Question about GE Freezers
I have a GE side by side and the freezer shelves are too small and fall when food is put on them solutions??
  • 93 Answers
SOURCE: Upright freezer keeps thawing & re-freezing??
check your defrost timer
Posted on Jul 18, 2008
SOURCE: Kenmore Upright freezer needs cleaning under bottom shelf
cactus bob has it right. you really have to shove it to the left or right though. one side will not feel as loose and that is probably the locking side. the other side will be the loose side. if you lock side is on the left as mine was, you much push the entire shelf to the left very hard. does that make any sense? at first it seems like it wont work, but give it a good shove and it's made to eventually go left.
Posted on Aug 21, 2009
  • 358 Answers
SOURCE: small freon leak, food safety
If it was a freon leak ,probably was also some oil that came out through the hole , clean it up real good and then you can put the food back inside.
Posted on Sep 25, 2009
SOURCE: Shelves not saying in grommets. This happens will
I have exactly the same problem and it is mostly because of the cheap plastic support brackets. I'd like someone to to offer a cheap way to "rig" it so it will support the weight of the shelves when full. Glad tyo know I am not the only one.
Posted on Sep 26, 2009
myrlex
  • 674 Answers
SOURCE: FOOD IN DOOR & TOP SHELF COLD, NOT FROZEN.
bring to the nearest service center is better
Posted on Apr 04, 2010
Plastic door shelves fall out
Try small cable ties if they sit on pegs sticking out you can then cut the ties for removal.
Aug 26, 2014 | GE 21 cu ft Top-Freezer Refrigerator White...
Ge profile refrigerator temperature setting
Sounds like the damper controller is stuck due to obstruction or isn't working at all and needs replaced.
Jul 31, 2014 | GE PFE29PSDSS 29 cu. ft. French Door...
We had a freon leak, I wondering do we need to throw all the food away that was in the freezer??
fixing freon leak at evaporator coils by replacing evaporator on this video. GE side by Side.
Dec 05, 2010 | GE Freezers
Our two lower slide-in baskets will not stay on track. Even when the load has been reduced, the baskets fall off the track. I have tried to bend the sides to better reach the track, but it doesn't work. ...
No, very rarely internal shelves can be moved between generations. Unfortunately all you can do is an improvisation to keep them in place: you need to make the channel walls higher by gluing some small pieces of thick plastic on them using a powerful adhesive - not superglue, something like Loctite Sumo Glue.
Sep 10, 2010 | Kenmore Freezers
Lower shelves keep falling down out of wall supports
replace gromments and reduce the weight that you put inside the shelf/basket.
Apr 22, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I am getting ice around the door and the bottom of the freezer
This is usually due to a plugged up drain. If you look behind the food and shelves near the bottom you will see a small hole facing down. This can be flushed with hot water using a turkey baster until the water runs free
Apr 16, 2010 | Woods 201 cu. ft. Upright Freezer V2003RW3
Small freon leak, food safety
fixing freon leak. Evaporator is leaking freon. Replaced Evaporator on this video
Sep 23, 2009 | GE Freezers
I HAVE AN UPRIGHT FREEZER THAT IS DEVELOPING FROST ON ALL THE SHELVES, I DEFROSTED IT TODAY AND RIGHT AWAY THE SHELVES DEVELOPED FROST AGAIN. THIS HAS NEVER HAPPENED BEFORE, IT WOULD GET FROST ON THE...
Sounds like an air leak. Check the door gasket. If that is sealing well all the way around, try putting a peice of foil duct tape over the two small vents in the bottom of the door.
Sep 05, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
Aug 02, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezers Logo
14 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
