Question about Denon AVR-3805 Receiver
Denon receiver AVR 2307CI not showing display, did we turn it off accidentally?
There is no display on the receiver screen, but it turns ON and it sounds like it is responding to the remote
  • 395 Answers
SOURCE: Denon AVR-681 receiver
this manual is the same as the 681 the only difference is the front input and power difference. this web sight http://www.usa.denon.com/AVR1602_682_ownersmanual.pdf
Posted on Jan 13, 2008
djnick989
  • 1067 Answers
SOURCE: Denon AVR-1905 remote
www.remotewarehouse.com grenteeed fit match
Posted on Jan 26, 2008
SOURCE: Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Posted on Dec 24, 2008
  • 11 Answers
SOURCE: I just hooked up my wii to my Denon AVR-2307CI
Most likely the VCR1 input in the Denon is set to a digital input, you will need to go into the setup for the VCR1 input and make sure that NONE is selected for the digital audio input.  Also - make sure you did not plug the Red/White audio cables from the Wii, in to the VCR OUT, instead of IN.
Posted on Apr 01, 2009
marketex
  • 371 Answers
SOURCE: Denon AVR-1403 receiver switched from digital to analogue.
There are three modes (Auto, DTM, and PCM) on the input mode switch, on the main unit, selected by repeatedly pressing the input mode switch.
However, if you have already depressed the Analog button in, on the main unit you have predetermined the mode as analog.
On the remote, the INPUT MODE switch combines toggles for 5 choices, [Auto, PCM, DTS, Analog,
Ext. input]
My guess is that either the input mode switch on the main unit and/or the remote are toggled to analog.
Posted on Apr 11, 2009
Can I make the Denon AVR-2307Ci receiver have a passthrough for 3D?
I believe it is like my Denon AVR-3808 as it's a HDMI v1.3 compliant. For 3D you need 1.4. So I now use optical cables to the AVR and HDMI to the TV. Then config the DNLA player to split the video to HDMI and the 5.1 sound to optical.
Jul 15, 2014 | Denon AVR-2307Ci Receiver
I reinitialized my 2307ci receiver and cannot get on on screen menu
I had a similar issue with another denon model solved it by buying a cheap replacement remote for denon multiple models, make sure it covers your model. It looks better than the old one and covers every function.
Dec 23, 2013 | Denon AVR-2307Ci Receiver
Denon AVR-2307CI HDMI won't always connect
In short, HDMI will not work. HDMI is riddled with issues, your's is just one of many! HDMI version 1.1,1.2,1.2a,&1.2b do not work 100% on any receiver. The current version is 1.3b and "so far" it works... Now the bad news; It's not just a software patch to fix the problem, it's a hardware issue as well. If your unit is still under warranty, the manufacturer will update hardware and software for you at N/C. If it's out of warranty, it's way too expensive to have done! The fix is to run your HDMI directly to your TV from source, ie. Cable,DVD, etc. then run coaxial digital or optical to your receiver for audio. The catch.. How many HDMI inputs your TV has will limit sources hooked up via HDMI. If you want further info on HDMI issues, just google "HDMI forums" and there are many different sites to answer the problems of HDMI. Hope this helps.
Aug 23, 2009 | Denon AVR-2307 Receiver
Picture takes 1 min to show up on TV thru HDMI
There are firmware upgrades on (some) receivers, call customer support for Denon, or an authorized service center. They can help you over the phone. If you need more help, post a comment and I can help you further.
Aug 05, 2009 | Denon AVR-2307 Receiver
I just hooked up my wii to my Denon AVR-2307CI receiver and have video but no audio. I set component in assignment to VCR-1 and put Green/Blue/Red in comp 1 and Red/White in VCR-1 in Audio IN
Mar 10, 2009 | Denon AVR-2307Ci Receiver
HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Oct 12, 2008 | Denon AVR-2307Ci Receiver
No display
I too have mine for 1 year and all of sudden it powers up for stanby and sound is produced but no display?
May 15, 2008 | Denon AVR-2307Ci Receiver
AVR-2307CI, Auto Room Set Up problem
maby out of phase cheak wiring red on postive black on negitive wires ones out of phase
Jan 22, 2008 | Denon AVR-2307Ci Receiver
DOG!!!!
I'd look here first: http://usa.denon.com/ServiceCenterLocator.asp
Dec 18, 2007 | Denon AVR-2307Ci Receiver
Denon AVR-3805 Receiver Logo
195 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
