Question about Samsung Washing Machines
Samsung WF210ANW washer is shaking, rattling and moving all over the laundry room, I thought it was going to knock out the wall next to it.
SOURCE: shaking like crazy
For the new machine that is violently shaking, make sure the shipping bolts in back are removed and their plastic pins.
For a machine that has developed this problem, it may be the shocks under the tub. these can wear out. but check level and balance first.
When it is on the pedestals the rubber shims are not supposed to be there, they are for dryer only.
Posted on Apr 19, 2008
SOURCE: excessive vibrations
I have ordered KE shake away pads. I'll have to see how they work.
Posted on Jul 05, 2008
  • 69 Answers
SOURCE: washer shakes and bounces across the floor on spin cycle
http://www.acmehowto.com/howto/appliance/washer/check/movement.php
Try using that guide.
Posted on Oct 04, 2008
fredcause
  • 51 Answers
SOURCE: washer shakes and rattles when using regular cycle.
just a long shot but open it up and grab the edge of the tub and give it a good tug and a shake in an effort to get the tub (empty) to settle in properly on the suspension springs inside.
Posted on Dec 08, 2008
  • 106 Answers
SOURCE: My GE frontload washer "jumps around" the room.
Plug off the mains. Open up the machine to look for defective shock-absorbers, broken springs, etc. You shd have done this much earlier, surely you're not walking around the house with a helmet.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Posted on Mar 01, 2009
Tip
Basic tip for out of control, out of balance washer
I thought my washing machine (a top load,stackable Maytag), was going to rock and roll right out of my laundry room and move in with the neighbors!
It was not quite that bad....yet...but it was rattling across the room. I tried shifting and shuffling my loads and downsizing them.
However, just like the dryer vent must be cleaned out, and a fabric softener is great for this job....our washing machines have this need, too.
After loads of trafficking diapers, childrens' play clothes, tennies,etc., my machine was giving me my money's worth....but the bumping and grinding had to stop!
I pulled out the vent, located in mid-center of the top-load washer, unscrewed pieces that were removable (don't force anything!), and ran them through hot water and bleach. Some of the 'gunk' had to be removed with paper towels. Afterward, I re-inserted the catch-all pieces, and the washer is now washing, on a balanced,and quieter cycle. Spin drying in my washer has never been so pleasantly silent.
on Mar 09, 2010 | Washing Machines
Water leak at front left corner of our Samsung WF210ANW/XAA01 front load washer
You will need to order and replace the door seal, also verify the door is not loose due to worn hinges. Go to www.applienceparts.com for parts if you like.
Oct 26, 2016 | Samsung WF210ANW 3.5 cu. ft. front load...
Stacking washer and dryer still vibrating and walking during spin cycle even though stacking kit is attached
Assuming that you've installed the stack kit according to instructions, you should check the following:
1. The dryer should be securely attached to the washer and not wiggle or move. The washer must always go on the bottom of the stack.
2. Washer should be level and have all four level legs making solid contact with the floor, no wobbling.
3. Make sure the drain hose is not pinched or restricted (or there is not debris in the drain pump) as a slow pump out will accentuate vibration problems.
4. Make certain you've removed all of the washer packing bolts before using the machine (see owners manual for description.)
5. The floor must be solid with no "springy" or "spongy" feel. No matter what you do to the laundry set it will vibrate on a less than solid floor. This occurs on upstairs installations or other wooden floors, especially in an older home. Sometime the floor can be braced to stiffen it. Also, vibration pads are sold that might help minimize the vibration. The walking is a symptom of vibration.
Experience shows that most problems of this sort result from incorrect installation and/or flooring issues, not the laundry. You should not attach it to the wall. It is possible the washer has a problem in which case a technician would need to check the unit. They can check the suspension and drive system for proper operation.
Aug 24, 2014 | Samsung Front-Load Washer and Dryer stack...
For spares:
espares.co.uk
Mar 01, 2009 | GE WSXH208A Front Load Washer
Washer shakes and rattles when using regular cycle.
Dec 08, 2008 | Hotpoint Washing Machines
Excessive vibrations
Jul 01, 2008 | GE Washing Machines
Replacement For Whirlpool AWG329 washer/dryer
Not sure if this will help, but Whirlpool has a pretty neat tool that can help you configure your laundry-room layout: LAUNDRY-ROOM LAYOUT
Nov 18, 2007 | Whirlpool AWG329 Front Load Washer/Dryer
Washing Machines Logo
122 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
