Question about Konica Minolta bizhub C250 All-In-One Laser Printer
How do you change the paper selection?!?
We have about 300 people printing to our c650. Not all of them know how to set their paper settings correctly or what drawer each type of paper is stored in (each drawer remains a constant size).
So, consequently, when people print to the printer, they select the wrong paper tray. Is there a way to guide it to the right paper tray so it can continue printing? I just want to change the tray, but it doesn't seem to let you from the machine (short of deleting the print and angering the person who sent it).
Please help!
  • ckleinholz Nov 12, 2008
    Unfortunately, I know to do that, but the other 300 people don't. The issue is that when they don't choose the correct paper size and/or tray I can't change it. On all our other copiers you can "guide" it to the right tray by choosing it from the error screen on the machine. This machine doesn't seem to allow you to pick a different paper tray, even if it has the right paper in it.
    I totally agree with the training part. In a perfect world I would definately make all the people here go through a training on the machines. Unfortuately, that's not going to happen here.
    We are running off a server and since I don't work in IT I have no control over what goes on at that level. The print driver defalts to auto (at least my computer does) but if your printing from Acrobat and have your settings to "choose paper size by pdf size" or whatever that little check box is, then it gets hairy. There's so many variations that I can't control how they send their stuff. I just want to be able to fix it and continue printing without deleting their print and making them send it again.
    Champion:
  • 214 Answers
If you have a different size/type paper in trays, just choose auto tray from printing preference, you only have to put right paper type /plain/thick ..... and the printer find it self the right tray
Posted on Nov 12, 2008
  • Illar Lumiste Nov 12, 2008
    OK, how are the users connected to printer, is the printer shared out from server ??? because the default is auto select tray, usually user don't have to choose tray at all, just paper type is required.
    if you share it out from server, I'm not sure, but it may be possible lock paper source field.
    But better way to manage printing in 300 people company, is to use boxes, create every user a box, and they print in user box and when they come to printer, user open his box, chooses jobs that he still want to print out and prints it out in the correct tray. this also prevents users to waste pointless paper. e.g just print out and forget it in the printer.
    still you have to teach them how to print send them a e-mail with pictures, not to choose paper tray, just leave it to auto select. tray choosing is only necessary when printing in bypass tray
    good luck.
  • Illar Lumiste Nov 13, 2008
    One more thing, that you can try, open in web brauser your printer ipaddress (pagescope web connection) log in as admin (12345678) ad choose print tab, there is a field: "action when there is no maching paper in tray" -> choose "switch to tray with correct paper size".
    Maybe this will help a little bit. It should switch trays even if wrong tray is selected. I just tryd it.
Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
Feb 09, 2012 | Lexmark T644 Laser Printer
PRINT RUBS OFF
When printing envelopes ensure you set paper/media type to Envelopes, and feed via tray 1/bypass . Paper type setting sets correct fuser temp, the fuser is the hot bit at the rear that "melts" the image into the paper.
If paper type is set correctly then I recommend you change the fuser unit.
Ensure envelopes are standard type. ie you are printing on paper envelopes
Feb 11, 2008 | HP LaserJet 5p Printer
Printing three black and white labels to a page - the first of three looks perfect - the next two are granular at best - i've already tried changing the printer settings to best and darken with no luck...
Probably your paper settings are not correct, or you do not have a sufficient label-paper. Try to select the exact paper type you use. Depending on what choice you make, the paper will go through the printer on a different speed, exactly what is needed to fuse the toner on the substrate. When it is going to fast, there is not enough heat to bond the toner onto the paper and your printout looks weak.
Sep 24, 2011 | Samsung CLP 300 Laser Printer
Error Number : 71 The selected paper size and the paper source are not compatible. Turn the Photo Paper Tray handle to the right, load paper of the correct size in the auto feeder or change the paper size...
This is probably a software settings issue, please check in the application that you use for printing if the default paper size is the correct one (A4 on Letter)
Also check in Control panel, under printers Properties, that the correct paper size is selected.
Try printing again.
Regards,
Katharsys
Mar 31, 2011 | Office Equipment & Supplies
Lexmark T632 has 2 (ea) 500 sheet drawers, but once the paper runs out in Drawer 1 it will not automatically pull from Drawer 2. Please advise how to fix this problem.
go to Menu, reports, and print out the top report.
This will show you what the printer sees as the default tray, and what paper size and type are set for each tray.
If you have plain paper in each tray, make sure that the setting page also shows that each tray is set to letter, plain.
This printer sets the tray type automatically, based on the way the tray is set. There are little tabs on the side of the tray that change as you change the size of the paper with the paper guides.
If the paper guide is set even one click off, this can cause the printer to read the paper size incorrectly, and thus will not change to the next tray. ( if it thinks that tray 2 is A4 paper, but you are printing letter, it will not change to tray 2).
if the trays ARE set correctly, but the printer is still reading it wrong, then there could be something wrong with the sensor ( metal fingers and switch ) inside the printer.
Feb 15, 2011 | Lexmark T632 Laser Printer
Please teach me how to use my HPF4185 to print envelopes. Thanks.
Hi
Use the product software, also known as the printer driver, to change the print settings for your envelope size and type. Then, use the Envelopes and Labels tool in Microsoft Word to select your envelope size.
Step one: Adjust the print settings
-In Microsoft Word, click File , and then click Print .
-Make sure that your product is in the Name drop-down list box, and then click Properties .
-Click the Features tab, or the Paper/Quality tab.
-Select an envelope size from the Size drop-down list.
-If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
-Select Custom from the drop-down list.
-In the Custom Paper Size dialog box, type a name for the new custom size.
-In the Width and Height boxes, type the dimensions.
-Select the unit of measurement, and then click Save .
-Click OK to close the Custom Paper Size dialog box, and then click OK again to close the Properties dialog box.
NOTE: You must exit the Properties dialog box to apply your changes.
Open the Properties dialog box again, and select the new custom size from the Size drop-down list.
-Select the paper type.
-In the Paper Type or Type is drop down list, click More .
-Click the desired paper type, and then click OK .
-Select the paper source from the Paper Source drop-down list.
-Change any other settings, and then click OK to close the Properties dialog box.
Step two: Set the correct envelope size
-Set the correct envelope size in the Envelopes and Labels dialog box before printing envelopes.
-In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
-In the Envelopes and Labels dialog box, click the Envelopes tab.
-Click Options .
-From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
-Click OK , and then click Close to close the Envelopes and Labels dialog box.
-Click File , and then click Print to print the envelope.
NOTE: When you finish printing the envelopes, return the paper size and the paper type settings to the defaults.
Regards
Riztech
Oct 30, 2010 | HP Deskjet F4140 All-In-One InkJet Printer
The copier is flashing at the "error" light and the screen reads "change reccomended size, common settings" I don't know how to change it
To change paper size on Drawer 1, Go to Additional Functions > Common Settings > Reg Paper Size > Drawer 1 > Paper Size > (Select the correct paper size) > Press Ok
To change paper size on Stack By-Pass, Go to Additional Functions > Common Settings > By-Pass Std Set > (Select ON) > Paper Size > (Select correct paper size) > Press Ok
Oct 24, 2010 | Canon imageRUNNER 1023iF Black and White...
Paper not pulling from tray 2 when tray 1 empties - Lexmark T654
For the majority of the Lexmark printers, all that needs to be done is to set the paper size and type the same for each drawer. Example - drawer 1 & 2 sizes are set to letter, drawer 1 & 2 paper types are set to plain. Set up this way, when drawer 1 empties, the printer will automatically switch to drawer 2 to supply the paper.
May 20, 2010 | Lexmark Office Equipment & Supplies
Custem size paper are not creat
am using an Epson LX-300+II dot matrix printer in Windows XP. I am
trying to print checks that are tractor feed 8.0" x 3.66". I added the cusotm
paper size in the print server and it is saved correctly, however, when I try
to print, the print properties dialog does not show the paper size. In fact,
there are many paper sizes in the print manager that do not show up in the
list of available paper sizes.
Apr 13, 2010 | Epson LX-300+ II Matrix Printer
How can i add paper size of tally printing in lx-300
if you want change page setting in your printer ..... to get the all settings of your printer press font button and switch on the printer (before take setting make sure that you printer loaded with paper ) goes through the instruction printed in the paper to change the settings ........ change paper size.....
you can map your tally printer paper size in system .....go to printer and faxes ... file..>server properties ...>select create a new from ...> change the name as you wise and change the paper setting and click ok ........
while you give print change paper size to your created paper size and check
Dec 19, 2009 | Epson LX-300+ II Matrix Printer
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
739 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
