Question about Motorola Mobility Droid (2 GB) Cell Phone
Cannot type a text
When trying to type a text I can type 2 words then it freezes - typing beyond that does nothing
  • 380 Answers
    • 1 Press the "Menu" button, which is the far left physical button on the front of the Droid X.
    • 2 Select "Language & Keyboard" from the menu that appears.
    • 3 Select "Input Method."
    • 4 Click "Swype" to enable the Swype keyboard on the Droid X phone.
Posted on Feb 24, 2012
Testimonial: "but even though it DOES work now to type a text, the auto fill in words with apostrophes and comma's, etc. are no longer there"
SOURCE: my phone freezes when trying to create a text message
I had the same problem with my Razr.
What happens is that your user dictionary, the one that predicts what text you write, runs out of memory and that's why you can type numbers but not words.
The solution is to download an m-explorer to access your Razr files. Then, you need to delete itap_user dictionary, restart your phone, and it should work. Hope this helps.
Posted on Jun 18, 2008
SOURCE: Text msg. freezing on V3 RAZR
take it back, ask for a exchange
Posted on Jan 13, 2007
SOURCE: text freezes
I had this problem and I following the advice to restore to factory settings the code I required was 000000. I a am now able to text again,
Thanks for your help
Posted on Dec 07, 2007
SOURCE: My Razr
I do not have my manuel on my phone and I just got text messaging and I do not know how to use it, can you help me?
Posted on Oct 24, 2008
dirinda89
  • 214 Answers
SOURCE: can i turn off the qnotes feature
Your messages are set to 'word' and you want it set to 'alpha'. If you have your user guide this info is on page 45. Here's how to do that. If this helps plz rate this as 'fixya'. If you need more help leave a comment & I'll be happy to help. Thank you kindly.
You can enter text into your phone using the traditional method of pressing a key several times for each character, or by pressing a key once for each letter while words likely to be the one you want are chosen from a database. You can also enter symbols and numbers into a text field. In screens that require you to enter text, you see the following icons. These icons tell you which text input mode you are using: When you access a screen that requires you to enter text, you start in the mode last used.
To choose a text input mode: 1 At a screen that requires you to enter text, press m. 2 Select the text input mode you want to use. A checkmark appears next to the current mode.
Posted on Mar 15, 2009
While typing text my cursor jumps back 2-3 lines
The keyboard speed maybe set too low for your typing skills, try increasing the keyboard speed.
Open the Control Panel - Keyboard - Speed tab and move the speed slider to the max speed.
Apr 16, 2013 | Computers & Internet
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
How can i unhighlite the text in macbook word 2008
JUST READ THROUGH
Just wondering if anyone else was having issues with Microsoft Word from MS Office 2008, where you open the application, you type a few sentences, and the application freezes with the spinning circle of death that won't go away until you click the dock where it says "application not responding" and do a force-quit? You can leave the circle spinning for 10-20-30 minutes, and it never goes away.
Now for the weird part--this error only happens for me when I'm using a specific document on my computer. I can open Word, start a new document, type several paragraphs of text, and it works fine. But I've been working on an existing paper for about two months that all of a sudden started causing these freezes/crashes when editing it. It's about 30 pages roughly, no images, no big inserts that would take up a lot of memory (116 kb in size). And up until today, there were no problems. So why all of a sudden can't I edit anything on this paper without freezing the program?! I downloaded the Microsoft Office 2008 Service Pack 1 that was just released after this problem started, and ran all the recent Java and program updates through Software Update with computer restarts. I even copied the text from the Word document I was working on, pasted it into a new document, tried saving it as both .doc and .docx, and again the program still freezes when working with that text in a new file. This one baffles me. It's like the text within a document is somehow freezing the application. One thing I did notice is that the freezes seem to happen when I'm scrolling using a mouse wheel. Not always, but quite a bit. I suppose this is some memory issue related to several pages of text that the program can't render or process when you add new lines of text or scroll, but again, I can't figure why this paper I've been working on for months all of a sudden decided to start freezing Word today. Can you really only have 30 double-spaced pages of text in Word before it crashes?
Looks like I've found my reason to switch to Open Office, since I'm 3-4 days out from a
Sep 23, 2010 | Apple MacBook Mac Notebook
My phone freezes up when tryin outgoing text
try to reset
Start-->System Tools -->Master Reset
Jun 13, 2009 | Motorola Mobility Moto Q
When I send text messages I can't see the words I'm typing, it wont let me text certain people, it wont stop sending messages to other people, and it keeps freezing.
I had the same problem, and it will only get worse. It's a simple fix though...just follow these steps. I actually found this solution on this exact website =] so if you can't fully understand how I explain it, ou can find other posts as well.
Settings >> Text Input Settings >> Uncheck box next to "Suggest Words When Typing."
Simple enough, restart the phone and start texting, It should be fine. Hope this helps!!
Jun 08, 2009 | Motorola Mobility Q9m Smartphone
My LG VENUS keeps freezing!!!
i would guess that when you droped it you knocked something loose is it still under a warenty? if so i would return it for a new one if not take it into a shop
Jan 10, 2009 | LG VENUS Cellular Phone
My rizr z3 phone freezes while texting or typing anything. Have to remove battery to get it to come back on.
The problem is autocomplete.. disable it and the text messaging will stop freezing. Just go into the same screen as if you're about to type up a text. Then follow these menu prompts "Options>Text Setup>Word Completion (Off)" That should help.
Aug 09, 2008 | Cell Phones
My phone freezes when trying to create a text message
try deleting some text messages, especially your outbox and unused files on your phone.
Feb 10, 2008 | Motorola Mobility RAZR V3
It keeps freezing up
probably is because your memory if full so you have to delete all the messages that they are store in your memory phone go to messages select options select delete all and that will be all
Dec 29, 2007 | Motorola Mobility RAZR V3
Motorola Mobility Droid (2 GB) Cell Phone Logo
147 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
