Question about Electrolux Washing Machines
Saya butuh buku petunjuk pemakaian mesin cuci electrolux ewt 115
Electrolux ewt 115
  • 123 Answers
SOURCE: Need Manual for Electrolux EWT 13420 W - EWT 10420
These site carries the full line of Electrolux Manuals
http://userguides.50webs.com/manual.htm
Posted on Sep 06, 2009
SOURCE: USER MANUAL OF EWT 10730 W FROM ELECTROLUX
Try this site. www.laundrymanualsonline.com
Hope this helps.
Posted on May 21, 2010
richroth
  • 9472 Answers
SOURCE: modul mesin cuci sanken tipe AW-772SS rusak, bisa
Berikut ini adalah mesin cuci Sanken.
Posted on Jan 10, 2011
SOURCE: error pada mesin cuci lg
the machine does not fill air.indikator spotty water continues. in trying to fill the manual is still not mau.indikator water is still spotty, so the engine is turned off the water that filled manually ngebuang own. lg brand machine type WF-7010PC
Posted on May 17, 2011
  • 6277 Answers
SOURCE: electrolux washing machine ewt 1330
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 13, 2011
Electrolux ewt 115
Hi Cong Tran.
To buy parts for your machine you should go the the manufacturers distributor with the full model number. (The shop where you bought the machine may be able to help you with that information) The parts shop can easily tell you cost and availability of the part.
Good Luck
Cheers
Nomess
Jan 03, 2015 | Electrolux Washing Machines
Lupa password dan username poker88 atas nama buku
bos nama saya ade sumantri, saya lupa user name, pasword, bahkan email dulu yang saya buat waktu daftar poker 88, gmana caranya saya mau main lagi dengan data rekening dan nama yang udah saya daftarkan, email yang baru ade_sumantri@ymail.com,tolong di bantu
Aug 05, 2013 | Computers & Internet
How to do i open filter for electrolux aqua shower 800
bagaimana cara mengoprasikan mesin cuci
Mar 28, 2013 | Electrolux Washing Machines
Mesin Cuci LG WF-T900IS, Kami Baru beberapa detik Bekerja Langsung Berkedap-kedip seraya muncul kode dE di Perangkat Digital nya. Mohon Bantuan & Solusi nya Trims.
Nov 21, 2012 | LG Washing Machines
Electrolux EWT854S
Bagaimana cara memperbaiki mesin cuci elextrolux EWT854S yg kode kerusakan nya EA
Aug 24, 2012 | Electrolux AWT1012 Top Load Washer
Tolong,bantu aku untung membuka zynga poker saya
Berikut adalah bagaimana anda melakukannya. langkah pertama Menukar alamat e-mel anda dikaitkan dengan akaun buku muka anda. pergi untuk menghadapi buku, kemudian ke akaun, maka ketetapan akaun menukar e-mel ke alamat e-mel baru. facebook akanmenghantar anda e-mel pengesahan kepada alamat peti masuk e-mel baru anda, ikuti pautan untuk mengesahkan. kini kembali untukmenghadapi buku dan kembali ke tetapan akaun, dan menukare-mel ke alamat e-mel baru ... jangan lupa untuk mengeluarkanalamat e-mel yang lama (hacked) pada titik ini. dan yang kawan-kawan saya .... bekerja untuk saya, harap ia berfungsi untuk andajuga.
Sep 15, 2011 | Zynga Texas HoldEm Poker
Error pada mesin cuci lg 6.5 g kode dE disebaban oleh apa?
m.cuci lg toplouding error DE. pada dasarnya pintu atas dilengkapi swich tapi kenapa model ini kok gak.terus gimana cara ngatasi door swich ini. mohon pencerahan
Jan 17, 2011 | LG Washing Machines
Cannot open the door
'UE' adalah menandakan " unbalance error ", solusinya adalah set kembali posisi mesin cuci anda jangan sampai miring atau seimbang dari permukaan lantai. jika sudah dianggap seimbang, coba hidupkan kembali mesin cuci anda dari proses pertama.
Jul 31, 2010 | Samsung WF337AA Front Load Washer
Selamat Siang, Saya mau bertanya.... Printer Canon saya tipe MP160 itu mengalami kerusakan,pada display muncul (E 1,5) Ku sudah baca buku petunjuk penggunaan dan saya praktekan tetap gak bisa....,apakah...
Wah mas agunggunawan,
kalo pake bahasa indonesia kemungkinan dapat jawaban sedikit :)
Reseat Ink Cartridge Procedure.
Error LED E,1,5 tolong dibaca dulu:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=13368#SupportDetailAct
Klo ga bisa juga kemungkinan begitu.
Tinggal perbandingan aja mending di repair ato beli baru :)
Dec 26, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Washing Machines Logo
165 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
