Question about Kenmore Side by Side Refrigerator
Kenmore refrigerator model 106 41212101, not cold, fan working, light working, air blowing in frigt. how to troubleshoot
Two day ago, we discover, the freezer, and refrigerator no cold air, freezer items melting, meats become soft. so do the milk from the refrigerator is not cold. Both inside the light is working, the air is blowing, remove the behind cover, the fan is working, the compressor is hot when touching. 2003 kenmore side by side refrigerator, model 106 41212101 white color, how to trouble shoot ? thank you.
5 Suggested Answers
SOURCE: refrigerator not that cold and freezer not freezing well
dirty coils underneath the fridge, or the fan in the bottom (to cool the compressor) is not working.
Posted on Aug 07, 2008
  • 1122 Answers
SOURCE: refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Posted on Nov 04, 2008
VOTIT
  • 2071 Answers
SOURCE: Kenmore side by side is not getting cold or freezing
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
Is the refrigerator completely dead?
If so, see “It's stopped completely.”
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor
The Thermostat
The overload, relay, or capacitor
The defrost timer
The condenser fan motor
The freezer and the fridge are cooled by the same system, air is moved to the fridge by a fan from the freezer, either the circulation fan is defective or the fridge thermostat is defective.
Regards:
VOTIT
Don't forget to rate;
Posted on Jul 05, 2009
j_bloomfield
swan fridge freezer not working
Posted on Jul 11, 2013
We have a Kenmore Bottom Mount Refrigerator. The freezer cold but the refrigerator part is warm. Model Number is 596.6998. How do we fix it. We have removed the grille and vacummed it.
Is the fan that blows cold air from freezer to refrigerator running? And is the mechanism that controls the doorway allowing air into refrigerator working properly?
Jan 11, 2017 | Kenmore Refrigerators
My ice cream is melting and things have started to thaw
Turn the t'stat up to 9. You want to save the meat and ice cream. It sounds like you may be losing freon. Get it looked at soon so you won't come home and find meat soft and ice milk.
Mar 06, 2013 | Whirlpool EV160NZTQ Upright Freezers
Kenmore side by side Refrigerator top portion is not getting cold. The freezer is working and the bottom portion of the refrigerator is cold but not the top portion of the refrig,
the refrigerator simply by transferring the cold air from freezer via circulation fan the temp controls tells the fan to circulate cold air until the thermostat is satisfied I would check to see if the fan is blowing on most models I have seen its located in the left rear wall closest to the freezer above the top shelf
May 02, 2012 | Kenmore Refrigerators
AEG Santo C61841i - freezer is working but fridge is not very cold and turning everything off very quickly - milk only last two-three days
A refrigerator not cold enough is a hassle, because you are at risk of spoiling the foods you store in there. Most often, this problem is caused by something easy to fix.
1. Faulty Door Gaskets
The door gaskets in a refrigerator ensure a sealed closure every time you shut the door. Torn or loose gaskets on the door of the refrigerator can result in a leak in the cold air. As a result, the refrigerator is warmer. Repetitive and frequent opening and closing of the refrigerator is also a possible cause, because the warm air from outside replaces the cold air in the refrigerator every time you open it.
2. Dirty Condenser Coils
Dirty condenser coils can result in improper functioning of the refrigerator. These coils are located on the back or the underside of refrigerators. If you find this to be the cause of the problem, unplug the refrigerator before you attempt any cleaning.
3. Frost-free Feature not Working
If the frost-free feature fails, it causes a buildup of frost around the evaporator coils in the freezer. This causes a malfunctioning of the evaporator fan that blows cold air around. The fan can also be damaged if it hits the frost.
4. Faulty or Incorrect Temperature Control
A faulty thermostat can lead to a refrigerator that is not maintaining the desired coldness. Check for this problem and also ensure that the temperature is set to the correct level. Normally, refrigerators are set to a temperature of about 0°C, whereas the freezer sections are around -17°C.
5. Inadequate Air Flow inside Refrigerator
A refrigerator that is loaded with too many food items can fail to maintain an adequate level of coolness across all the items kept in it. The surface items tend to be colder, and the items underneath do not become as cold. A refrigerator that has very few items in it can also fail to function efficiently. Try to ensure that your refrigerator has enough food in it at all times, but is not so loaded that the air flow gets constricted.
6. Vents between Freezer and Refrigerator Clogged
The vents between the freezer and refrigerating section blow cold air from the freezer across to the refrigerator. If these vents are clogged with ice, the air is blocked and the refrigerator does not cool down. If this is the case, you can unplug the refrigerator, wait for the ice to melt and then connect it back to the power supply.
7. Faulty Door Switch
The door switch is found on the bottom of refrigerator doors. It turns off the light in the refrigerator and resumes cooling action when you close the door. If this switch is not functioning properly, the refrigerator will not be cold and it will also be affected by the heat of the interior light.
8. Refrigerant Leak
A refrigerant leak is very unlikely. This problem can cause malfunctioning of your refrigerator. If you suspect this to be the cause, contact a service technician.
Hope this will help in solving the problem....
Aug 05, 2011 | AEG Refrigerators
We have a GE side-by-side refrigerator (GSS23QGTA); it's about 6 or 7 years old and has been working just fine until about a month ago when we noticed that the freezer was not freezing food. The temp had...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 16, 2011 | Refrigerators
I have a Kenmore refrigerator/freezer model # 596.65232401, this is the one with the freezer on the bottom and refrigerator on top. The freezer works fine, the refrigerator was not cooling, I removed the...
What you didnt state was whether you had cold air blowing when the damper opened up. If you did, then the problem will be with the damper assembly itself, or the control board, which is what you would adjust to change temperatures. This microswitch you mentioned, was this on the control board? then the control board is the problem. If you did something with the damper assembly, then that might be the problem.
If you dont have any cold air blowing when you opened the damper door, then airflow is your issue, and you will have to include more symptoms for a refrigerator repair diagnosis.
Nov 27, 2010 | Kenmore Refrigerators
I have a Ge side by side model #GSS25TSR. It is 4 years old. the problem started 4 weeks ago. Things are freezing on the refrigerator side in the vegetable drawer and on the shelf above the meat drawer. I...
you've already discovered your problem. its not blowing. if the freezer fan motor is not blowing air through unit, the cold air falls to the bottom of both sides, and warm air at top of both sides as well. On that model, the fan itself may be bad, or it may be the main control board behind the unit. Without properly testing and inspection, I cant be certain if its one or the other or quite possibly both, And I was trained directly from GE about this.
www.FixMyFridge.net
Mar 08, 2010 | Refrigerators
Icecream not staying froze meat stays frozen though
Meat is always more dense than frozen dairy product. This soft ice cream issue usually occurs when the circulating fan becomes blocked due to overloading.
Unlike a chest type freezer, top mounted freezers use a fan to circulate to the refrigerator. If the return vents to the freezer become blocked by too many small items, or loose plastic bags the compressor may run too long in an attempt to lower the refrigerator temp,
This may cause the compressor to heat up and kick in the overload safety, further dropping the total temperature.
Mar 05, 2010 | General Electric GTR16BBSR Top Freezer...
ONLY BLOWING SEMI COLD AIR> NOT REAL COLD LIKE IT SHOULD BE. cleaned front condencer still not ice cold. worked fine two days ago
return air ducts are iced up , unplug unit overnight or use a blow dryer in the freezer area. Ducts are behind rear panel left and right side
Nov 27, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore Side by Side Refrigerator Logo
47 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
