Question about Sirius Stiletto 2 Satellite Radio Receiver
Antenna not detected - Sirius Stiletto 2 Satellite Radio Receiver
My Sanyo Ds27910 when searching for channels it says no antenna detected. what does this mean?
If you see thus, check the antenna connection for firmness first. If it seem correct, the tuner to your set is faulty. Does not process the RF signal. There is no repair to this, other than replacement. Contact any service technician to replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 24, 2014 | Sanyo DS27510 27" TV
It tells me there is no antenna not detected
Antenna not detected could be caused by one of three things: The antenna, the docking station, or the receiver. If you have other equipment to troubleshoot, you can narrow down what is causing your issue and replace it. tss-radio.com is a good source for parts and trouble shooting ;)
Jun 14, 2011 | Sirius Satellite Radio Sirius Sportster...
Antenna not detected what could this be
Usually the antenna is not plugged-in all the way, or you have broken the little tiny antenna wire. Try another location first, then try another antenna.
Jun 14, 2010 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
New dp 19648 sanyo hdtv no signal detected
You gotta have a way to get signal to the tv . If you don't want a outside antenna use rabbit ears .After you hook them up hide them behind the tv then do a channel scan. If you don't pick up all the stations set them on top and scan again or get satillite or cable hd boxes.
Dec 24, 2008 | Sanyo DS27820 27" TV
How do I see the rest of this solution? Garmin Nuvi 660 GPS Receiver Problem: Garmin Nuvi GPS won't acquire satellites Solution by: wingflinger (1 solutions) There is a known hardware bug in the...
you should see it now
There is a known hardware bug in the Garmin 600 series relating to the detection of the connection of an external antenna. The GPS is supposed to do this automatically and when it detects an external antenna plugged in it switches out the internal antenna. Unfortunately, this circuitry doesn't work correctly in some versions of the unit and sometimes it get's comfused and thinks there is an external antenna connected when there is not. This causes the behavior you describe because, for all practical purposes, there is no antenna connected.
Garmin can fix this and they've been known to fix it even on units that are out of warranty. There is a fix that can be done by someone with the right equipment and know-how which requires disassembling the unit and bypassing the antenna switch. Not to be attempted by anyone not experienced in micro surface mount PCB re-work.
Wingflinger
Dec 12, 2008 | Garmin GPS
No antenna detected
More than likely, it is the antenna. Sad to say, but the Sirius antennas go bad very easily. Make sure there is no undue pressure on the antenna wire itself, as that can aide to premature failure. Bad antennas are the number one reason for the unit to read 'antenna not detected.' I have seen plenty of the antennas go bad and they were not misused one bit. If you contact Sirius, they're usually pretty good at understanding the misfortune of losing your paid service. Sometimes they'll ship you out a new antenna.
May 11, 2008 | Xact Communication XTR1 SIRIUS Radio...
Starmate 4 acquiring signal
With the antenna plugged in, it may take a minute to aquire the signal. If it takes more than a minute there is a problem with the antenna or the reciever.
Sep 09, 2007 | Rio SIRIUS Starmate Replay Receiver
No antenna detected
i had the same problem and had to return the antenna to radio shack to get a replacement. the guy said that the antenna had a crack in it from the cold weather or water got into the antenna and that is why it malfunctioned.
Feb 06, 2007 | Sirius Satellite Radio Sirius Sportster...
Call Audiovox support. After waiting an hour I was told the unit (pnp2) was faulty and I was to call customer service to arrange a replacement. Mine is on the way to NY.
Jan 15, 2007 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Sirius Stiletto 2 Satellite Radio Receiver Logo
59 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
