Question about Cycling
Removal of rear wheel with internal geared 3-speed and coaster brake hub
Bicycle is a women's schwinn collegete model. 1970's vintage. has a 3 speed, internal geared rear hub with a coaster brake. i need to remove the rear wheel.
  • 20 Answers
Find the joiner link on the chain, remove the retainer clip followed by the link. Remove the chain. Remove the bolt holding the brake arm to the frame. Loosen the axle bolts on the wheel enough to be able to slide the rear wheel out of its slots on the frame.
Posted on Feb 24, 2012
3 Suggested Answers
  • 10 Answers
SOURCE: I am having trouble putting the front tire on my
The easiest way to put on or take off a tire is to release the break cable. Bikes nowadays have a quick release for the break cables and that will release the pressure on the break pads.
Posted on May 22, 2010
dunnbiker
  • 8546 Answers
SOURCE: i have a Shimano Nexus 7 Speed (SG-7C18) Internal
http://techdocs.shimano.com/media/techdocs/content/cycle/SI/Nexus/CoasterHub/SI-7C26C-EN_v1_m56577569830605809.pdf
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/SG/EV-SG-7C18-2396C_v1_m56577569830702946.pdf
You'll probably need some special tools - or take it to a bike shop and let them deal with it.
Posted on Jul 21, 2010
Drive {pedel cog} just turns but will not drive the wheel cog
If a one speed coaster brake the rear hub needs to be overhauled. Take to a bike shop or bike co-op, unless you want to look up, study and follow carefully: Bicycle Coaster Brakes
Nov 14, 2016 | Cycling
Aseemble a coaster brake on a bicycle
Ken, Check the attached links,instruction and guides on removal and install coaster brake. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Coaster Hub Overhaul Pedal Brake Hub
How To Install Cog On Coaster Brake Hub
Bicycle Coaster Brake Repair and Service
Oct 01, 2014 | Husky 26"" x 2.125 Industrial Chrome...
I found a very old Scwinn 26" boy's with a 3 speed coaster brake on it. I figure someone swapped it decades ago. Do you know how far back that 3 speed w/ coaster bakes goes?
Three speed Schwinn's go back to the late 50's and 60's. Just type Schwinn Photos in the command line on the internet search page area and a full page of pictures will come up. Here you may see the exact bike you purchased with the descriptions.
Feb 26, 2014 | Schwinn Windwood 26 Women s Cruiser...
When coasting the pedals keep moving so you have to continue to pedal and when peddling backwards the bike goes backwards, how do I stop this?
I assume that this bike normally has a coaster brake. If so, your coaster brake mechanism (inside the hub of the drive wheel) is jammed or broken. You will have to disasssemble the wheel hub. This bike might have a coaster brake on both rear wheels or maybe just one side. Lift both rear wheels off the ground and turn them independently to determine which side the problem is on.
Sep 18, 2012 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Coaster brake adjustment
These aren't really adjustable, but the parts that are wearing out are replaceable, and it involves disassembling the rear hub. Here is a link to a VERY thorough how-to guide, but this just covers one type of coaster brake. There are a couple of different styles, and if you have one of the older ones you can pretty much figure it out by taking it apart.
Here's the link--
http://www.troubleshooters.com/bicycles/1speed/1speed_overhaul.htm
good luck
Sep 12, 2012 | Schwinn Windwood 26 Women s Cruiser...
The brakes are getting stuck and the wheel doesn't tuen
You do not say what kind of bike, speed bike?Coaster brake? hand brakes, pedal brake? If, it is a hand brake, it usually means that your wheel is bent and needs to be trued. You cannot adjust brakes with a bent wheel and you need a truing stand.. If it is a coaster brake you need you hub rebuilt as there is an part broken inside the hub.
Apr 16, 2011 | Schwinn Cycling
How do you use the 21 speeds on the Schwinn ladies coaster bike?
there are 7 cogs on the rear wheel hub; three on the crank hub:
7x3=21 gear change possibilities
large gears move the wheel faster and farther around but, with more effort
small gears move the wheel less distance but, with less effort
i.e. 10 teeth divided by 30 teeth= 3:1 per 360 degree rotation of the bicycle wheel
Sep 07, 2009 | Schwinn Cycling
It is a 3 speed coaster brake and the speed changer threaded mechanism keeps coming out of the hub because the internal mechanism is stripped. Had it repaired once and the same thing has happened again
There is very good information at this site:http://sheldonbrown.com/coaster-brakes.html You can also find the info on the three speed changer here. They are fairly easy to work on if you have tools but you will have to shop around for parts. Hope this helps.
Aug 11, 2009 | Schwinn Windwood 26 Women s Cruiser...
Cycling Logo
876 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
