Heating & Cooling Logo
A
Anonymous Posted on Feb 24, 2012
Carrier air conditioner E3 problem - Carrier TSTATHPP 7-Day Programmable Thermostat
5 Related Answers
Anonymous
  • Posted on Jun 27, 2009
SOURCE: I have a 51GR Carrier window air conditioner and the
TRY:
Power off (Disconnect)
Push together "Temp up" and "On/off" and reconnect power while pushing.
1STHVACMAN
  • 69 Answers
  • Posted on Aug 23, 2009
SOURCE: Carrier programmable thermostat flashes E3
manufacturers put their name on lots of other peoples stats. Honeywell has a very good help line and an online service. Need to know whose thermostat white- rogers, Or honeywell Or Model number
Anonymous
  • Posted on Dec 26, 2009
SOURCE: carrier spit type air conditioner 5 blinks
Unit should reset with circuit breaker off/wait/on. Codes are near the end of this manual.
http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/48ss,sx-12si.pdf
My panel cannot be read.
Anonymous
  • Posted on May 21, 2010
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Anonymous
  • Posted on Sep 29, 2010
SOURCE: carrier holiday portable air conditioner manual
Mine has a model number of PCA061D.
If you remove the water capture reservoir, there is a sticker that has the model number.
Once putting off fujiaire split ac its shows E3 Error
Try this: http://www.manualslib.com/
I Googled this: Fuji air conditioner E3 Error
One item seems to have the answer:
http://errorcodeairconditioning.blogspot.com/2010/10/fujitsu-air-conditioner-error-codes.html
"E3:00 Return air thermistor short circuit"
So more than likely you have a crossed wire issue. good luck.
I'd call ACND service man!
tip
CARRIER WINDOW ELECTRONIC CONTROL
CONTROL PANEL ERROR CODE
PROBLEM
REMEDY
E4
Thermistor problem
Shutdown unit and restart
E3
Unrecoverable of E2RAM data
Shutdown and unit and restart
E2
Loss or corruption of stored data
Using remote control go to Cool mode and shutdown the system, and then restart.
E1
Code validation check fail
Shutdown and unit and restart.
FL
Filter check warning
Press the “MODE” and (DOWN) “▼” buttons together until error code disappear.
Note: If the problem persist replacement of control board is needed.
-Push arrow up and arrow down together for 5sec. the room temp. will show.
What is e3?
change metallic sensor
How to fix Carrier E3 split type Model: 42CIV012308
Your question is to vague. What are the problems, list here and then some one will get a better idea of a solution
How to fix E3 in Carrier AC?
Has to be the cable. If you attach the sensor directly to the thermostat, you will get a good reading. If ohm the cable it shows open with both ends disconnected OR with the remote end twisted together.
1helpful
How serious is an e3 system error message on a carrier thermidastat control? the homeowner's manual says it means there is a problem with the outdoor temperature control reading.
Its more of a nusance. The temperature probe is not reading of has a broken wire. its two wires and reads the outdoor temperature. Its usually at the bottom of the electrical compartment or underneath the unit. Its a $20 part and you should be able to get it at heatcoolparts.com. It you have dual source system it tells the system when to switch from heat pump to the furnace. I believe you can jumper it out with a 10K ohm resistor to have the furnace run instead of the heat pump.
Not cooling the house.
clean or change air filter and if the filter is realy dirty you might need to clean the evap coil
6helpful
2answers
Carrier Thermostat Displays Error Code E3
Carrier Air Conditioning display an error code E5 and then swtich off
Top Carrier Heating & Cooling Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
