Question about Frigidaire Ovens
1 Need Figidaire Double Oven knobs Model REG78WL*2
Model # REG78WL*2
3 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Double oven. Top is digital. It has started
You have a stuck keypad or a bad electronic oven control. Try pressing all buttons at random several times each to unstick a faulty pad. If that does not work the EOC must be replaced.
Posted on Oct 06, 2009
  • 250 Answers
SOURCE: Stoves 720 EF Electric Double Oven Model No
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Posted on Nov 27, 2010
Need User Manual Kuppersbusch Okotherm Double Oven
The age of the oven may make it difficult or impossible to find the information you are looking for.
Jul 08, 2014 | Kuppersbusch Ovens
Help!!! Need Replacement knob kit for my Thermador double oven!
these are NLA. No Longer Available.
Try to get something that is acceptable to you and fits by researching "oven Knobs" at repair clinic dot com and selecting by looks and size.
Nov 09, 2013 | Thermador SC302T Electric Double Oven
Clock Knobs
sears should have them . ck searsparts.com. use your model # and you should be able to get them . and if not contact me at (dodgeappliance@comcast.net.) and i will try to find them as some parts for this oven are n l a ..
Jul 12, 2010 | Thermador SC302T Electric Double Oven
We have a double wall oven which is 16 years old. The top oven doesn't heat above 150 and the bottom oven is overheating...the oven said 375 and an oven temperature gauge said 450. Is this fixable or do I...
I have the same issue. Only answer I found was the elements may be burned out. The bottom oven is separate (knobs).Go to GE site and see how to adjust the thermostat (behind a knob).
Nov 01, 2009 | GE JKP27 Electric Double Oven
Frigidaire oven is slow to heat then exceeds set temp set
Normally you should have an appliance spare parts supplier in your area. They generally stock all range of spares for all appliances. You need to pull plug out of the wall and remove the panel covering the wiring to gain access to the oven thermostat. Look carefully on the body of the thermostat and record any numbers you see on a sticker that's present. Then remove knob off in front of thermostat and see if there is a nut attached to the centre which holds the thermostat in position or if there are 2 screws holding the thermostat in place. Use this information to order the thermostat also quoting the oven model number.
Oct 06, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Need Chambers Oven clock/timer unit, model #GBO-244
I can get you one. Please call me at 9728590929 and I will be happy to find one and ship it to you. Hope this helps! Ella
Aug 20, 2009 | Ovens
MAJIC CHEF DOUBLE OVEN NOT WORKING
I just had a model 976-4CX put in...I have no manual...I'm trying to find one. I thought I had a problem with the element, dial or thermostat. The bottom worked, but the top stopped working. There are 2 timers with dials next to the clock labeled Start and Stop, and Push for Manual. Come to find out my problem was solved by adjusting the Start and Stop dials and/or pushing in for manual!?!
If I had a manual I'd know how these timers worked.
Nov 29, 2008 | Magic Chef 9522 Electric Double Oven
BOTTOM OVEN WIILL NOT HEAT
check the bottom heat element and see if you see any burn out spots on it,if so you will have to replace it(easy)let me now-mike
Oct 13, 2008 | GE JKP28 Electric Double Oven
Ovens Logo
85 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
