ERROR MESSAGE E 7 A1035100
TRYING TO ERASE DVD-RW DISC WHEN RECORDING ERROR COMES UP STATING 'CAN NOT RECORD ON THIS DISC.'
SOURCE: Emerson DVD Recorder EWR20V
The problem is likely that you are using 8x/2x media. Though the booklet does not say it, the burner does not support anything above 4x for DVD-R and 1x for DVD-RW. Calling their tech support can (possibly) get an update for this problem. Otherwise, the burner cannot use anything but outdated media.
Posted on Jun 02, 2007
SOURCE: dvd recorder won't record on DVD-RW disc.
CLEANING THE DISC LENS ? If this unit still does not perform properly although you refer to the relevant sections and to ?TROUBLESHOOTING GUIDE? in this Owner?s Manual, the laser optical pickup unit may be dirty. Consult your dealer or an Authorized Service Center for inspection and cleaning of the laser optical pickup unit. FROM EWR20V5 OWNERS MANUAL FUNAI-CORP.COM
Posted on Jul 01, 2007
SOURCE: Sylvania DVR90VE DVD Recorder / VCR - formatting DVD-RW
This unit only supports 2X -RW discs or 4X -R discs.
Posted on Oct 28, 2007
SOURCE: Emerson EWR20V4 that wont record DVD's
Sure, My suggestion is to call 1-800-605-8453, They will be glad to help you with that error code!
Good luck
Posted on Feb 08, 2008
eswaran73
SOURCE: Loading DVD-RW discs
My recorder has stopped accepting NEW DVD-RW discs and ejects them.
There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording
I have tried several different DVD-RW makes. Puzzling??
Posted on Nov 08, 2008
Playback on recorded disk
The DVD has burned incorrectly and the data has likely corrupted somewhat to the point where the DVD player/writer can't read it. You may be able to watch it on your computer with a DVD drive. Try saving it to your computer, then erasing the disc and trying to record something short to it and play it back - if it plays back, it's likely to have been a recording problem, however, if you get the same problem, it may be a dodgy disc, a faulty DVD player/writer, or a format problem. Try this, in order left to right. Copy DVD to PC -> Erase DVD -> Record on DVD from TV -> Play back If plays back Erase DVD -> Continue as normal If not Buy DVD-RW (emphasis on the minus) -> Try using that If that works continue as normal, otherwise... Return the DVD player/writer under warranty for repair/replacement.
Sep 17, 2007 | iLO DVDR04
When trying to record a home video VHS to DVD this is what I get. E-4 54040990 Cannot record on this disc. The disc is brand new.
Have you've tried cleaning the laser with a cleaning disc?
Failing this it may be worth removing the cover and cleaning the lens directly with a QTip and some lens cleaning fluid. Only use a drop and then wipe off with a clean dry QTip.
The other option is that you are using an incompatible format of blank DVDs. I've heard of people having problems using DVD-R & DVD-RW and although it is lised as being suitable for all types of recordable DVDs I belive you're best using DVD+R & DVD+RW.
The Manual states
Recordable disc
• We strongly recommend for good recording quality:
SONY DVD+RW 4x, MAXELL DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, TDK DVD+R 4x/8x/16x,
MAXELL DVD-RW 4x, MAXELL DVD-R 8x/16x
• Discs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+RW 4x VERBATIM DVD+R 8x
VERBATIM DVD-RW x VERBATIM DVD-R 8x JVC DVD-RW 4x MAXELL DVD-R 16x
May 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Erasing the disc
it would actually depend on the type of disc your using for you to be able to erase the contents of the disc and reuse that same disc for new recordings. it's called "formatting the disc". it deletes all recordings and returns the recording medium to its original empty state. this operation is possible if you are using dvd-rw or dvd+rw (re-writeable) discs only. please refer to pp.12-13 of your camcorder's instruction manual for more information about disc format features. hope this helps. thanks:)
May 28, 2010 | Sony DCR-DVD608E DVD Camcorder
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Error code E 4 54040990
jamesgranger - I think your DVD recorder is still having trouble reading the DVD+RW. It should not have a problem using a DVD+RW many times. Try taking the DVD+RW and put it in your computer. Find it in Explorer, right-click and choose "Erase". Then try to record to it using the DVD recorder again. If it works, you can use this to record, though it might be a pain.
The fact that your machine will record to the +R means that it works. Failing to work (record or erase) on the +RW means it's not reading it well. I would try running the lens cleaner again if it were mine. Also, I would make sure that the unit didn't have a lot of dust in it. If you can, power it off and use some spray-air to be sure there's no dust. You may have cleaned the lens, but if there's a lot of dust inside the unit, it will quickly find it's way back to the lens and you'll have the same problem. Michael
Jul 09, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Disc initialization Toshiba D-R250SB recorder
can i suggest you record vhs tapes on maxell dvd-r or tdk dvd-r (if you wish to keep them) used the dvd-rw to record those sporting events / movies or specials that you might not be around for....(because any one can accidently erase an dvd-rw).......now that formatting dvd-rw issue. i found that dynex http://www.dynexproducts.com/c-11-storage-media.aspx dvdv-rw works best with toshiba . i record all the ultimate fights erase (format) after i look at and on to next good luck
May 28, 2009 | Toshiba DRW2 DVD Recorder
Good luck
Jan 29, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Will not playback get error message Please Check Disc
i have a r136 , have you got the dvd discs u need ? i had the wrong format .
eg, dvd+rw needed dvd-rw
if not and there re-recordables they dont work after a few recordings and u need a new disc.
Dec 05, 2007 | Samsung DVD-R130 DVD Recorder
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
