Question about Sony Cyber-shot DSC-W55 Digital Camera
The lens does not stop popping in and out plus it says to turn off and on again
When i turn on my camera it says access. while the screen says access, the lens is popping in and out a couple of times, then it tells me to turn off the camera and back on. I read on a website to gently pull the lens and twist and that would fix my problem, but unfortenately it didnt.
  • 6 more comments
  • mcschwert Nov 02, 2008
    the camera says "access" and the lens keeps popping in and out
  • olemisschick Nov 03, 2008
    my camera says access then says turn power off and on again i have had my camera since last christmas so
  • Anonymous Nov 10, 2008
    when i turn on my camera it says access. while the screen says access, the lens is popping in and out a couple of times,...
  • Anonymous Nov 13, 2008
    I have the sam problem and twising the lens does not resolve it........... Any other ideas?
  • Anonymous Nov 17, 2008
    I tried this also and it did not resolve the issue
  • Anonymous Nov 19, 2008
    when i turn on my camera it says access. while the screen says access, the lens is popping in and out a couple of times, then it tells me to turn off the camera and back on. I read on a website to gently pull the lens and twist and that would fix my problem, but unfortenately it didnt.
  • tturner2032 May 07, 2009
    I have a Sony Cybershot w55 and it keeps popping in and out and it will not take a picture and it says turn power on and off again. what should i do? i cant view my pictures or anything.
  • mooosed May 12, 2009
    I have the same problem. When I turn the camera on the lens pops in & out the screen then says access then the lens shuts and the screen says turn the power off & on again. I tried this but it did not work. the DSc W55 is about 18mnths old and out of warranty is there another fix or can you reccommend a repair centre?
    Dave
  • 74 Answers
Hi there
turn camera on, gently take hold of the end of the lense and pull toward you twisting it a few times, be gentle dont make it pop, you may howeveer hear it click. then turn off and on again the problem should be solved.
Posted on Oct 31, 2008
  • c Nov 05, 2008
    just try to move the lense left to right it wont twist round but should move
  • 3 Answers
I followed the advice on a couple of other boards which suggests you actually give the camera a few hard whacks on a tile floor. That worked for some people. With me, after whacking didn't work I took a knife used it to pry up the edge of the lense while it was trying to open. A little of that worked for me.
You can't imagine the sense of accomplishment I felt when the thing finally started working again after all the banging and prying. It's a tough little bugger!
Posted on Apr 21, 2009
Twist the lense at the larger part of it each and that should solve the problem well it did for me and now my camers is fine
Posted on Apr 26, 2009
Umm it wont twist!!??
Posted on Nov 02, 2008
" " lens pops in & out twice & the screen says access then screen says turn power off and on again. Sony Cybershot dsc w55
this problum is related with optic zoom lenz assy its not work propally so thats why screen shows access problum pleae go to your nearst sony service centre & fix the problum or repair optic zoom assy
Feb 05, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Lens pops in & out twice & the screen says access then screen says turn power off and on again.
please follow the photos. location which may have damaged/ scan your memory card then try/ reset your camera.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Feb 01, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
"Access? & ?Turn the power off and on again? keep appearing
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Mar 04, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Lens pops in and out
hi there
turn on and gently take the end of the lense pul it toward you and twist left to right a few times, be gantle dont make it pop you may however here it click. then turn camera off and on again and the problem should be solved.
Oct 31, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cybershot 4.1 megapixels mpegmovie vx dsc-s90
Yeah, try to tapp the lens assembly with finger when it keeps going in and out.
May 05, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Cyber Shot DSC W35-W55
Sir,
The lens keeps coming in and out and it says access then it stops and says turn power on and off again. I can access my pictures but thats about it. Please help.
regards
prakash
Mar 05, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Panasonic Lumix DMC LZ2
My camera is a Lumix DMC - LS70 and the same thing was happening to me, the camera kept telling me to turn it off which never solved the problem and the lens never closed when the camera turned off. What i did was, i zoomed out as i turned the camera on (while it was in a picture taking mode) and it corrected itself. Try it and see what happens.
Sep 23, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Problem with a sony s600
This indicades the lens motor/gearing is damaged or worn. Nothing for you to do except contact Sony Chances are when you see the price of a 'repair' you will opt for a new camera.
Sep 11, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Sony n2 camara problem
ok guys, I was getting the same "Access" black screen on my dcsn2. I would turn it on and the lens would pop in and out I would get the black screen with the "Access" on it. What worked for me was the following:
As the lens came out i grabbed and pulled while it was fully extended
The "Access" screen disappeared and my camera was back to normal.
hope this works for u guys! :-)
Sep 09, 2007 | Sony Cyber-shot DSC-N2 Digital Camera
Camera Motor running
your lens is possibly damaged or seriously out of alignment - replacing lens is easier , than opening the camera ( hard to believe how many tiny screws etc . are in the way ) plus if you do open it . . . ? few technicians will work on it , after .
Aug 08, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
484 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
