Question about Sony FD Trinitron WEGA KV-34XBR800 34" TV
I have a sony's kv-34xbr800 tv and it has a dvi hdtv interface.
I want to connect my acer travelmate 2410 laptop to this sony tv. My laptop does not have a hdmi output only a vga output. What is the best available option to see the laptop's video as a hd picture on my tv?
What inputs do you have on your tv
Posted on Feb 24, 2012
I recently bough a used 40in sony trinitron xbr. i have the DVI to HDMI cable but wether its my laptop or xbox the sound wont come through the tv at all. any suggestions?
Check the audio cable it might not been connected securely.
Could also be missing.
Even with the HDMI you may still needs it ( DVI is for video only).
DVI means Digital Video Interface.
Sep 26, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
How to connect a Samsung R700 PC to Sony LCD TV KDL-46S2010
hi my name is Rui i would like to help you with your problem...
its just easy to connect a PC to a sony lcd tv...^_^ here are 5 ways to do it...
1. S-Video - This is probably the most common method out there currently because an S-Video Cable is cheap as heck and just about every TV under the sun has a S-Video port. You'll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC's are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA Cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won't find a VGA port on regular TV's though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with "digital" being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI - Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Coverter Box - This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
just try hooking up 1 of this tips i give you.well if you ask me i prefer HDMI & VGA. ^_^
but it will still depend on your preference..
hope this will help you... Good luck... ^_^
Jul 17, 2011 | Samsung Computers & Internet
Issue playing audio from AcerTravelMate6593 on Phillips37PFL7603D
You need to run the audio out to an amplifier such as a stereo unit. The computer doesn't have enough power via the line out to make the TV pick up the sound by itself unless you turn the volume all the way up and maybe not even then, so an amplifier is your answer. It work for me.
Aug 17, 2009 | Acer TravelMate 6593-6656 Notebook
DVI port on Sony Trinitron KV-32HS500 not standard.What fits it?
I've just recently connected my old 32" Sony KV-32HS510 to my HP G60 Laptop via an HDMI (laptop) to DVI HDTV port(TV) with a cable.
I'm running Windows Vista on my laptop with the nVidia software. Once I've plugged in the TV to the HDMI port, the software initializes (recognizes the TV) and then I can select it as my second 'monitor' in the nVidia control panel.
I found I had to tinker with the resolution settings in the nVidia program to find an optimal resolution where the sides of the screen weren't 'cut off' by the TV.. I finally ended up with the resolution 1152x768 (I believe). It might be different for everybody, as I'm told Vista might do things differently than XP... But you should be able to tinker with the resolution settings and adjust the screen size...
(hope this helps with the second post - above)
Feb 11, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony KV-34XBR800
Complete manual is here:
http://www.mediafire.com/?ixd49edyyam
ID
KV-34XBR800
34XBR800
0 ID0
89
1 ID1 255
2 ID2 239
3 ID3 107
4 ID4 203
5 ID5 243
6 ID6 126
7 ID7 25
Rate me as fixya for my work, and ask another question if needed.
Mar 27, 2008 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Pink/Green Background Acer Travelmate 2410
you are having an lcd experience of the 3rd kind..i'd venture to say your in for a replacement event.
Feb 27, 2008 | Acer TravelMate 2300 Notebook
Sony FD Trinitron WEGA KV-34XBR800 34" TV Logo
110 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
