recomend this to the average homeowner so lets assume you're above average.
Lets also assume that the fellow who removed it knew what he was doing (he should have reinstalled it for you).
If all you need is help with the wireing:
First double check that the power is off.
There should be a romex connector a few inches from the end of the wire. If it's not there he may have left it attached to the junction box under the d/w. You must use a romex connector to connect the wire to the junction box. Make sure the romex connector is on the cover insulation not on the individual wires. The wires are color coded. Connect the blacks together, the whites together and the ground to the green wire (sometimes to a gound screw). Be carefull that the wire nuts are tight but none of the wire ends broke. Before you put the cover on finish instaling the d/w, water line, drain line, counter screws and be carefull to make sure the d/w is perfectly level. Turn on the water and check for leaks. Turn on the power and test the unit. Then put the junction box cover on. All that's left is the kick plate. If you run into problems you might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Dishwashers
Wire from bra stuck behind drum in Boasch NeXXt front loader washer
Are you comfortable opening the cover the refer to
www.repariclinic.com
Jul 03, 2008 | Bosch WFR 145 Front Load Washer
Computers & Internet Logo
147 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
