Alpine CDA-9830 CD Player
Problem for Alpine CDA-9830 CD Player
Alpine CDA-9830 off-n-on mode
By ninety-10 on Oct 28, 2008
Recently my Alpine CDA-9830 has started powering off and on and off again in a never ending cycle. When it stays on it works fine; then suddenly it will switch off and on, staying on for about 1 second, then powers off by itself and back on again. It will do this continuously. My only recourse is to power it off. I cannot determine what triggers it. It does it while moving, while stopped, warm or cold.
Comments:
Apr 13, 2009
- I checked the connections on both the red and yellow wires and all looked fine (wire nuts). I did however trim them back, stripped the insulation and reconnected them. I have not had any problems with it for the past week. I appreciate your feedback on this issue.
Best Solution
posted on Nov 28, 2008
Helpful)
matt9o9
Rank: Apprentice
Rating: 90%, 1 votes
check all the power connections it could be that the remote wire is hooked up to somthing falty, try hooking it up with the positive power to see if that fixes the problem, useing this method will require you to have to turn off your stereo manually. the power wire is yellow and is usually thicker and the remote or (ignition) wire is red, just wire them both together. the remote wire is usually connected to the positive end of somthing that turns on when the ignition is on like the cigarette lighter. if thats not the problem it could be that its not getting enough power ether because the power wires going to it are to thin or there isn't a good connection. check the voltage at your battery and at your stereo.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Alpine CDA-9830 CD Player
Questions and Unsolved Problems for Alpine CDA-9830 CD Player
Do you recommend Alpine CDA-9830 CD Player?
Answer
Answer
cda 9885, it was playing great as usual then it just stopped playing, i tried to eject it to no... (More)
Answer
how to install Pioneer In-Dash DVD Receiver w/ 6.1'' LCD, AVH-P4000
Answer
needs to installed in 2004 chevy cavalier and hooked up to ipod for power and play through stereo. ... (More)
Answer
My sub output RCA is not sending a signal to my amplifier. I have an alpine CDA 9831 head unit and I... (More)
Answer
tried to figure out how to turn the aux and sub woofer buttons
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top In Dash Receiver Experts
Top Audio & Video Equipment Repairmen
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
