Question about Xerox WorkCentre Pro 421Pi All-In-One Laser Printer
WorkCentre Pro 421P
How to remove fuser
    Scholar:
  • 89 Answers
I have replaced everything on my 123 but it still jams
Is it jamming at the fuser? the most common problem is the fuser exit sensor that is located behind the fuser on the frame of the machine. Can you provide more details or an error code?
Oct 06, 2014 | Xerox WorkCentre Pro 123/128 Printer
Paper jams just before fuser unit
Remove the fuser. Behind the fuser there is a sensor. Frequently that sensor does not move freely and causes jams. You will see it on a metal bracket, Try flipping it gently, I am assuming that it will not move freely. You can lubricate it on the end posts.
If you need to replace it, its is not that expensive .
Feb 21, 2011 | Xerox WorkCentre Pro 428 Copier
Heat error
hi
this error is due to the fuser so to take of this issue you can remove the fuser and put it back but to be on a safer side i would suggest you to contact the customer care of xerox they will guide you accordingly and in case if the printer is under warrantty and the issue is a bad fuser they will be able to replace it
regards ali
Feb 17, 2011 | Xerox WorkCentre Pro 412 All-In-One Laser...
I have a Xerox, Workcentre 580 and I am getting a fuser error
On this model, the heat roll has a temperature sensor. If the heat roll is worn and coated with toner, this will damage the sensor. Most common problem is this sensor goes out when a heat roll is badly worn. Circuit boards on this model are pretty reliable.
This sounds like a fuser rebuild.
Feb 16, 2011 | Xerox WorkCentre Pro 580 Plain Paper Laser...
Printer is saying "fuser error- call for service"
You will have to replace the fuser unit.
Google a business called The Parts Drop and give them a call. They are roughly 200-250 dollars to replace
Dec 13, 2010 | Xerox WorkCentre Pro C2636 Color Copier
Paper stop before the fuser
hi,clean drum cartridge or fuser espicially fuser.be sure little papers in fuser.
May 15, 2009 | Xerox WorkCentre Pro 416DC Copier
Xerox Workcentre 24- Paper jam in the fuser
Shut down. Unplug!!! Remove fuser to remove jam. Fuser may be or be going bad.
Apr 22, 2009 | Xerox WorkCentre M-24 Color Copier
I need the manufacturer part number for the fuser to a WorkCentre Pro 580 - Xerox.
Call 1-800-828-5881 and follow the prompts. They will give you the part number you need.
Dec 15, 2008 | Xerox WorkCentre Pro 580 Plain Paper Laser...
My machine shows a U4 code
U4 code refers to a fuser heat failure, you'll probable find the fuser roll is stone cold .Possible cause is open circuit heater or overheat thermostat popped.Either way you will need to pull out the fuser unit and check continuity of the components
May 29, 2008 | Xerox WorkCentre Pro 423 Copier
Xerox WorkCentre Pro 421Pi All-In-One Laser Printer Logo
126 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
