Samsung SGH J150 Cell Phone Logo
Posted on Feb 24, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My internal memory 9 MB out of 10 MB is got occupied and i can't identify where it is ? and i used nps also to find, it is not getting. i done phone formating also - nothing responsible
Anonymous
Level 3:
  • Master 380 Answers
  • Posted on Feb 24, 2012
Anonymous
Master
Level 3:
Answers
380
Questions
0
Helped
102712
Points
1118
Samsung SGH-J 150 : Mobile phone, camcorder, camera: Yes, Integrated, megapixels: 1.3, bluetooth, synchronisation: SyncML, usb connection, aerial: Internal, design: Regular, number of colours: 262000, e-mail: POP3 / SMTP / IMAP4, java, mp3/audio player, radio, sar-value: 0.596 W/kg, video player/streaming, voice memo, weight: 66.5 grams, internal memory: 10.0 MB, supported external memory cards: MicroSD.
*#9998*585# Non-Volatile Memory (NVM)
#7263867# = RAM Dump (On or Off)
How do I add memory to my acer travelmate P256M?
You should check Internal memory (REM) installed, Internal memory type: probably DDR3L-SDRAM, Maximum internal memory: 16 GB, and number of memory slots available and occupied
Problem is tha compatibility of memory and parity requiremens Means if you have 4 Gb wirh 2 x 2 Gb, not all boards let yoi nstall an 8 gb Memory with an existing 2 Gb memory
The other issue if you have one 4 Gb DDR3L-SDRAM does your board accespt other specificacion of 4 Gb memory or must be the same.
You should check this info with someone who has the technical specificacions of your MB
Will windows vista 32 bit work on my HP ze5270 notebook/laptop?
look for windows vista minimum requirments here >>
Windows Vista Home Basic
Processor 800-megahertz (MHz) 32-bit (x86) processor or 800-MHz 64-bit (x64)
System memory 512 MB - bytes (MB).
Note system configurations that use system memory graphics memory, at least 448 MB of system memory must be time operating system after some memory is allocated to graphics.
Card DirectX 9 class graphics
Graphics memory 32 MB - bytes (MB).
Hard drive size 20 Giga - (GB) in which the free space 15 GHz - (GB).
DVD drive internal or external
Internet access capability
Audio output capability
AS YOU KNOW THAT THE INTERNAL MEMORY OF THIS DEVICE IS 186 MB IT IS VERY LOW AND I CAN'T DOWNLOAD MORE APP DUE TO THE INTERNAL MEMORY HOW CAN I SOLVE THIS PROBLEM ? MOREOVER I USE SD CARD 8 GEGA
Go to the "My Files" app, and check what files and downloaded applications are in the phone memory. Try to move the applications to the SD card, then move any other data (videos, pictures, music, etc) to the SD card.
I also recommend downloading either the CCleaner app or the AVG app to clean out junk files form the memory.
Why can't I take more than 3 pictures with internal memory? It then says internal memory is full.
The camera that you have only has 10 MB of internal memory , if you are taking photographs at 12 megapixels only 3 photographs would fit as each photograph would be around 3 MB each. I would suggest to buy an external memory card and take photographs on that. The internal memory is only for demoing and checking if the camera works and not for standard use. Buy a SD/SDHC card , they are very cheap nowadays and have immense capacity to hold lot more photographs.
I m getting Phone Memory Full Error every now and then in my phone. I have deleted all content in Phone Memory in my Nokia E71 phone. But still i have this problem. Its shows occupied phone memory is 119...
There are basically 2 ways to try to fix this, the first is for you to go to the setting of the phone and restore factory settings, it will ask for the security code. provide the original code for it and your phone will be resetted. Then the memory will read normally. The other solution is for you to have the phone flashed with the appropriate software, that will automatically reset the phone.
Take care and good luck
Gateway Foxconn C51GU01 (105552) Problem: blue
Possible a memory socket is bad. Make sure you are using the correct type of memory including parity and compatible speeds. It is recommended to use like memory sticks in each slot. Some PCs even require the sticks to be equal memory capacity. User's guide should tell you what the compatible capacities and speeds should be. If you don't have the manual, you can get by looking up your PC model number on Gateway.com.
Bret
1-2-1ComputerServices
Need Manual for Slot1 PIII Gateway Jabil Tabor III Motherboard.
The memory specifications for that motherboard are as follows:
  • 100-megahertz (MHz) Memory Bus Speed (FSB)
  • Three 64-bit or 72-bit Error Checking and Correction (ECC) 4-clock, 3.3V, unbuffered synchronous DRAM (SDRAM) Single or double-sided DIMMs in the following sizes: 8 MB, 16 MB, 32 MB, 64 MB, 128 MB
  • Expandable to 384 megabytes (MB) of SDRAM, CAS latency of 2, using 64-Mbit chips
  • DIMMs must adhere to the Intel 4-clock 100-MHz 64-bit unbuffered SDRAM DIMM specification, latest revision
  • Uses gold-plated DIMM socket
  • ECC signal and multiple bit detection, single bit correction, supported, using ECC DIMMs, can be enabled and disable in the BIOS Setup Utility
  • 0helpful
    How do I get music into SV1011 digital Picture frame
    There is no internal memory on your frame. Therefor you must transferre the music onto the SD card and then it will play from your frame.
    Contact KODAK:
    http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
    My 2GB memory stick PRO duo claims its full,
    i) it has nothing to do with the number of songs(like you said 188 songs,,,, 15 picturess... or something like that ), it depends on the storage capacity of your memory stick(2 GB)
    ii) some songs may occupy more memory, so may occupy less memory....for eg: song1: 10 mb, song2 : 3 mb; .....
    so i would suggest to store some songs(not numbered ...depending upon their capacity and suffiencecy of your card....)
    Top Samsung Cell Phones Experts
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
