Question about Emerson Televison & Video
How do we connect a ps3 to an emerson television its an older version television set
Rf module
Posted on Feb 24, 2012
I am unable to get a picture on hdmi when i connect my ps3, but am able to get sound when i use ps3 controller. any ideas ?
Steps
  1. Step 1 Check for an HDMI port Check the back of your television for an HDMI port and refer to your owner's manual for your television's resolution. A resolution of 1080p offers the highest quality.
  2. Most PS3 systems support 1.3 HDMI, but older systems may need a software update from the 1.1 or 1.2 version.
  3. Step 2 Disconnect cables Disconnect all the cables and adapters from the back of your PS3, and then unplug your TV to reduce the risk of shock as you work.
  4. Step 3 Connect HDMI cable Connect the HDMI cable. Reconnect the power cables on both the TV and the PS3 system.
  5. Step 4 Hold power button Hold down the power button until the PS3 beeps and continue holding it for an additional five seconds until the system makes a second beep.
  6. The Playstation 3 should detect the high definition cable and automatically adjust the settings to give you the best picture and sound possible.
  7. Step 5 Test the connection Test the connection. If the HDMI cable isn't working, turn everything off and reconnect the original cables to manually change the settings.
  8. Step 6 Adjust the settings Turn the system back on, select Settings, Display Settings, Video Output Settings, and then HDMI. Repeat the process for your Audio Settings. You can now experience your games with the highest video and audio quality available.
Dec 01, 2014 | Sony KDF-E50A12U 50" LCD HDTV
How do I set up this Emerson TV to work with this sudden link remote
You don't do anything with your Emerson TV. You program the Suddenlink remote to control the Emerson TV.
There are four different versions of Suddenlink remote. Follow the guide here for your particular model.
Suddenlink Help Television Remotes
Sep 09, 2014 | Emerson Televison & Video
What do I need to connect an old TV with only one output on back to a TWC cable box, DVD Player, VCR and a Play Station?
Just connect the PS3 it also works as a DVD player. Do you really need a VCR player? You can get a converter box to stream the VCR footage through the DVD player/ PS3
Aug 06, 2012 | Televison & Video
I just bought a used ps3 i hook it up to my emerson hd tv and it shows format not supported , i then hooked it up to my poleroid hd tv and it works fine this all thru the hdmi cable
What are the specs on your emerson, does it support 1080p? Make sure you have the right settings on your ps3. If your emerson supports 720p and 1080i then it will not give you a 1080p picture and you might run into issues.
Mar 06, 2011 | Televison & Video
Ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Dec 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
How can I hook up my PS3 to an Emerson TV? There is not a place in the back for the jacks to plug in to. Just a place for an antenna. Model: EWT 19B3, AC 120V 60Hz 72w.
This is an older television. You need an converter box. These are generally called RF modulators and take composite video (3 RCA plugs - 1 video and 2 audio) to coax. If you want to use component video out from your PS3, you may need a component to composite video converter as well. For an example, see http://www.svideo.com/ypbpr2svideo.html. Unfortunately, you will get signal loss with the conversion.
I hope this helps.
(Walmart and RadioShack have carried RF modulators in the past. RadioShack probably still does.)
Jul 21, 2010 | Emerson EWF2004 20" TV
When I hook my PS3 to my Emerson LC320EM9 B the tv goes blank on the HDMI screen and then says unsupported format. What gives?
Something to do with the resolution, just hold the power button on the ps3 for about 10 - 15 seconds. It won't ruin the PS3, it just sets it to it's default settings.
Feb 16, 2010 | Emerson LC320EM9 32 in. LCD HDTV
PS3 hdmi generates a not supported format error message on my emerson lcd tv
your ps3 is set to work on a 1080p tv you can change the pixel setting on your ps3 by holding the power button down while youe console is running until it turns off let go and hold your power button down again when your console turns back on your tv wil ask you about the hdmi device its found unless you failed, good luck n00bs
Jan 10, 2010 | Emerson Televison & Video
Televison & Video Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
