Question about Raindrip R673CT Digital Water Timer
TIMER WON'T STOP RUNNING
Ypu have to set the stop time
Posted on Aug 19, 2013
Dryer intermittently not starting.
The rat chewed up the power line and caused it to short out. Kill the rat!
Jul 14, 2013 | Whirlpool Dryers
Won't stop running
door switch needs replacing
hydeparkappliancerepair.com or visit us on Facebook
Feb 16, 2013 | Kenmore 500 6952 Dryer
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
Won't stop running
1) the water can be pre-heated, if this is your case, you must test the heating element +thermostat see the video how to test it. 2) test the timer is stuck with some conctacts, try to clean, tight any wires loose, open, or broken, or replace the timer. God bless you 7_11_2012_6_28_33_pm.gif
Jul 11, 2012 | Bosch Dishwashers
Won't stop, have to manually open door
Sounds like a bad timer. Your dryer is a Whirlpool product.so a replacement timer should be easy to locate. If the timer is advancing but the dryer won't stop, the problem could be the control unit. Run another load of clothes and take notice of the timer's position. If it doesn't run out, then it's very likely the timer. The video below shows step by step instructions for replacing the timer unit.
Mar 30, 2012 | Estate TEDS740JQ Electric Dryer
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
The dryer won't stop running after a heating
Hello, Thank You for using FixYa. I will be helping you today.Replace the timer.It has a bad contact.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Kenmore 64882 Electric Dryer
Whirlpool electric dryer
As long as the timer is on your heating element will be on.Sounds like you've have lost both.
Feb 11, 2009 | Whirlpool LEQ9858P Electric Dryer
Raindrip R673CT Digital Water Timer Logo
141 people viewed this question
Top Raindrip Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Hippy_dd
Are you a Raindrip Hardware and Accessory Expert? Answer questions, earn points and help others
