Air conditioner not heating - Heating & Cooling
  •  John
    John Feb 24, 2012
    I have a thru the wall type Heater/AC and it will not blow hot air, even when temp is turned all the way hot, it just blows mildly warm air. I've cleaned out the filter and vacuumed all around it, my first thought is the temp control / thermostat.
  • 499 Answers
Depending on whether you have a heat pump or resistive hea-t strip in the ac unit, you may only sense warm a-ir as we are 98.6 a-nd the a-ir exiting a heat pump on the c-ompression cyle a-lone will be around -30 degrees a-bove indoor -a-nbient temp, w-hich usually feels drafty to our skin.If you have a strip the stat and thermal safetys uually are why the heat stops, the heat strip itself can open up too.
Posted on Feb 25, 2012
I have a Crosley 220 volt 18,500 btu window unit air conditioner with a heat pump. The cool air works fine when set on cold, but when set on heat, it doesn't blow warm air. What should I check first?
18000 BTU Air Conditioner ' The Air Conditioner Guide
www.theairconditionerguide.com > BTUs
An 18000 BTU air conditioner is your best bet if you are looking to cool a room ... 2) Frigidaire 18,500 BTU Window-Mounted Median Air Conditioner with ...Troubleshooting Guide. Lost your Everstar air conditioner manual? Fix it tips are here!
Nov 26, 2015 | Crosley CAHE18ER Air Conditioner
Duo therm heat pump blowing hot air only
relay module or communication cable from t-stat issue.
Apr 02, 2014 | Dometic 459186 Duo-Therm Brisk Air...
Ac exhaust fan
Yes for dehumidifier, no for heat mode. In dehumidifier mode all the unit does is takes air in, runs it through the evaporator (cold) coil and the back through the condenser (warm) coil discharging dry, slightly warmer air back into the room. In heating mode however if you don't vent the exhaust there will be no heat produced. Warm air will come out the top but cold air will also come out the exhaust (essentially, in heating mode all it does is operates as an air conditioner in reverse. Hope this helps.
Jan 11, 2014 | Whirlpool ACP102PS Portable Air...
No manual for a cool 438656
Recent Carrier Xhb123d Xy Series Heatcool Air Conditioner ...
domecrel.com/recent-carrier-xhb123d-xy-series-heatcool-air-conditioner/
Download Your Carrier Manual - Oge. Recent carrier xhb123d xy series heatcool air conditioner Heat ?^' enables the heating equipment to operate as needed.
Jan 05, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
How to tell if your unit is a heat pump or just air conditioner with electric heat strip
PTH is a heat pump. PTC is an air conditioner only. I don't believe Amana makes electric heat strip-only models based on what I see in their literature. You can just do a google search and look for yourself.
Nov 29, 2011 | Amana PTH123B25AJ Heat Pump Air...
Wife kicked on heat this morning, worked fine. turned off before leaving for work. now we have nothing. heat or air. thermostats runs a heat pump plus the air. thinking it`s got a bad swich. oh, it`s 21...
Here is a tip about troubleshooting your air conditioner or heat pump...
There are many things that can cause your air conditioner not to cool or heat...
Air Conditioner Trouble - Review the Possibilities
heatman101
Apr 22, 2011 | Heating & Cooling
Name of tablet that are put in air conditioner unit
They are called Humiditreat water purification tablets. What kind of a problem are you having with this Heat-Pump?
Shastalaker7
A/C, & Heating Contractor
Apr 13, 2011 | Friedrich YS13L33 12700 BTU Cooling, 11000...
My hitachi ductless split room air conditioner with heat pump is not heating my room , i have cleaned out the filters and unplugged the unit for 10 min and plugged in back in and it only blows cool air , i...
dear sir
please reset you air conditioner by it,s remote to heat mode and check thermostat setting maybe it has been turn off after remove air conditioner,s electric supply plug from electric source . i hope after reset it will be able to work again.
hope answer the question
thank you
please vote!
Oct 03, 2010 | Hitachi RAS-09UH Air Conditioner
Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Feb 25, 2008 | Carrier 52PQ307 Wall/Window Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
