Hp dx2310 MT (KQ861AV) motherboard problem
Good day, my problem is when i turned on my computer and the HP logo appear it does not go to bios set-up rather it freeze or hang-up... please i need an advice on this matter.. thanks!
  • 43 Answers
SOURCE: MSI MS-7142 motherboard problem
try cleaning CMOS with cmos jumpers or just remove your battery of motherboard for 10 seconds (previously unplug power from PC.)
Posted on Jan 31, 2008
tpvijay
  • 34 Answers
There is a general possible issue may be with
  1. CPU/Memory Clock Speed...
  2. CPU Voltage
  3. CPU FAN Status
guide2u
  • 461 Answers
SOURCE: HP DX5150 MT TOWER
I'm not sure what operating system that you are using.. I have a list of them..
you can try and get them here
http://etech.maiila.com/?p=9
Posted on Apr 17, 2008
Daholk
  • 41 Answers
SOURCE: My HP dv5000 laptop has AMI BIOS beep code - 4 beeps
It sounds like either RAM or VIDEO problem to me. (I can't remember the specific beep sequence for AMI bios errors).
Hard to diagnose in Laptops.... if it was a desktop you can just start swapping out the RAM DIMMS..... are you techo enough to check whether you have 1 or 2 RAM cards installed? If 2 then run it with each card in turn to see if it boots (indicating 1 faulty RAM stick). If only 1 then try running MEMTEST on it to see if any errors. (I like HIRENS if you have it... I think it usually has latest MEMTEST on it).
If your cards all pass then its very likely a video problem. If its onboard video with no expansion slot (likely in a laptop) then you may be buggered.
Let me know if you need a hand doing any of the above.
Posted on Mar 25, 2009
leecom72
  • 4806 Answers
SOURCE: problem with my HP Compaq DC5100 MT
Hi there.
Go here to HP support and download the drivers you need, they are Vista drivers so should work on Win7 >>>>>
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=uk&prodNameId=447280&prodTypeId=12454&prodSeriesId=454811&swLang=13&taskId=135&swEnvOID=2096
Good luck and thanks for using FixYa!!
Posted on May 27, 2009
No audio out
Make sure that you do not have the mute on. That is actually one of the most common fixes I run into when people complain about no audio. Plug in different speakers or a set of headphones to make sure that it is not your speakers that are bad. You can also check the device manager in windows to make sure that there are no devices showing as not installed.
Apr 26, 2014 | HEWLETT-PACKARD Computers & Internet
Asus NVIDIA GeForce GT 420 not compatible with HP Compaq dx2310 mt? I can't run my NBA 2K14 game with my computer specs. Help please! Thanks!
perhaps you could follow this thread on the HP website.
http://h30434.www3.hp.com/t5/Hardware-Upgrades-Replacements/NVIDIA-Geforce-GT-420-on-a-HP-DX2310-MT-NOT-COMPATIBLE/td-p/3059793
Oct 30, 2013 | HP Computers & Internet
What function key gives entry to cmos
BIOS is fixed program that starts up the computer. BIOS is initialized during start up of HP Compaq-6715B which sets the computer settings to be uploaded. BIOS enables the creation of a bootable diskette, CD, or USB key that can be used to locally restore or upgrade the System BIOS in the supported notebook models with a 68YTT Family ROM. Only insert the USB drive that will be used to format and create bootable BIOS upgraded USB media. However, you should remove all unused USB drives and flash drives from the notebook before. In order to ROM family and ROM date, press F10 on the target notebook during startup to run the setup utility.
The tips to get into the BIOS of HP Compaq-6715b are:
  • Press F2 for setup
  • Shows logo
  • Independent of OS
Press F2 for setup
BIOS often has a blue background, and uses the arrow keys, PageUp, PageDown and enter keys to change the settings. After you have got into or accessed the BIOS, you can change the boot order settings so that the floppy disk is checked first to see if it contains a bootable program. Usually a message will appear telling you how to enter the BIOS setup program as the computer starts up, such as Press F2 for Setup.
Shows logo
Your HP Compaq-6715b might be configured to show your computer's logo instead of important BIOS messages. In this case, you can press Esc or Tab while the logo screen is visible. If you are facing problems pressing the pause button in time, turn on your computer with your keyboard unplugged. In this situation you will receive a keyboard error, which helps you in pausing the startup process long enough for you to see the keys necessary to enter BIOS.
Independent of OS
The PCs with both PS/2 and USB connections are configured to only allow USB input after the POST. If you are using a USB keyboard, it could be impossible to access BIOS. You would need to connect an older PS/2 keyboard to your PC to access BIOS. The BIOS accessing is independent of any Operating System on your computer because the BIOS is part of your motherboard hardware.
http://www.bostonrecycling.net/
Jun 25, 2012 | HP Compaq 6715b Notebook PC
I have an HP media center m260n and it is stuck on blue hp logo screen. we've unplugged everything (except monitor and wired keyboard) and continually pushed the F1 (set up) key and still nothing. any...
HI.
Well, you had the exact right idea, it's just that you was pushing the wrong button is all.
Make sure the power cord and ethernet cable if your computer needs one, and then press and hold the power button for a minimum of 45 seconds, and then release the button.
This allows for the capacitors on the motherboard to discharge their static charge, and return the motherboard to a ready state.
This isn't just a "shadetree machanic" type of fix, it is also the official HP procedure for a hard system reset.
Hp says that in some cases, this might also reset the bios password to blank, so if you have a password on your bios, you might need to redo it afterwards.
HP said that it is a motherboard problem, but I have worked on several HP computers, and it's NOT the motherboard that goes wrong, it's a glitch in the bios program.
Unfortunately, HP uses their own bios, so you can't just load any bios that you want into it.
Too bad, though, because some bios programs have extra features built in to them, allowing extra functions like overclocking the processor, turning on multi-core support, and being able to add more memory than HP bios will allow.
I hope this helps you to know what is going on.
Good luck to you, and have a good day.
Jun 27, 2011 | HP Media Center PC M260n (DF200A#ABA) PC...
I want to restore my laptop to factory settings its an hp pavilion dv4000
  • Using the recovery partition
    • 1 Turn on your computer and insert your recovery disc. Press F10 during start-up to open the console. This opens up the HP recovery console.
    • 2 Click "Next" on the screen that appears.
    • 3 Choose whether you want a nondestructive recovery (one that keeps your files in place) or a destructive one (one that erases your disk and rebuilds your system to factory defaults). If most of your files aren't corrupted or are still usable, go with a nondestructive recovery. Otherwise, perform the destructive recovery.
    • 4 Follow the instructions on the prompts that appear to restore your HP Pavillion.
  • Using recovery discs
    • 1 Turn on your computer. Press F1 at the first logo screen to enter the BIOS menu.
    • 2 Move to the Boot Options section of the BIOS menu. Look for the Boot Priority menu.
    • 3 Set the Boot Priority option to booting the CD-ROM first.
    • 4 Insert the first recovery disc into the HP laptop. Then press "Enter" on your keyboard to save your settings and exit. The computer will then reboot into the recovery console.
    • 5 Follow the instructions on the prompts that appear, to restore your laptop.
  • Jan 01, 2011 | HP Pavilion dv4000 Notebook
    Reset the BIOS on a Compaq server 740 jumpers settings
    Don,t do that insatead:
    Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
    1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
    2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
    NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
    1. In the BIOS Setup utility, select the Exit tab.
    2. Select Load Setup Defaults .
    3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
    4. Press Esc and then Enter to exit Setup.
    Nov 13, 2010 | Computers & Internet
    Hi have a dv8225nr laptop. did bios upgarde to fix keybroad problem after download restarted laptop and gets to hp logo and stops.can't get in to bios. can get to screen to set was goiging on with esc keep...
    when you make the update bios you back up the old one?if yes then restore if not find the battery on the motherboard remove it end put it back this should reset all then you should go in bios to see the version of bios is active.
    Dec 08, 2009 | Computers & Internet
    My hp pavilion a1330n computer freezes on the HP
    the dreaded Blue-Screen of death.
    Usually caused by:- Ram Failure ( memory Modules )
    CPU Failure ( Processor Failure )
    Hard-Disk faulty, not spinning et,c.
    Cmos battery fault.
    Missing/deleted/corrupted operating System files.
    Possible Solutions:- remove cmos battery, from Motherboard for 10 seconds and replace. ( eliminates cmos/bios errors )
    remove 1 stick of Memory ( Ram ) and test individually ( eliminates 1 or More Faulty sticks Of memory Or Slots )
    remove, CPU Fan/heatsink, remove CPU and re-seat, re-grease with Artic-Silver or similar ( thermal-Compound ) replace heatsink/Fan. test.
    Hope this points you towards a Sucessful repair.
    Mike @ Compurepair. No-Links No-Nonsense Just Good Practical Advise :-)
    Nov 04, 2009 | HP Pavilion Media Center a1330n - AMD...
    Bios says no ide device found (hard frive missing?)
    If the BIOS is not detecting your hard drive, then there are two possible suspects here. Could just be your hard drive or it also be your motherboard.
    If you have already reseated your hard drive and memory and the symptoms are still the same, then go to the nearest local computer shop that sells HP. Have them try a known-good hard drive on your system. If it works, purchase a new hard drive. If it doesn't work, your mobo needs to be replaced.
    Jan 01, 2009 | HP Compaq Presario v3000z Notebook
    Start up
    - BIOS not BIO :)
    - all computers, laptop/desktop/server..etc ... have a small battery, that helps keep the settings in BIOS as the user changed them !
    - u;ll have to go through u're motherboard user manual to see exactly where the bios reset jumper is ! If u don't have the manual, u will see the battery (is a round and flattened 1.5 cm battery...u cant miss it, is the only one in the computer) somewhere on the motherboard (ussualy in the lower right part of the motherboard). You just have to remove it for 5 seconds or so (force it out of the soket it is in) and then replaceit back. By doing this all the BIOS settings go to the manufacters default settings...
    Aug 09, 2008 | HP Pavilion a800n (PP163AA) PC Desktop
    Computers & Internet Logo
    74 people viewed this question
    David Payne
    David Payne
